Overview of MRS Cluster Logs
Log Description
MRS cluster logs are stored in the /var/log/Bigdata directory. The following table lists the log types.
         Type  |
         Description  |
         Installation log  |
         Installation logs record information about FusionInsight Manager, cluster, and service installation to help users locate installation errors.  |
         Run logs  |
         Run logs record the debugging information, status changes, potential problems, and error information generated during the running of services.  |
         Audit logs  |
         Audit logs record information about users' activities and operation instructions, which can be used to locate fault causes in security events and determine who are responsible for these faults.  |
The following table lists the MRS log directories.
         File Directory  |
         Log Content  |
         /var/log/Bigdata/audit  |
         Component audit log.  |
         /var/log/Bigdata/controller  |
         Log collecting script log. Controller process log. Controller monitoring log.  |
         /var/log/Bigdata/dbservice  |
         DBService log.  |
         /var/log/Bigdata/flume  |
         Flume log.  |
         /var/log/Bigdata/hbase  |
         HBase log.  |
         /var/log/Bigdata/hdfs  |
         HDFS log.  |
         /var/log/Bigdata/hive  |
         Hive log.  |
         /var/log/Bigdata/hetuengine  |
         HetuEngine logs.  |
         /var/log/Bigdata/httpd  |
         HTTPD log.  |
         /var/log/Bigdata/hue  |
         Hue log.  |
         /var/log/Bigdata/kerberos  |
         Kerberos log.  |
         /var/log/Bigdata/ldapclient  |
         LDAP client log.  |
         /var/log/Bigdata/ldapserver  |
         LDAP server log.  |
         /var/log/Bigdata/loader  |
         Loader log.  |
         /var/log/Bigdata/logman  |
         logman script log management log.  |
         /var/log/Bigdata/mapreduce  |
         MapReduce log.  |
         /var/log/Bigdata/nodeagent  |
         NodeAgent log.  |
         /var/log/Bigdata/okerberos  |
         OMS Kerberos log.  |
         /var/log/Bigdata/oldapserver  |
         OMS LDAP log.  |
         /var/log/Bigdata/metric_agent  |
         MetricAgent run log.  |
         /var/log/Bigdata/omm  |
         oms: complex event processing log, alarm service log, HA log, authentication and authorization management log, and monitoring service run log of the omm server. oma: installation log and run log of the omm agent. core: dump log generated when the omm agent and the HA process are suspended.  |
         /var/log/Bigdata/spark2x  |
         Spark2x log.  |
         /var/log/Bigdata/sudo  |
         Log generated when the sudo command is executed by user omm.  |
         /var/log/Bigdata/timestamp  |
         Time synchronization management log.  |
         /var/log/Bigdata/tomcat  |
         Tomcat log.  |
         /var/log/Bigdata/watchdog  |
         Watchdog log.  |
         /var/log/Bigdata/yarn  |
         YARN log.  |
         /var/log/Bigdata/zookeeper  |
         ZooKeeper log.  |
         /var/log/Bigdata/oozie  |
         Oozie log.  |
         /var/log/Bigdata/kafka  |
         Kafka log.  |
         /var/log/Bigdata/storm  |
         Storm log.  |
         /var/log/Bigdata/iotdb  |
         IoTDB log.  |
         /var/log/Bigdata/cdl  |
         CDL log.  |
         /var/log/Bigdata/upgrade  |
         OMS upgrade log.  |
         /var/log/Bigdata/update-service  |
         Upgrade service log.  |
         /var/log/Bigdata/patch  |
         Patch log.  |
Run logs
Table 3 describes the running information recorded in run logs.
         Run Log  |
         Description  |
         Installation preparation log  |
         Records information about preparations for the installation, such as the detection, configuration, and feedback operation information.  |
         Process startup log  |
         Records information about the commands executed during the process startup.  |
         Process startup exception log  |
         Records information about exceptions during process startup, such as dependent service errors and insufficient resources.  |
         Process run log  |
         Records information about the process running information and debugging information, such as function entries and exits as well as cross-module interface messages.  |
         Process running exception log  |
         Records errors that cause process running errors, for example, the empty input objects or encoding or decoding failure.  |
         Process running environment log  |
         Records information about the process running environment, such as resource status and environment variables.  |
         Script logs  |
         Records information about the script execution process.  |
         Resource reclamation log  |
         Records information about the resource reclaiming process.  |
         Uninstallation clearing logs  |
         Records information about operations performed during service uninstallation, such as directory deletion and execution time  |
Audit logs
Audit information recorded in audit logs includes FusionInsight Manager audit information and component audit information.
         Operation Type  |
         Operation  |
         User management  |
         Creating a user Modifying a user Deleting a user Creating a user group Modifying a user group Deleting a user group Adding a role Modifying a role Deleting a role Changing a password policy Changing a password Resetting a password User login User logout Unlocking the screen Downloading the authentication credential Unauthorized operation Unlocking a user account Locking a user account Locking the screen Exporting user information Exporting a user group Exporting a role  |
         Cluster  |
         Starting a cluster Stopping a cluster Restarting a cluster Performing a rolling restart of a cluster Restarting all expired instances Saving configurations Synchronizing cluster configurations Customizing cluster monitoring indicators Configuring monitoring dumping Saving monitoring thresholds Downloading a client configuration file Configuring the northbound Syslog interface Configuring the northbound SNMP API Clearing alarm through SNMP Adding a trap target through SNMP Deleting a trap target through SNMP Checking alarms through SNMP Synchronizing alarms through SNMP Creating a threshold template Deleting a threshold template Applying a threshold template Saving cluster monitoring configuration data Exporting configuration data Importing cluster configuration data Exporting an installation template Modifying a threshold template Canceling the application of a threshold template Masking alarms Sending an alarm Changing the OMS database password Resetting the component database password Restarting OMM and Controller Starting the health check of a cluster Importing a certificate file Configuring SSO information Deleting historical health check reports Modifying cluster attributes Running maintenance commands in synchronous mode Running maintenance commands in asynchronous mode Customizing report monitoring indicators Exporting report monitoring data Running a command using SNMP in asynchronous mode Restarting the Web service Customizing monitoring indicators for static resource pools Exporting monitoring data of a static resource pool Customizing dashboard monitoring metrics Stopping a task Restoring configurations Modifying domain and mutual trust configurations Modifying system parameters Making a cluster enter the maintenance mode Making a cluster exit the maintenance mode Making OMS enter the maintenance mode Making OMS exit the maintenance mode Exiting the maintenance mode in batches Modifying OMS configurations Enabling threshold alarms Synchronizing all cluster configurations  |
         Service  |
         Starting a service Stopping a service Synchronizing service configurations Refreshing a service queue Customizing service monitoring indicators Restarting a service Performing a rolling restart of a service Exporting service monitoring data Importing service configuration data Starting the health check of a service Configuring the service Uploading a configuration file Downloading a configuration file Synchronizing instance configurations Commissioning an instance Decommissioning an instance Starting an instance Stopping an instance Customizing instance monitoring indicators Restarting an instance Performing a rolling restart of an instance Exporting instance monitoring data Importing instance configuration data Creating an instance group Modifying an instance group Deleting an instance group Moving an instance to another instance group Making a service enter the maintenance mode Making a service exit the maintenance mode Changing the display name of a service Modifying service association Downloading monitoring data Masking alarms Unmasking alarms Exporting report data of a service Adding custom parameters for a report Modifying custom parameters of a report Deleting custom parameters of a report Switching over controller nodes Adding a mount table Modifying a mount table  |
         Host  |
         Setting a node rack Starting all roles Stopping all roles Isolating a host Canceling host isolation Customizing host monitoring indicators Exporting host monitoring data Making a host enter the maintenance mode Making a host exit the maintenance mode Exporting basic host information Exporting host distribution report data Exporting host trend report data Exporting host cluster report data Exporting service report data Customizing host cluster monitoring metrics Customizing host trend monitoring metrics  |
         Alarm  |
         Exporting alarms Clearing alarms Exporting events Clearing alarms in batches  |
         Log collection  |
         Collecting log files Downloading log files Collecting service stack information Collecting instance stack information Preparing service stack information Preparing instance stack information Clearing service stack information Clearing instance stack information  |
         Audit logs  |
         Modifying audit dump configurations Exporting audit logs  |
         Backup and restoration  |
         Creating a backup task Executing a backup task Executing backup tasks in batches Stopping a backup task Deleting a backup task Modifying a backup task Locking a backup task Unlocking a backup task Creating a restoration task Executing a backup restoration task Stopping a restoration task Retrying a restoration task Deleting a restoration task  |
         Multi-tenant management  |
         Saving the static configuration Creating a tenant Deleting a tenant Associating a service with a tenant Deleting a service from a tenant Configuring resources Creating resources Deleting resources Adding a resource pool Modifying a resource pool Deleting a resource pool Restoring tenant data Modifying a tenant's global configurations Modifying queue configurations for a capacity scheduler Modifying queue configurations for a super scheduler Modifying resource distribution for a capacity scheduler Clearing resource distribution for a capacity scheduler Modifying resource distribution for a super scheduler Clearing resource distribution for a super scheduler Adding a resource catalog Modifying a resource catalog Deleting a resource catalog Customizing tenant monitoring metrics  |
         Health check  |
         Starting health check for a cluster Starting health check for a service Starting health check for a host Starting health check for OMS Starting health check for a system Updating health check configurations Exporting health check reports Exporting cluster health check results Exporting service health check results Exporting host health check results Deleting historical health check reports Exporting historical health check reports Downloading health check reports  |
         Audit Log  |
         Operation Type  |
         Operation  |
         CDL audit log  |
         Service operation  |
         Creating a link Deleting a link Creating a job Starting a job Deleting a job  |
         IoTDB audit log  |
         Maintenance management  |
         Granting permissions Revoking permissions Recording authentication and login information  |
         Service operation  |
         Deleting a time series, partition, function, or index Modifying a time series  |
         ClickHouse audit log  |
         Service operation  |
         Creating a database or table Inserting, deleting, querying, and migrating data  |
         DBService audit log  |
         Performing backup restoration operations  |
         HBase audit log  |
         Data definition language (DDL) statement  |
         Creating a table Deleting a table Modifying a table Adding a column family Modifying a column family Deleting a column family Enabling a table Disabling a table Modify the user information Changing a password User login  |
         Data manipulation language (DML) statement  |
         Putting data (to the hbase:meta, _ctmeta_, and hbase:acl tables) Deleting data (from the hbase:meta, _ctmeta_, and hbase:acl tables) Checking and putting data (to the hbase:meta, _ctmeta_, and hbase:acl tables) Checking and deleting data (from the hbase:meta, _ctmeta_, and hbase:acl tables)  |
         Permission control  |
         Assigning permissions to a user Canceling permission assigning  |
         HDFS audit log  |
         Permissions management  |
         Managing permissions on files or folders Managing permissions on owner information files or folders  |
         File operation  |
         Creating a folder Creating a file Opening a file Appending file content Changing a file name Deleting a file or folder Setting time property of a file Setting the number of file copies Merging files Checking the file system File links  |
         Hive audit logs  |
         Metadata operation  |
         Defining metadata, such as creating databases and tables Deleting metadata, such as deleting databases and tables Modifying metadata, such as adding columns and renaming tables Importing and exporting metadata  |
         Data maintenance  |
         Loading data to a table Inserting data into a table  |
         Creating or deleting roles Granting/Reclaiming roles Granting/Reclaiming permissions  |
         Hue audit log  |
         Service startup  |
         Starting Hue  |
         User operation  |
         User login User logout  |
         Task operation  |
         Creating a job Modifying a job Deleting a job Submitting a task Saving a task Updating the status of a task  |
         KrbServer audit log  |
         Changing the password of a Kerberos account Adding a Kerberos account Deleting a Kerberos account Authenticating a user  |
         LdapServer audit log  |
         Adding an operating system user Adding a user group Adding a user to user group Deleting a user Deleting a group  |
         Loader audit log  |
         Security management  |
         User login  |
         Metadata management  |
         Querying connector information Querying a framework Querying step information  |
         Managing data source connections  |
         Querying a data source connection Adding a data source connection Updating a data source connection Deleting a data source connection Activating a data source connection Disabling a data source connection  |
         Job management  |
         Querying a job Creating a Job Updating a Job Deleting a job Activating a job Disabling a job Querying all execution records of a job Querying the latest execution record of a job Submitting a job Stopping a job  |
         MapReduce audit log  |
         Application running  |
         Starting a Container request Stopping a Container request After Container request is completed, the status of the request is displayed as succeeded. After Container request is completed, the status of the request is displayed as failed. After Container request is completed, the status of the request is displayed as suspended. Submitting a task Ending a task  |
         Oozie audit log  |
         Task management  |
         Submitting a task Starting a task Killing a task Suspending a task Resuming a task Re-running a task  |
         Spark audit log  |
         Data maintenance  |
         Storm audit log  |
         Nimbus  |
         Submitting a topology Stopping a topology Reallocating a topology Deactivating a topology Activating a topology  |
         UI  |
         YARN audit log  |
         Job submission  |
         Submitting a job to a queue  |
         ZooKeeper audit log  |
         Setting the access permission to Znode  |
         Znode operation  |
         Creating a Znode Deleting a Znode Configuring Znode data  |
         HetuEngine audit log  |
         Job management  |
         Adding an external data source Deleting an external data source Modifying an external data source Creating a compute instance Starting a compute instance Stopping a compute instance Deleting a compute instance Querying a compute instance Modifying compute instance configurations  |
MRS audit logs are stored in the database. You can view and export audit logs on the Audit page.
The following table lists the directories to store component audit logs. Audit log files of some components are stored in /var/log/Bigdata/audit, such as HDFS, HBase, MapReduce, Hive, Hue, YARN, Storm, and ZooKeeper. The component audit logs are automatically compressed and backed up to /var/log/Bigdata/audit/bk at 03:00 every day. A maximum of latest 90 compressed backup files are retained, and the backup time cannot be changed.
Audit log files of other components are stored in the component log directory.
         Component  |
         Audit Log Directory  |
         DBService  |
         /var/log/Bigdata/audit/dbservice/dbservice_audit.log  |
         HBase  |
         /var/log/Bigdata/audit/hbase/hm/hbase-audit-hmaster.log /var/log/Bigdata/audit/hbase/hm/hbase-ranger-audit-hmaster.log /var/log/Bigdata/audit/hbase/rs/hbase-audit-regionserver.log /var/log/Bigdata/audit/hbase/rs/hbase-ranger-audit-regionserver.log /var/log/Bigdata/audit/hbase/rt/hbase-audit-restserver.log /var/log/Bigdata/audit/hbase/ts/hbase-audit-thriftserver.log  |
         HDFS  |
         /var/log/Bigdata/audit/hdfs/nn/hdfs-audit-namenode.log /var/log/Bigdata/audit/hdfs/nn/ranger-plugin-audit.log /var/log/Bigdata/audit/hdfs/dn/hdfs-audit-datanode.log /var/log/Bigdata/audit/hdfs/jn/hdfs-audit-journalnode.log /var/log/Bigdata/audit/hdfs/zkfc/hdfs-audit-zkfc.log /var/log/Bigdata/audit/hdfs/httpfs/hdfs-audit-httpfs.log /var/log/Bigdata/audit/hdfs/router/hdfs-audit-router.log  |
         HetuEngine  |
         /var/log/Bigdata/audit/hetuengine/hsbroker/hsbroker-audit.log.0 /var/log/Bigdata/audit/hetuengine/hsconsole/hsconsole-audit.log.0 /var/log/Bigdata/audit/hetuengine/hsfabric/hsfabric-audit.log.0 hdfs://hacluster/hetuserverhistory/Tenant name/coordinator/application_ID/container_ID/yyyyMMdd/hetuserver-engine-audit.log hdfs://hacluster/hetuserverhistory/Tenant name/coordinator or worker/application_ID/container_ID/yyyyMMdd/server.log  |
         Hive  |
         /var/log/Bigdata/audit/hive/hiveserver/hive-audit.log /var/log/Bigdata/audit/hive/hiveserver/hive-rangeraudit.log /var/log/Bigdata/audit/hive/metastore/metastore-audit.log /var/log/Bigdata/audit/hive/webhcat/webhcat-audit.log  |
         Hue  |
         /var/log/Bigdata/audit/hue/hue-audits.log  |
         Kafka  |
         /var/log/Bigdata/audit/kafka/audit.log  |
         Loader  |
         /var/log/Bigdata/loader/audit/default.audit  |
         CDL  |
         /var/log/Bigdata/audit/cdl/service/cdl-audit.log  |
         MapReduce  |
         /var/log/Bigdata/audit/mapreduce/jobhistory/mapred-audit-jobhistory.log  |
         Oozie  |
         /var/log/Bigdata/audit/oozie/oozie-audit.log  |
         Spark2x  |
         /var/log/Bigdata/audit/spark2x/jdbcserver/jdbcserver-audit.log /var/log/Bigdata/audit/spark2x/jdbcserver/ranger-audit.log /var/log/Bigdata/audit/spark2x/jobhistory/jobhistory-audit.log  |
         Storm  |
         /var/log/Bigdata/audit/storm/logviewer/audit.log /var/log/Bigdata/audit/storm/nimbus/audit.log /var/log/Bigdata/audit/storm/supervisor/audit.log /var/log/Bigdata/audit/storm/ui/audit.log  |
         Yarn  |
         /var/log/Bigdata/audit/yarn/rm/yarn-audit-resourcemanager.log /var/log/Bigdata/audit/yarn/rm/ranger-plugin-audit.log /var/log/Bigdata/audit/yarn/nm/yarn-audit-nodemanager.log  |
         ZooKeeper  |
         /var/log/Bigdata/audit/zookeeper/quorumpeer/zk-audit-quorumpeer.log  |
         IoTDB  |
         /var/log/Bigdata/audit/iotdb/iotdbserver/log_audit.log  |
Manager Logs
Log path: Manager log files are stored in /var/log/Bigdata/Manager by default.
- ControllerService: /var/log/Bigdata/controller/ (OMS installation and run logs)
 - Httpd: /var/log/Bigdata/httpd (httpd installation and run logs)
 - logman: /var/log/Bigdata/logman (log packaging tool logs)
 - NodeAgent: /var/log/Bigdata/nodeagent (NodeAgent installation and run logs)
 - okerberos: /var/log/Bigdata/okerberos (okerberos installation and run logs)
 - oldapserver: /var/log/Bigdata/oldapserver (oldapserver installation and run logs)
 - MetricAgent: /var/log/Bigdata/metric_agent (MetricAgent run logs)
 - omm: /var/log/Bigdata/omm (omm installation and run logs)
 - timestamp: /var/log/Bigdata/timestamp (NodeAgent startup time logs)
 - tomcat: /var/log/Bigdata/tomcat (Web process logs)
 - Watchdog: /var/log/Bigdata/watchdog (watchdog logs)
 - Upgrade: /var/log/Bigdata/upgrade (OMS upgrade logs)
 - UpdateService: /var/log/Bigdata/update-service (upgrade service logs)
 - Sudo: /var/log/Bigdata/sudo (sudo script execution logs)
 - OS: /var/log/message file (OS system logs)
 - OS Performance: /var/log/osperf (OS performance statistics logs)
 - OS Statistics: /var/log/osinfo/statistics (OS parameter configuration logs)
Log archiving rules:
Manager logs are automatically compressed and archived. When a log file exceeds 10 MB in size, the file is automatically compressed by default. The file is named as follows after compression: <Original log name>-<yyyy-mm-dd_hh-mm-ss>.[ID].log.zip. A maximum of 20 latest compressed files are reserved.
         Type  |
         Log File Name  |
         Description  |
         Controller run log  |
         controller.log  |
         Log file that records component installation, upgrade, configuration, monitoring, alarm reporting, and routine O&M operations  |
         controller_client.log  |
         Run log file of REST APIs  |
         acs.log  |
         ACS run log file  |
         acs_spnego.log  |
         spnego user log in ACS  |
         aos.log  |
         AOS run log  |
         plugin.log  |
         AOS plug-in log  |
         backupplugin.log  |
         Log file that records backup and restoration operations  |
         controller_config.log  |
         Configuration run log  |
         controller_nodesetup.log  |
         Controller loading task log  |
         controller_root.log  |
         System log of the Controller process  |
         controller_trace.log  |
         Log that records the remote procedure call (RPC) communication between Controller and NodeAgent  |
         controller_monitor.log  |
         Monitoring log  |
         controller_fsm.log  |
         State machine log  |
         controller_alarm.log  |
         Controller alarm log  |
         controller_backup.log  |
         Controller backup and restoration log  |
         install.log, restore_package.log, installPack.log, distributeAdapterFiles.log, and install_os_optimization.log  |
         OMS installation log  |
         oms_ctl.log  |
         OMS startup and stop log  |
         preInstall_client.log  |
         Preprocessing log file before client installation  |
         installntp.log  |
         NTP installation log  |
         modify_manager_param.log  |
         Manager parameter modification log  |
         backup.log  |
         OMS backup script run log  |
         supressionAlarm.log  |
         Alarm script run log  |
         om.log  |
         OM certificate generation log  |
         backupplugin_ctl.log  |
         Startup log of the backup and restoration plug-in process  |
         getLogs.log  |
         Run log of the collection log script  |
         backupAuditLogs.log  |
         Run log of the audit log backup script  |
         certStatus.log  |
         Log that records regular certificate checks  |
         distribute.log  |
         Certificate distribution log  |
         ficertgenetrate.log  |
         Certificate replacement logs, including logs of level-2 certificates, CAS certificates, and httpd certificates  |
         genPwFile.log  |
         Log that records the generation of certificate password files  |
         modifyproxyconf.log  |
         Log that records the modification of the HTTPD proxy configuration  |
         importTar.log  |
         Log that records the process of importing certificates into the trust library  |
         Httpd  |
         install.log  |
         Httpd installation log  |
         access_log, error_log  |
         Httpd run log  |
         logman  |
         logman.log  |
         Log packaging tool log  |
         NodeAgent  |
         install.log, install_os_optimization.log  |
         NodeAgent installation log  |
         installntp.log  |
         start_ntp.log  |
         NTP startup log  |
         ntpChecker.log  |
         NTP check log  |
         ntpMonitor.log  |
         NTP monitoring log  |
         heartbeat_trace.log  |
         Log that records heartbeats between NodeAgent and Controller  |
         alarm.log  |
         Alarm log  |
         monitor.log  |
         Monitoring log  |
         nodeagent_ctl.log, start-agent.log  |
         NodeAgent startup log  |
         agent.log  |
         NodeAgent run log  |
         cert.log  |
         Certificate log  |
         agentplugin.log  |
         Agent plug-in running status monitoring log  |
         omaplugin.log  |
         OMA plug-in run log  |
         diskhealth.log  |
         Disk health check log  |
         updateHostFile.log  |
         Host list update log  |
         collectLog.log  |
         Run log of the node log collection script  |
         host_metric_collect.log  |
         Host index collection run log  |
         checkfileconfig.log  |
         Run log file of file permission check  |
         entropycheck.log  |
         Entropy check run log  |
         timer.log  |
         Log of periodic node scheduling  |
         pluginmonitor.log  |
         Component monitoring plug-in log  |
         agent_alarm_py.log  |
         Log that records alarms upon insufficient NodeAgent file permission  |
         okerberos  |
         addRealm.log and modifyKerberosRealm.log  |
         Realm handover log  |
         checkservice_detail.log  |
         Okerberos health check log  |
         genKeytab.log  |
         keytab generation log  |
         KerberosAdmin_genConfigDetail.log  |
         Run log file of kadmin.conf generated during start of the kadmin process  |
         KerberosServer_genConfigDetail.log  |
         Run log file of krb5kdc.conf generated during start of the krb5kdc process  |
         oms-kadmind.log  |
         Run log of the kadmin process  |
         oms_kerberos_install.log and postinstall_detail.log  |
         Okerberos installation log  |
         oms-krb5kdc.log  |
         Run log of the krbkdc process  |
         start_detail.log  |
         Okerberos startup log  |
         realmDataConfigProcess.log  |
         Log file that records the rollback upon a realm handover failure  |
         stop_detail.log  |
         Okerberos stop log  |
         oldapserver  |
         ldapserver_backup.log  |
         Oldapserver backup log  |
         ldapserver_chk_service.log  |
         Oldapserver health check log  |
         ldapserver_install.log  |
         Oldapserver installation log  |
         ldapserver_start.log  |
         Oldapserver startup log  |
         ldapserver_status.log  |
         Log that records the status of the Oldapserver process  |
         ldapserver_stop.log  |
         Oldapserver stop log  |
         ldapserver_wrap.log  |
         Oldapserver service management log  |
         ldapserver_uninstall.log  |
         Oldapserver uninstallation log  |
         restart_service.log  |
         Oldapserver restart log  |
         ldapserver_unlockUser.log  |
         Log file that records information about unlocking LDAP users and managing accounts  |
         metric_agent  |
         gc.log  |
         MetricAgent JVM GC log file  |
         metric_agent.log  |
         Run log file of MetricAgent  |
         metric_agent_qps.log  |
         Log file that records MetricAgent Internal queue length and QPS information  |
         metric_agent_root.log  |
         All run log files of MetricAgent  |
         start.log  |
         Log file that records information about the MetricAgent startup and stop  |
         omm  |
         omsconfig.log  |
         OMS configuration log  |
         check_oms_heartbeat.log  |
         OMS heartbeat log  |
         monitor.log  |
         OMS monitoring log  |
         ha_monitor.log  |
         HA_Monitor operation log  |
         ha.log  |
         HA operation log  |
         fms.log  |
         Alarm log  |
         fms_ha.log  |
         HA alarm monitoring log  |
         fms_script.log  |
         Alarm control log  |
         config.log  |
         Alarm configuration log  |
         iam.log  |
         IAM log  |
         iam_script.log  |
         IAM control log  |
         iam_ha.log  |
         IAM HA monitoring log  |
         config.log  |
         IAM configuration log  |
         operatelog.log  |
         IAM operation log  |
         heartbeatcheck_ha.log  |
         OMS heartbeat HA monitoring log  |
         install_oms.log  |
         pms_ha.log  |
         HA monitoring log  |
         pms_script.log  |
         Monitoring control log  |
         config.log  |
         Monitoring configuration log  |
         plugin.log  |
         Monitoring plug-in run log  |
         pms.log  |
         Monitoring log  |
         ha.log  |
         HA run log  |
         cep_ha.log  |
         CEP HA monitoring log  |
         cep_script.log  |
         CEP control log  |
         cep.log  |
         CEP log  |
         config.log  |
         CEP configuration log  |
         omm_gaussdba.log  |
         GaussDB HA monitoring log  |
         gaussdb-<SERIAL>.log  |
         GaussDB run log  |
         gs_ctl-<DATE>.log  |
         GaussDB control log archive log  |
         gs_ctl-current.log  |
         GaussDB control log  |
         gs_guc-current.log  |
         GaussDB operation log  |
         encrypt.log  |
         Omm encryption log  |
         omm_agent_ctl.log  |
         OMA control log  |
         oma_monitor.log  |
         OMA monitoring log  |
         install_oma.log  |
         OMA installation log  |
         config_oma.log  |
         OMA configuration log  |
         omm_agent.log  |
         OMA run log  |
         acs.log  |
         ACS resource log  |
         aos.log  |
         AOS resource log  |
         controller.log  |
         Controller resource log  |
         floatip.log  |
         Floating IP address resource log  |
         ha_ntp.log  |
         NTP resource log  |
         httpd.log  |
         Httpd resource log  |
         okerberos.log  |
         Okerberos resource log  |
         oldap.log  |
         OLdap resource log  |
         tomcat.log  |
         Tomcat resource log  |
         send_alarm.log  |
         Run log of the HA alarm sending script of the management node  |
         feed_watchdog.log  |
         feed_watchdog resource log  |
         timestamp  |
         restart_stamp  |
         NodeAgent start time log  |
         tomcat  |
         cas.log and localhost_access_cas_log.log  |
         CAS run log  |
         catalina.log, catalina.out, host-manager.log, localhost.log, and manager.log  |
         Tomcat run log  |
         localhost_access_web_log.log  |
         Log that records the access to REST APIs of FusionInsight Manager  |
         web.log  |
         Run log of the web process  |
         northbound_ftp_sftp.log and snmp.log  |
         Northbound log  |
         perfStats.log  |
         Performance statistics log file  |
         watchdog  |
         watchdog.log and feed_watchdog.log  |
         watchdog run log  |
         update-service  |
         omm_upd_server.log  |
         UPDServer run log file  |
         omm_upd_agent.log  |
         UPDAgent run log file  |
         update-manager.log  |
         UPDManager run log file  |
         install.log  |
         Installation log file of the upgrade service  |
         uninstall.log  |
         Uninstallation log file of the upgrade service  |
         catalina.<Time>.log, catalina.out, host-manager.<Time>.log, localhost.<Time>.log, manager.<Time>.log, manager_access_log.<Time>.txt, web_service_access_log.<Time>.txt, catalina.log, gc-update-service.log.0.current, update-manager.controller, update-web-service.controller, update-web-service.log, commit_rm_distributed.log, commit_rm_upload_package.log, common_omagent_operator.log, forbid_monitor.log, initialize_package_atoms.log, initialize_unzip_pack.log, omm-upd.log, register_patch_pack.log, resume_monitor.logrollback_clear_patch.log, unregister_patch_pack.log, update-rcommupd.log, update-rcupdatemanager.log, and update-service.log  |
         Run log file of the upgrade service  |
         upgrade  |
         upgrade.log_<Time>  |
         OMS upgrade log file  |
         rollback.log_<Time>  |
         OMS rollback log file  |
         sudo  |
         sudo.log  |
         Sudo script execution log  |
Log levels
          Level  |
          Description  |
          FATAL  |
          Logs of this level record fatal error information about the current event handling that may result in a system crash.  |
          ERROR  |
          Logs of this level record error information about the current event handling that indicates a system malfunction.  |
          WARN  |
          Logs of this level record abnormal information about the current event handling that does not cause the system to malfunction.  |
          INFO  |
          Logs of this level record normal status information about the system and events.  |
          DEBUG  |
          Logs of this level record system and its debugging information.  |
Log format
Manager log formats are as follows:
         Type  |
         Component  |
         Format  |
         Example  |
         Controller, HTTPd, Logman, NodeAgent, oKerberos, oldapserver, OMM, Tomcat, and upgrade  |
         <yyyy-MM-dd HH:mm:ss,SSS>|<Log level>|<Name of the thread that generates the log>|<Message in the log>|<Location where the log event occurs>  |
         2020-06-30 00:37:09,067 INFO [pool-1-thread-1] Completed Discovering Node. com.xxx.hadoop.om.controller.tasks.nodesetup.DiscoverNodeTask.execute(DiscoverNodeTask.java:299)  |
