Updated on 2025-08-09 GMT+08:00
Viewing MRS Cluster Events
Alarms and events are important mechanisms for ensuring the stability, reliability, and performance of MRS clusters.
Events capture status changes and system operations that occur during system running. They are used to audit or trace system behavior, including component instance startup, shutdown, and active/standby switchover in an MRS cluster, and node-level changes such as slow disk isolation.
For details about common events in an MRS cluster, see Table 2.
Generally, you do not need to manually handle events. However, for events of the major or higher severity, you need to check whether the related components are running properly and whether related alarms exist. For details, see Viewing Alarms of an MRS Cluster.
Video Tutorial
This tutorial introduces how to view cluster alarms and events and configure an alarm threshold.
The UI may vary depending on the version. This tutorial is for reference only.
Viewing Cluster Events on the Management Console
  1. Log in to the MRS console.
  2. On the Active Clusters page, select a running cluster and click its name to switch to the cluster details page.
  3. On the Dashboard page, click Synchronize next to IAM User Sync to synchronize IAM users.
  4. Choose Alarms > Events. On the displayed page, view event information about the cluster.
    Figure 1 Viewing MRS cluster events
    In the event list, you can check events generated in the current cluster, including the event name, severity, and generation time.
    You can click the arrow before an event name to expand the event details.
  5. To export event information, click Export, select the file format, and export the event file to a local directory.
Viewing Cluster Events on Manager
  1. Log in to FusionInsight Manager of the MRS cluster.
    For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
  2. Choose O&M > Alarm > Events. On the displayed Events page, you can view information about all events in the cluster, including the event name, ID, severity, generation time, source, object, and location. By default, the latest 10 events are displayed on each page.
    • For clusters of MRS 2.x or earlier, choose Alarms > Events.
    • Click Export All to export all event details.
    • You can click to manually refresh the current page and click to select the columns that will display.
    • You can filter events by object or cluster.
    • You can click Advanced Search to search for events by event ID, name, severity, start time, or end time.
    You can click on the left of an event to view detailed event parameters. Table 1 describes the parameters.
    Table 1 Event parameters
    Event ID
    Event ID.
    Event Name
    Event name.
    Event Severity
    Event severity. The options are Critical, Major, Minor, and Suggestion.
    Generated
    Time when an event is generated.
    Object
    Possible cause of an event.
    Serial Number
    Number of events generated by the system.
    Location
    Detailed information for locating the event, which includes the following:
    • Source: cluster for which the event is generated.
    • ServiceName: service for which the event is generated.
    • RoleName: role for which the event is generated.
    • HostName: host for which the event is generated.
    Additional Info
    Error information.
    Event Cause
    Source
    Cluster name.
Common Events of an MRS Cluster
Table 2 MRS Cluster Event List
Event ID
Component
Event Name
Event Severity
12019
Manager
Stop Service
Warning
12021
Manager
Stop RoleInstance
Warning
12023
Manager
Delete Node
Warning
12024
Manager
Restart Service
Warning
12025
Manager
Restart RoleInstance
Warning
12026
Manager
Manager Switchover
Minor
12065
Manager
Restart Process
Minor
12070
Manager
Job Running Succeeded
Warning
12071
Manager
Job Running Failed
Warning
12072
Manager
Job Killed
Warning
12082
Manager
Automatic Disk Isolation Stopped
Major
12083
Manager
Slow Disk Isolated
Major
12084
Manager
Disk Data Balancing Failed
Major
12085
Manager
Disk Recovered
Major
12086
Manager
Restart Agent
Warning
12087
Manager
Cancel Disk Isolation Failed
Major
12088
Manager
Disk Isolation Cancelled
Major
12089
Manager
Major
12090
Manager
Disk Node Isolated
Major
12091
Manager
Disk Node Isolation Cancelled
Major
12092
Manager
Disk Node Instance Started
Major
12093
Manager
Disk Node Isolation Failed
Major
12094
Manager
Disk Node Instance Start Failed
Major
12095
Manager
Cancel Disk Node Isolation Failed
Major
12096
Manager
Disk Node Recovered
Major
12097
Manager
Abnormal Connection to OMS Node Network
Major
12152
Manager
Start Periodic Replication
Minor
12153
Manager
Periodic Replication Completed
Minor
12154
Manager
Start Streaming Replication
Minor
12155
Manager
Restart Streaming Replication
Minor
12156
Manager
Stop Streaming Replication
Minor
12157
Manager
Skip Periodic Synchronization
Minor
12158
Manager
Host Information Lost
Minor
14005
HDFS
NameNode Switchover
Minor
14028
HDFS
HDFS Disk Balance
Minor
14029
HDFS
Active NameNode In Safe Mode and New FSimage Generated
Minor
17001
Oozie
Oozie Workflow Execution Failed
Major
17002
Oozie
Oozie Scheduled Job Execution Failed
Major
18001
Yarn
ResourceManager Switchover
Minor
18004
Mapreduce
JobHistoryServer Switchover
Minor
18029
Yarn
Jobs Occupied Too Many Storage Resources
Minor
19001
HBase
HMaster Failover
Minor
19027
HBase
RegionServer-level Hotspot Transfer
Major
19028
HBase
Hotspot Region Splitting
Major
19029
HBase
Hotspot Region Isolation
Major
20003
Hue
Hue Failover
Minor
23002
Loader
Loader Failover
Major
24002
Flume
Flume Channel Overflow
Major
25001
LdapServer
LdapServer Failover
Minor
27000
DBService
DBServer Switchover
Minor
38003
Kafka
Topic Data Storage Period Changed
Warning
43014
Spark
Spark Data Skew
Warning
43015
Spark
Spark SQl Ultra-Large Query Results
Warning
43016
Spark
Spark SQL Timeout
Warning
43024
Spark
Start JDBCServer
Warning
43025
Spark
Stop JDBCServer
Warning
43026
Spark
ZooKeeper Connection Succeeded
Warning
43027
Spark
Zookeeper Connection Failed
Warning
43601
GraphBase
GraphBase Failover
Minor
45002
HetuEngine
QAS Failover
Minor
45597
IoTDB
Region Replica Supplementation
Warning
45651
Flink
FlinkServer Failover
Minor
Helpful Links
