Common Ports for MRS Cluster Services
This section describes the common ports of each component in an MRS cluster. If the cluster version type is LTS during cluster creation in custom config mode as described in Buying a Custom MRS Cluster, you can determine whether to keep the default ports of the components consistent with those of the open-source components.
- If Component Port is set to Open source or Version Type is set to Normal, find the default component ports in the Default Open Source Port column of the following table.
- If Component Port is set to Custom, find the default component ports in the Default Custom Port column of the following table.
- If there is only the Default Port column, the open-source ports of the component are the same as the default custom ports.
- The value range of each component port is a recommended value, defined by the product. However, the system does not enforce strict limitations on port ranges.
Common HBase Ports
The protocol type of all ports in the table is TCP.
| Parameter | Default Open Source Port | Default Custom Port | Port Description |
| hbase.master.port | 16000 | 21300 | HMaster RPC port, which is used to connect the HBase client to HMaster.
| hbase.master.info.port | 16010 | 21301 | HMaster HTTPS port, which is used by the remote web client to connect to the HMaster UI.
| hbase.regionserver.port | 16020 | 21302 | RegionServer (RS) RPC port, which is used to connect the HBase client to RegionServer.
| hbase.regionserver.info.port | 16030 | 21303 | RegionServer HTTPS port, which is used by the remote web client to connect to the RegionServer UI.
| hbase.thrift.info.port | 9095 | 21304 | Thrift server listening port of ThriftServer. This port is used by client connections.
| hbase.regionserver.thrift.port | 9090 | 21305 | Thrift server listening port of RegionServer. This port is used by clients to connect to RegionServer.
| hbase.rest.info.port | 8085 | 21308 | Port of the native web UI of RegionServer RESTServer. |
| - | 21309 | 21309 | REST port of RegionServer RESTServer. |
Common HDFS Ports
| dfs.namenode.rpc.port |
| 25000 | NameNode RPC port, which is used for communication between the HDFS client and NameNode and connections between different DataNodes.
| dfs.namenode.http.port | 9870 | 25002 | HTTP access port of NameNode. This port is used for the point-to-point NameNode checkpoint operations and for the remote web client to connect to the NameNode UI.
| dfs.namenode.https.port | 9871 | 25003 | HTTPS access port of NameNode. This port is used for the point-to-point NameNode checkpoint operations and for the remote web client to connect to the NameNode UI.
| dfs.datanode.ipc.port | 9867 | 25008 | Port for communication between DataNode processes. This port is used by clients to connect to DataNodes to perform RPC operations.
| dfs.datanode.port | 9866 | 25009 | DataNode data transmission port. This port is used by the HDFS client to transfer data from or to DataNode.
| dfs.datanode.http.port | 9864 | 25010 | DataNode HTTP port, which is used to remotely connect to the DataNode UI through a web client in secure mode.
| dfs.datanode.https.port | 9865 | 25011 | DataNode HTTPS port, which is used to remotely connect to the DataNode UI through a web client in secure mode.
| dfs.JournalNode.rpc.port | 8485 | 25012 | JournalNode RPC port, which is used for client communication.
| dfs.journalnode.http.port | 8480 | 25013 | JournalNode HTTP port, which is used to remotely connect to JournalNode through a web client in secure mode.
| dfs.journalnode.https.port | 8481 | 25014 | JournalNode HTTPS port, which is used to remotely connect to JournalNode through a web client in secure mode.
| httpfs.http.port | 14000 | 25018 | HttpFS HTTP server listening port, which is used to remotely connect to HttpFS through a REST API.
Common HetuEngine Ports
| server.port (HSBroker) | 29860 | 29860 | Specifies the port number that HSBroker listens to. |
| server.port (HSConsole) | 29880 | 29880 | Specifies the port number that HSConsole listens to. |
| server.port (HSFabric) | 29900 | 29900 | Specifies the port number that HSFabric listens to, which is used for cross-domain connections. |
| gateway.port | 29902 | 29902 | Specifies the port number that HSFabric listens to, which is used for JDBC connections. |
Common Hive Ports
| templeton.port | 9111 | 21055 | Port used for WebHCat to provide the REST service. This port is used for the communication between the WebHCat server and the WebHCat client.
| hive.server2.thrift.port | 10000 | 21066 | Port for HiveServer to provide Thrift services. This port is used for the communication between the HiveServer server and the HiveServer client.
| hive.metastore.port | 9083 | 21088 | Port for MetaStore to provide Thrift services. This port is used for communication between the Metastore client and Metastore, that is, communication between HiveServer and Metastore.
| hive.server2.webui.port | 10002 | - | Hive Web UI port, which is used to communicate with the Hive UI server using HTTPS/HTTP. |
Common Hue Ports
| HTTP_PORT | 8888 | 21200 | Port for Hue to provide HTTPS services This port is used to provide web services over HTTPS, which can be changed.
Common Kafka Ports
| port | 9092 | 21005 | Port for a broker to receive data and obtain services |
| ssl.port | 9093 | 21008 | SSL port used by a broker to receive data and obtain services |
| sasl.port | 21007 | 21007 | SASL security authentication port provided by a broker, which provides the secure Kafka service |
| sasl-ssl.port | 21009 | 21009 | Port used by a broker to provide encrypted service based on the SASL and SSL protocols |
Common Loader Ports
| Parameter | Default Port | Port Description |
| LOADER_HTTPS_PORT | 21351 | This port is used to provide REST APIs for configuration and running of Loader jobs.
Common Manager Ports
| Parameter | Default Port (Versions Earlier Than MRS 3.x) | Default Port (For MRS 3.x or Later) | Port Description |
| - | 8080 | - | Port provided by WebService for user access This port is used to access the web UI over HTTP.
| - | 28443 | 28443 | Port provided by WebService for user access This port is used to access the web UI over HTTPS.
| - | - | 20009 | CAS port This port is used for user login authentication.
| - | - | 20028 | Control port provided by the backup and restoration plug-in process. This port is used by the controller to send backup and restoration control commands. |
| - | - | 20029 | Port registered by the client with the OM server |
| - | - | 20015 | OMS database service port This port is used to provide database services.
| - | - | 20051 | DBService database service port This port is used to provide database services.
| - | - | 9022 | Port used to receive operation or query requests from the management plane and to forward the requests to the executor or manager for execution. |
Common MapReduce Ports
| mapreduce.jobhistory.webapp.port | 19888 | 26012 | Web HTTP port of the JobHistory server This port is used to view the web page of the JobHistory server. |
| mapreduce.jobhistory.port | 10020 | 26013 | Port of the JobHistory server This port is used for:
| mapreduce.jobhistory.webapp.https.port | 19890 | 26014 | Web HTTPS port of the JobHistory server This port is used to view the web page of the JobHistory server. |
Common Spark Ports
| hive.server2.thrift.port | 22550 | 22550 | JDBC thrift port This port is used for socket communication between the Spark 2.1.0 CLI/JDBC client and server. If hive.server2.thrift.port is used, an exception indicating that the port is occupied is reported.
| spark.ui.port | 4040 | 22950 | Web UI port of JDBC This port is used for HTTPS/HTTP communication between Web requests and the JDBC Server Web UI server. The system obtains the port based on the parameter settings and checks its validity. If the port is invalid, the system increases the port number by 1 each time for a maximum of 16 times until a valid port is obtained (the retry times can be configured using spark.port.maxRetries).
| spark.history.ui.port | 18080 | 22500 | JobHistory Web UI port This port is used for HTTPS/HTTP communication between web requests and the Spark 2.1.0 History Server. The system obtains the port based on the parameter settings and checks its validity. If the port is invalid, the system increases the port number by 1 each time for a maximum of 16 times until a valid port is obtained (the retry times can be configured using spark.port.maxRetries).
Common Storm Ports
| nimbus.thrift.port | 6627 | 29200 | Port for Nimbus to provide thrift services |
| supervisor.slots.ports | 6700/6701/6702/6703 | 29200–29499 | Port for receiving service requests that are forwarded from other servers |
| logviewer.https.port | 29248 | 29248 | Port for LogViewer to provide HTTPS services |
| ui.https.port | 29243 | 29243 | Port for the Storm UI to provide HTTPS services |
Common YARN Ports
| yarn.resourcemanager.webapp.port | 8088 | 26000 | Web HTTP port of the ResourceManager service |
| yarn.resourcemanager.webapp.https.port | 8090 | 26001 | Web HTTPS port of the ResourceManager service This port is used to access the Resource Manager web applications in security mode.
| yarn.nodemanager.webapp.port | 8042 | 26006 | NodeManager Web HTTP port |
| yarn.nodemanager.webapp.https.port | 8044 | 26010 | NodeManager Web HTTPS port This port is used to access the NodeManager web applications in security mode.
Common ZooKeeper Ports
| clientPort | 2181 | 24002 | ZooKeeper client port This port is used for communication between the ZooKeeper client and ZooKeeper server.
Common Kerberos Ports
The protocol type of all ports in the table is TCP and UDP.
| KADMIN_PORT | 21730 | Port for managing Kerberos users. |
| KPASSWD_PORT | 21731 | Port for changing the Kerberos password. |
| kdc_ports | 21732 | Kerberos server port. This port is used by components for Kerberos authentication. This port may be used when you configure mutual trust between clusters. |
Common OpenTSDB Ports
| tsd.network.port | 4242 | Web UI port of OpenTSDB This port is used for HTTPS/HTTP communication between web requests and the OpenTSDB UI server. |
Common Tez Ports
| tez.ui.port | 28888 | Web UI port of Tez |
Common KafkaManager Ports
| kafka_manager_port | 9099 | Web UI port of KafkaManager |
Common Presto Ports
| http-server.http.port | 7520 | HTTP port for Presto coordinator to provide services to external systems |
| http-server.https.port | 7521 | HTTPS port for Presto coordinator to provide services to external systems |
| http-server.http.port | 7530 | HTTP port for Presto worker to provide services to external systems |
| http-server.https.port | 7531 | HTTPS port for Presto worker to provide services to external systems |
Common Flink Ports
| jobmanager.web.port | 32261~32325 | Web UI port of Flink This port is used for HTTP/HTTPS communication between the client web requests and Flink server. |
Common ClickHouse Ports
The protocol type of the port in the table is TCP and HTTP.
| interserver_http_port | 9009 | 9009 | HTTP port for the communication between ClickHouse servers. |
| interserver_https_port | 9010 | 9010 | HTTPS port for the communication between ClickHouse servers. |
| http_port | 8123 | 8123 | Port for connecting to the ClickHouse server through HTTP. |
| https_port | 8443 | 8443 | Port for connecting to the ClickHouse server through HTTPS. |
| tcp_port | 9000 | 9000 | Port for connecting the client to the ClickHouse server through TCP. |
| tcp_port_secure | 9440 | 9440 | Port for connecting the client to the ClickHouse server through TCP SSL. |
| lb_tcp_port | 21424 | 21424 | TCP communication port number for ClickHouseBalancer. |
| lb_http_port | 21425 | 21425 | HTTP communication port number for ClickHouseBalancer. |
| lb_https_port | 21426 | 21426 | HTTPS communication port number for ClickHouseBalancer. |
| lb_tcp_secure_port | 21428 | 21428 | TCP SSL communication port number for ClickHouseBalancer. |
Common Impala Ports
| --beeswax_port | 21000 | 21970 | Port for impala-shell communication |
| --hs2_port | 21050 | 21971 | Port for Impala application communication |
| --hs2_http_port | 28000 | 21981 | Port used by Impala to provide the HiveServer2 protocol for external systems |
Common Doris Ports
| http_port | 8030 | 29980 | HTTP port of the FE service |
| https_port | 8050 | 29991 | HTTPS port of the FE service |
| query_port | 9030 | 29982 | Port used by the Doris FE to query connections through the MySQL protocol |
| rpc_port | 9020 | 29981 | Thrift Server port of the FE service |
| be_port | 9060 | 29984 | Thrift Server Port on BE for receiving requests from FE |
| brpc_port | 8060 | 29987 | BRPC port on BE, which is used for communications between BE instances. |
| heartbeat_service_port | 9050 | 29985 | Thrift heartbeat service port on BE, which is used to receive heartbeat messages from FE |
| webserver_port | 8040 | 29986 | HTTP server port on BE |
| broker_ipc_port | 8000 | 29990 | Thrift Server communication port on Broker, which is used to receive requests. |
| single_replica_load_brpc_port | 9070 | 29988 | RPC port used for the communication between the master and slave replicas to import single-replica data |
| single_replica_load_download_port | 8050 | 29989 | Port used by the slave replica to download data files from the master replica through HTTP for single-copy data import |
Common Guardian Ports
| ranger.obs.service.rpc.address.port | 26901 | 26901 | The RPC listening port for the Guardian OBS client service. |
| token.server.http-server.port | 26900 | 26900 | HTTP listening port of the Guardian service. |
| token.server.rpc.address.port | 26902 | 26902 | The RPC listening port of the Guardian service. |
Common Kudu Ports
| rpc_bind_addresses | 7051 | 7051 | Default RPC port of the Kudu Master. All requests from Tablet Server and clients (such as Impala and Spark) interact with the Master through this port. |
| webserver_port | 8051 | 8051 | Web UI port of the Kudu Master. You can access http://<master_host>:8051 using a browser to view the Master status and monitoring information. |
| rpc_bind_addresses | 7050 | 7050 | Default RPC port of the Kudu Tablet Server. This port is used for receiving client requests, coordinating with the Master, and communication between Tablet Servers. |
| webserver_port | 8050 | 8050 | Web UI port of the Kudu Tablet Server. You can access http://<tserver_host>:8050 using a browser to view the Tablet Server status and monitoring information. |
