Updated on 2026-09-24 GMT+08:00
Viewing MRS Cluster Audit Logs
The Audit page records user operations on Manager. Administrators can view user operation records on Manager. For details, see Audit logs.
This section describes how to view and export audit logs on MRS Manager for post-event tracing, fault cause locating, and responsibility division of security events.
Viewing Audit Logs (MRS 3.x or Later)
  1. Log in to FusionInsight Manager of the MRS cluster.
    For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
  2. Choose Audit. The Audit page displays audit information of FusionInsight Manager, including the operation type, risk level, start time, end time, user, host, service, instance, and operation result.
    Table 1 Audit information
    Operation Type
    Type of operation performed on FusionInsight Manager. The options include User_Manager, Cluster, Service, Alarm, Backup and Restoration, and Tenant.
    Severity
    Security level of each audit log. The options include Critical, Major, Minor, and Notice.
    Started
    Time when the operation starts
    Completed
    Time when the operation ends
    User
    Name of the user who performs the operation
    Host
    Cluster node where the operation is performed
    Service
    Cluster service involved in the operation
    Instance
    Cluster role instance involved in the operation
    Operation Result
    User operation result. The options include Successful, Failed, and Unknown.
    Figure 1 Audit information list
    • You can select audit logs at the Critical, Major, Minor, or Notice level from the All risk levels drop-down list.
    • In Advanced Search, you can set filter criteria to query audit logs.
      1. You can query audit logs by user management, cluster, service, and health in the Operation Type column.
      2. In the Service column, you can select a service to query corresponding audit logs.
        You can select -- to search for audit logs using all search criteria except the service.
      3. You can query audit logs by operation result. The options are All, Successful, Failed, and Unknown.
    • You can click to manually refresh the current page or click to choose the columns to display on the page.
    • Click Export All to export all audit information at a time, in TXT or CSV format.
Viewing Audit Logs (Versions Earlier Than MRS 3.x)
  2. Click Audit to view default audit logs.
  3. If an audit log contains more than 256 characters, click expand button to view full audit details.
    • Records are sorted in descending order by the Occurred column as the default setting. To change the sorting mode, click Operation Type, Severity, Occurred, User, Host, Service, Instance, or Operation Result.
    • You can filter all alarms of the same severity, including both cleared and uncleared alarms, by Severity.
    Exported audit log files contain the following columns:
    Table 2 Audit log file information
    Sno
    Number of audit logs generated by MRS Manager. The number increases by 1 each time an audit log is generated.
    Operation Type
    Operation type. The options are Alarm, Auditlog, Backup and Restoration, Cluster, Collect Log, Host, Service, Tenant, and User_Manager. User_Manager is available only for clusters with Kerberos authentication enabled. Each option contains varying operation types. For example, Alarm includes Export alarms, Cluster includes Start cluster, and Tenant includes Add tenant.
    Severity
    Security level of each audit log, including Critical, Major, Minor, and Informational.
    Start Time
    Time when the operation starts, which is the CET or CEST time
    End Time
    Time when the operation ends, which is the CET or CEST time
    User IP Address
    IP address used by a user to perform the operation
    User
    Host
    Node where the operation is performed. The information is not saved if the operation does not involve a node.
    Service
    Service on which the operation is performed. The information is not saved if the operation does not involve a service.
    Instance
    Role instance on which the operation is performed. The information is not saved if the operation does not involve a role instance.
    Operation Result
    Content
    Detailed information of the operation
  4. Click Advanced Search. In the search area, set search criteria and click Search to view audit logs of a specified type. Click Reset to clear the search criteria.
    Start Time and End Time specify the start time and end time of the time range. You can search for alarms generated within the time range.
  5. To export all audit log files in the log list, click Export All.
  6. To export an audit log file, select it in the log list and click Export.
Helpful Links
