Viewing MRS Operation Logs
You can view operation logs of clusters and jobs on the
page. Log information is typically used for quickly locating faults in case of cluster exceptions, helping users resolve problems.Operation Type
Currently, the following operation logs are provided by MRS. You can filter the logs in the search box.
- Cluster operations
- Creating, deleting, scaling out, and scaling in a cluster
- Creating and deleting a directory, deleting a file
- Job operations: Creating, stopping, and deleting a job
- Data operations: IAM user tasks, adding user, and adding user group
Log Fields
Logs are listed in chronological order by default in the log list, with the most recent logs displayed at the top.
Table 1 describes various fields in a log.
Parameter |
Description |
Operation Type |
Various types of operations, including:
Operation IP |
IP address where an operation is performed.
If an MRS cluster fails to be deployed, the cluster is automatically deleted, and the operation logs of the automatically deleted cluster do not contain the Operation IP of the user. |
Users |
The user who performs the operation |
Operation |
Operation details. The value can contain a maximum of 2048 characters. |
Time |
Operation time. For a deleted cluster, only logs generated within the last six months are displayed. To view logs generated six months ago, contact Huawei Cloud technical support. |
Enterprise Project |
Enterprise project to which the cluster belongs |
Icon |
Description |
Select an enterprise project from the drop-down list box to filter logs. |
Select an operation type from the drop-down list box to filter logs.
Filter logs by time.
The left-side input box indicates the start time and the right-side one indicates the end time. The start time must be earlier than or equal to the end time. Otherwise, logs cannot be filtered. |
Enter a keyword of the Operation Details in the search box and click to search for logs. |
Click to manually refresh the log list. |
