- What's New
- Product Bulletin
- Getting Started
- User Guide
- API Reference
SDK Reference
- Introduction to Moderation SDK
- Applying for a Service
- Obtaining Authentication Information
- Preparing the Environment
- Using the SDK (Java)
- Using the Python SDK
- Using the .NET SDK
- Using the Go SDK
- Service Enabling
APIs
- How Do I Use Content Moderation APIs?
- What Should I Do When I Fail to Call a Content Moderation API?
- Can I Directly Upload a Word File for Text Moderation?
- What Are the Constraints on Concurrent API Calls?
- What Can I Do if the Request for Calling an API Times Out?
- How Do I Customize a Detection in Text Moderation?
- Can Content Moderation Traverse and Review the Content in an OBS Folder?
- Error Codes
- Monitoring
- Others
- Price Details
- Glossary
Show all
Process of Using Content Moderation
Content Moderation adopts image and text detection technologies that detect pornography and images and text violating related laws or regulations. By calling the APIs provided by Content Moderation, you can have your uploaded images, text, audio, and videos reviewed and obtain the inference results. This helps you build an intelligent system that delivers improved efficiency.
The following figure shows the procedure for using this service.
Procedure |
Sub Task |
Description |
Instruction |
Making preparations |
Signing up with Huawei Cloud |
Before using Content Moderation, sign up for a HUAWEI ID. |
Subscribing to the service |
Subscribing to the Content Moderation service by following the procedure |
You need to subscribe to the service according to the procedure. |
Choosing the yearly/monthly or pay-per-use billing mode |
After subscribing to the service, you need to purchase the service. Two billing modes are available. |
Preparing data |
Preparing data that meets requirements |
There are restrictions on the data format and the number of concurrent calls. Before using the service, you need to prepare the data to be reviewed by referring to the restrictions. |
Calling APIs or SDKs |
Making local calls |
Use the Moderation SDK for local development. You can directly call functions to use SDKs. |
Viewing the number of calls |
Viewing call result statistics |
You can view the review details and the number of API calls on the management console. |
