Updated on 2026-10-27 GMT+08:00
Overview
Application migration projects collect resources for servers, storage devices, containers, middleware, databases, and big data. They also support server and storage migration. Table 1 lists the details.
Table 1 Overview
Function
Remarks
Migration Journeys
During multi-cloud or IDC-to-cloud migrations, enterprises often face challenges such as complex workflows and a lack of standard guidance, leading to prolonged cycles and high error rates. The Migration Journeys function, built on Huawei Cloud's proven migration methodologies, deconstructs complex processes into manageable stages and tasks. For key scenarios like server migration, it provides standard frameworks and operation guides. By offering clear and professional guidance throughout the migration process, it significantly simplifies operations, helping enterprises migrate servers and storage data from existing cloud platforms or IDCs to Huawei Cloud with high efficiency and accuracy.
Migration Journeys (Old)
This function is built on proven cloud migration methodologies. It breaks down complex migrations into clear phases and actionable tasks, helping you manage workloads and coordinate teams more efficiently. It provides ready-to-use templates for migrating databases, Large Language Models (LLMs), and containerized applications, guiding you step by step through the entire journey. Whether you are moving data from other clouds or IDCs to Huawei Cloud, you will benefit from comprehensive guidance, tool tutorials, and curated migration resources.
TCO Analysis
The following functions are provided:
  • TCO Analysis for On-Prem to Cloud Migration: Specify your on-premises infrastructure details to estimate the cost savings you can realize by migrating on-premises workloads to Huawei Cloud.
  • TCO Analysis for Cross-Cloud Migration Using Credentials: Input the source cloud credentials to allow MgC to analyze your source bills, identify what and how many source resources you used, match the source resources with Huawei Cloud alternatives, and then compare the cost of your source environment with the cost on Huawei Cloud.
  • TCO Analysis for Cross-Cloud Migration Using Bills: Upload the source bills to allow MgC to analyze the bills, identify what and how many source resources you used, match the source resources with Huawei Cloud alternatives, and then compare the cost of your source environment with the cost on Huawei Cloud.
Credential-based analysis is applicable to source servers of AWS and Alibaba Cloud. Bill-based analysis is applicable to source servers of AWS.
Resource Discovery
MgC provides multiple resource survey and collection methods for servers, storage, databases, and middleware. The following features are included:
  • Online Discovery: It discovers and collects source cloud resources online through the public network.
  • Intranet Discovery: After you deploy the MgC Agent within your source network, MgC helps you discover and collect server information from your IDC and VMware environments, either by scanning network segments or by connecting directly to vCenter.
  • Importing RVTools Data: Export the resource list from RVTools, then import it to MgC.
  • Importing Cloud Resource Details: Export a resource list in CSV format from another cloud platform, then import it to MgC. MgC will automatically parse these files, identify resources, and display details in the resource list.
  • Online Discovery: Supported source platforms include Alibaba Cloud, Huawei Cloud, AWS, Tencent Cloud, Google Cloud, and Azure.
  • Intranet Discovery: Only VMs in VMware vSphere 5.0 to 7.0 can be discovered.
  • Importing RVTools Data: The exported file must be in XLSX format. The size of the imported file cannot exceed 100 MB, and the compression ratio cannot be lower than 5%.
  • Importing Cloud Resource Details: Resource lists exported from Alibaba Cloud or Azure are supported.
Cloud Migration Assessment
MgC provides comprehensive migration assessment services to help you efficiently and securely complete cloud migration. The following features are included:
  • Target specification recommendation: After assessing the source environment, the system recommends right-sized Huawei Cloud resources accordingly. Recommendations consider resource specifications, performance requirements, application scenarios, cost efficiency, availability, and security compliance requirements.
  • Migration risk assessment: MgC identifies potential risks in advance, including but not limited to general compatibility, firmware compatibility, and specification differences.
  • Storage migration assessment: MgC uses inputs such as the number and size of source files, expected migration duration, and other parameters to estimate the time and cost of cloud migration. It also offers multiple migration options, comparing their costs and benefits to support informed decision-making.
  • Big data migration assessment: MgC dynamically evaluates cluster resource requirements and reporting frequency based on data table size and change volume, following industry best practices to optimize migration efficiency.
  • Target specification recommendation: This is applicable to servers, databases, object storage, containers, and middleware.
  • Migration risk assessment: This is applicable to servers only.
Server Migration
MgC provides different task types suitable for various server migration scenarios. For details, see Server Migration Tasks.
Storage Migration
MgC provides different task types suitable for various storage migration scenarios. For details, see Storage Migration Tasks.
Migration Tool Center
MgC consolidates tools for various migration scenarios including server, storage, database, middleware, and container migrations into a unified platform. You can create migration tasks with a few clicks, improving operation convenience and efficiency.
Task Center
The Migration Task Center enables you to centrally manage migration tasks. It helps you monitor and manage migration tasks that have been configured and started.
Migration Clusters
A migration cluster is a core component for storage migration tasks. It allows you to create and manage migration nodes and list nodes, and deploy and upgrade migration plugins, ensuring smooth operations of storage tasks.
Migration clusters incur additional costs. For details, see Billing.
