Custom Parameters
For details about the custom parameters that can be configured for the target, see Table 1 and Configuration parameter description.
Parameter |
Value Range |
Description |
Mandatory |
spark.dli.metaAccess.enable |
Enter true. |
Yes |
spark.dli.job.agency.name |
Enter the DLI agency name. |
mgc.mc2dli.data.migration.dli.file.path |
Enter the OBS path for storing the migration-dli-spark-1.0.0.jar package. For example, obs://mgc-test/data/migration-dli-spark-1.0.0.jar |
mgc.mc2dli.data.migration.dli.spark.jars |
Enter the OBS path for storing the fastjson-1.2.54.jar and datasource.jar packages. The value is transferred in array format. Package names must be enclosed using double quotation marks and be separated with commas (,) For example: ["obs://mgc-test/data/datasource.jar","obs://mgc-test/data/fastjson-1.2.54.jar"] |
spark.sql.catalog.mc_catalog.tableWriteProvider |
Enter tunnel. |
Mandatory for migration over private lines |
spark.sql.catalog.mc_catalog.tableReadProvider |
Enter tunnel. |
spark.hadoop.odps.end.point |
Enter the VPC endpoint of the region where the source MaxCompute service is provisioned. For details about the MaxCompute VPC endpoint in each region, see Endpoints in different regions (VPC). For example, if the source MaxCompute service is located in Hong Kong, China, enter http://service.cn-hongkong.maxcompute.aliyun-inc.com/api. |
spark.hadoop.odps.tunnel.end.point |
Enter the VPC Tunnel endpoint of the region where the source MaxCompute service is located. For details about the MaxCompute VPC Tunnel endpoint in each region, see Endpoints in different regions (VPC). For example, if the source MaxCompute service is located in Hong Kong, China, enter http://dt.cn-hongkong.maxcompute.aliyun-inc.com. |
spark.hadoop.odps.tunnel.quota.name |
Enter the quota name used for accessing MaxCompute. |
No |
sc_type |
A, B, and C |
Specify the compute resource type. Currently, resource types A, B, and C are available. If this parameter is not specified, the minimum configuration (type A) is used.
No |
executorCores |
1–4 |
Specify the number of CPU cores of each executor in a Spark application. This configuration will replace the default setting in sc_type. |
numExecutors |
1–100 |
Specify the number of executors in a Spark application. This configuration will replace the default setting in sc_type. |
executorMemory |
1 – 16 GB |
Specify the executor memory of a Spark application, for example, 2 GB or 2048 MB. This configuration will replace the default setting in sc_type. The unit must be provided. Otherwise, the startup fails. |
driverCores |
1–4 |
Specify the number of CPU cores for the driver in a Spark application. This configuration will replace the default setting in sc_type. |
driverMemory |
1 – 16 GB |
Specify the driver memory of a Spark application, for example, 2 GB or 2048 MB. This configuration will replace the default setting in sc_type. The unit must be provided. Otherwise, the startup fails. |
hive.exec.dynamic.partition.mode |
If you set Migration Filter to Custom when you create a migration task to migrate dynamic partition data, add this parameter and set it to nonstric. |
No |
