Scanning for Incremental Metadata
Identify the metadata that has changed in the source databases after the previous migration is complete, and synchronize the incremental metadata to Huawei Cloud CLI.
- A source connection has been created.
- Target connections have been created.
- At least a full metadata migration has been completed.
Preparations
- Gain whitelist access to the Spark 3.3.1 feature.
Contact technical support to whitelist you to use the Spark 3.3.1 feature.
- Configure a DLI job bucket.
You need to purchase a bucket or parallel file system on OBS. The bucket is used to store temporary data generated by DLI. For details, see Configuring a DLI Job Bucket.
- Sign in to the MgC console. In the navigation pane, under Project, select your big data migration project from the drop-down list.
- In the navigation pane on the left, click Data Migration.
- In the upper right corner of the page, click Create Migration Task.
- Select MaxCompute for Source Component, Data Lake Insight (DLI) for Target Component, and Incremental metadata scan for Task Type, and click Next.
- Configure parameters required for creating an incremental metadata scan based on Table 1.
Table 1 Parameters for creating an incremental metadata scan Area
Configuration
Basic Settings
Task Name
The default name is Incremental-data-scan-of-MaxCompute-and-DLI-4 random characters (including letters and numbers). You can also customize a name.
MgC Agent
Select the MgC Agent you connected to MgC in Preparations.
Source Settings
Source Connection
Select the source connection you created.
MaxCompute Parameters (Optional)
The parameters are optional and usually left blank. If needed, you can configure the parameters by referring to MaxCompute Documentation.
Data Scope
Time Range
- If you select All, MgC will scan for the incremental metadata generated in the source databases since the last metadata migration.
- If you select Custom, select a T-N option to limit the scan scope to the incremental metadata generated within a specific time period (24 × N hours) before the task start time (T). Assume that you select T-1 and the task was executed at 14:50 on June 6, 2024. The system scans for incremental metadata generated from 14:50 on June 5, 2024 to 14:50 on June 6, 2024. NOTICE:
The system only identifies and synchronizes metadata that has changed within the specified time range. Metadata that exists only at the source or the target will not be synchronized or processed.
By database
Enter the names of databases to be scanned in the Include Databases text box. Click Add to add more entries. A maximum of 10 databases can be added. If you do not enter a database name, all source databases will be migrated by default.
To exclude certain tables from the scan, download the template in CSV format under Exclude Tables, add information about these tables to the template, and upload the template to MgC. For details, see 2 to 5.
By table
- Download the template in CSV format.
- Open the downloaded CSV template file with Notepad. CAUTION:
- Do not use Excel to edit the CSV template file. The template file edited and saved in Excel cannot be identified by MgC.
- The uploaded CSV file cannot exceed 240 KB.
- Retain the first line in the CSV template file. From the second line onwards, enter the information about tables to be migrated in the format of {MaxCompute-project-name},{table-name}. {MaxCompute-project-name} refers to the name of the MaxCompute project to be migrated. {table-name} refers to the data table to be migrated. NOTICE:
- Use commas (,) to separate the MaxCompute project name and the table name in each line. Do not use spaces or other separators.
- After adding the information about a table, press Enter to start a new line.
- After all table information is added, save the changes to the CSV file.
- Upload the edited and saved CSV file to MgC.
Target Settings
Target Connection
Select the DLI connection with a SQL queue created in Creating a Target Connection.
CAUTION:Do not select the connection with a general queue configured.
Custom Parameters (Optional)
Configure the parameters as needed. For details, see Configuration parameter description and Custom Parameters.
Migration Settings
Concurrency
Set the number of concurrent migration subtasks. The default value is 3. The value ranges from 1 to 10.
- After the configuration is complete, execute the task.
- A migration task can be executed repeatedly. Each time a migration task is executed, a task execution is generated.
- You can click the task name to modify the task configuration.
- You can select Run immediately and click Save to create the task and execute it immediately. You can view the created task on the Tasks page.
- You can also click Save to just create the task. You can view the created task on the Tasks page. To execute the task, click Execute in the Operation column.
- After the migration task is executed, click View Executions in the Operation column. On the Task Executions tab, you can view the details of the running task execution and all historical executions.
Click View in the Progress column. On the displayed Progress Details page, view and export the incremental metadata scan results.
- In the upper right corner of the progress details page, click Open DDL Editor to compare and edit the structures of incremental tables.
