- What's New
- Function Overview
- Getting Started
User Guide
New Edition
- Permissions Management
- Settings Management
- TCO Analysis
- Resource Discovery and Management
- Application Management
- Migration Path Planning
- Migration Workflows
- Preparations for Big Data Migration
- Big Data Migration (from MaxCompute to DLI)
- Big Data Verification
- Migration Partners
- Migration Clusters
- Migration Solutions (Offline Soon)
- Migration Plans
Old Edition
- Migration Surveys
- Big Data Lineage
- Migration Plans
New Edition
MgC Agent Usage Guide
- MgC Agent Overview
- OSs That Can Be Collected and Migrated
- Installing the MgC Agent (Formerly Edge)
- Resource Management
- Connecting the MgC Agent to MgC
- Collector-based Discovery
- Best Practices
- What Are the Requirements for the Server for Installing the MgC Agent (Formerly Edge)?
- How Do I Run the MgC Agent in Compatibility Mode?
- What Can I Do If the MgC Agent (Formerly Edge) Is Offline?
- Why Can't the MgC Agent (Formerly Edge) Start After Being Installed?
- How Do I Upgrade the MgC Agent (Formerly Edge) to the Latest Version?
- How Do I Uninstall the MgC Agent (Formerly Edge)?
- How Do I Restart the MgC Agent (Formerly Edge)?
- How Do I Check the Current MgC Agent Version (Formerly Edge)?
- How Do I Obtain Run Logs of the MgC Agent (Formerly Edge) on Linux?
- How Do I Fix the Error "The collector is not installed" When a Discovery Task Fails?
- How Do I Obtain the Hive Metastore Credential Files?
- What Can I Do If the Port Required by the MgC Agent Is Occupied and the Installation Fails?
- What Can I Do If AK/SK Verification Fails?
- How Do I Configure WinRM and Troubleshoot WinRM Connection Problems?
- What Do I Do If the Credential List Is Empty When I Create a Data Connection for Big Data Verification?
- What Can I Do If Installing the MgC Agent on a Linux Server Fails Due to Insufficient Entropy?
- How Do I Set Environment Variables to Collect and Migrate Linux Servers That Use OpenSSH Earlier Than 7.0?
- Known Issues and Solutions
Best Practices
Server Migration
- Configuring Permissions Required for Server Migration
- Network Requirements for Server Migration
- Migrating On-premises Servers to Huawei Cloud
- Migrating Servers from Alibaba Cloud to Huawei Cloud
- One-stop Cross-AZ ECS Migration
- Migrating Servers Across AZs on Huawei Cloud
- Migrating Servers to FlexusX Instances (Original HECS X Instances)
- Keeping Private IP Addresses of Servers Unchanged After the Migration
- Batch Modifying and Restoring the Host Configurations for Linux Source Servers
- Batch Modifying and Restoring the Host Configurations for Windows Source Servers
Storage Migration
- Migrating Data from Other Cloud Platforms to Huawei Cloud
- Migrating Data from Multiple Source Buckets by Prefix
- Migrating Archive (Cold) Data
- Migrating Data from SFS 1.0 to SFS 3.0
- Performing a NAS-to-NAS Migration and Service Cutover
- Migrating File Systems in Batches
- Migrating Data from MinIO to Huawei Cloud OBS over HTTP
- Migrating Data from Ceph to Huawei Cloud OBS over HTTP
- Migrating Data Using CDN
- Reducing Disk Capacity for Target Servers
- Resizing Disks and Partitions for Target Servers
- Collecting Details of Azure Kubernetes Service (AKS) Resources
- Collecting Details of Google Cloud GKE Resources
- Collecting Details of AWS Container Resources
- Collecting Details of Self-built Oracle Databases
Verifying Big Data Consistency After Migration
- Verifying the Consistency of Data Migrated from MaxCompute to DLI
- Verifying the Consistency of Data Migrated Between MRS ClickHouse Clusters
- Verifying the Consistency of Data Migrated from Alibaba Cloud EMR ClickHouse to Huawei Cloud MRS ClickHouse
- Verifying the Consistency of Data Migrated from Alibaba Cloud ApsaraDB for ClickHouse to Huawei Cloud MRS ClickHouse
- Verifying the Consistency of Data Migrated from Alibaba Cloud ApsaraDB for ClickHouse to Huawei Cloud CloudTable (ClickHouse)
- Verifying the Consistency of Data Migrated Between MRS Doris Clusters
- Verifying the Consistency of Data Migrated Between MRS Hive Clusters or from CDH or EMR to MRS Hive
- Verifying the Consistency of Data Migrated from MaxCompute to MRS Hive
- Verifying the Consistency of Data Migrated Between MRS HBase Clusters
- Verifying the Consistency of Data Migrated from Delta Lake (with Metadata) to MRS Delta Lake
- Verifying the Consistency of Data Migrated from Delta Lake (Without Metadata) to MRS Delta Lake
- Migrating Big Data Without Using the Internet
- BigData Migration Cockpit
Server Migration
Product Consultation
- How Do I Assign the Permissions Required for Using MgC to IAM Users?
- Where Is MgC Available?
- How Do I Prepare for Using MgC?
- How Do I Fix the Error "Failed to access IAM. Check the current user's IAM permissions"?
- Why Can't I Sign the Privacy Statement and Use MgC?
- How Does MgC Ensure Data Security?
- Does Data Collection Affect My Source Services?
Network Settings
- What Can I Do If a Source Server Fails the Migration Readiness Check Because Its IP address or Port Is Unreachable?
- What Can I Do If a Source Server Fails the Migration Readiness Check Because the Username or Password Is Incorrect?
- How Do I Fix the Error "Deliver Command to MgC Agent Failed" When a Source Server Fails the Migration Readiness Check?
- What Can I Do If a Source Server Fails the Migration Readiness Check Due to an Unreachable Port, Incorrect Firewall Settings, or Insufficient Access Permissions?
- What Can I Do If Deep Collection Fails on a Source Server Due to Disabled WinRM or an Unreachable IP Address or Port?
Server Migration
- What Are the Notes, Constraints, and Precautions for Server Migration?
- How Do I View the Migration Progress When the Migration Workflow Is in the Running State?
- Why the Workflow Status Is Always "Running"?
- How Do I Fix the Error "MgC Agent is not accessible" When a Step in the Migration Workflow Fails?
- How Do I Fix the Error "Server Require to Bind Credential First..." When the Migration Workflow Fails on a Source Server?
- How Do I Handle Resource Exceptions during a Batch Server Migration?
- What Are the Known Errors Related to Server Migration Workflows and How Can I Fix Them?
- What Can I Do If an Error Occurs During the Migration of a VMware Server?
- What Are the Information Mappings Between MgC and SMS?
- Why Is the Migration Progress Inconsistent Between MgC and SMS?
- What Do I Do If I Use a sudo User to Migrate a Source Server and the Server Fails the Source Environment Check?
- What Can I Do If the "StartUpAgent" Step Fails and the Error Message "System.OutOfMemoryException" Is Displayed?
- How Do I Fix the Error "SMS-Workflow.0503: SMS migration task failed. SMS.xxxx?"
- What Do I Do If Some Disks Are Not Attached to the Target Server After the Migration Is Complete?
Storage Migration
- What Are the Restrictions on Using MgC for Storage Migration?
- What Are the Requirements for the Source and Target Environments?
- How Do I Choose the Right Specifications for a Migration Cluster?
- What Affects the Migration Speed of Large Objects?
- What Affects the Migration Speed of Small Objects?
- How Do I View Key Metrics that Affect the Migration Speed?
- Why Is My Storage Migration Workflow Stalled for a Long Time?
- When I Migrate HTTP/HTTPS Data to Huawei Cloud OBS, How Are the Objects with the Same Name but Different URLs Processed?
- When I Migrate Data from OBS to NAS on Huawei Cloud, How Are Objects with the Same Name but Different Capitalization Processed?
- What Are the Constraints on the Length of Object Paths for Migrations Between OBS, NAS, and SMB Storage Systems on Huawei Cloud?
- How Do I Resolve the Problem that a Migration Cluster Fails to Be Created?
- How Do I Obtain Credentials for Accessing Microsoft Azure?
- What Do I Do If the Storage Migration Workflow Fails and "COMPARISON_ATTRIBUTE_NOT_SAME" Is Displayed?
- How Do I Choose Storage Classes?
- What Do I Do If a Migration Task Fails?
- Cross-AZ Migration
- TCO Analysis
Resource Discovery
- Known Resource Discovery Problems and Solutions
- Where Can I Find the Collection Failure Cause?
- What Can I Do If an Internet Discovery Task Fails and the Error Message "Network connection timed out" or "Other exception" Is Displayed?
- How Do I Collect Data from a Data Source Again If the Previous Collection Fails?
- How Do I Obtain Cloud Platform Credentials (AK/SK Pairs)?
- How Do I Obtain Azure Credentials?
- How Do I Obtain the Required Credentials Before Using MgC to Perform a Deep Collection for My Azure Object Storage Resources?
- How Do I Obtain the Permissions Required for Collecting Details of Azure Resources?
- How Do I Convert the Encoding Format of a CSV File to UTF-8?
- What Can I Do If the Collected Disk Information Is Empty or Incorrect After a Deep Collection Is Performed for a Windows Source Server?
- What Can I Do If the Collected OS Information Is Incorrect After a Deep Collection Is Performed for a Windows Source Server?
- What Can I Do If an RVTools Import Fails?
- What Do I Do If the Deep Collection Succeeds on a Source Server but Some Specifications Information Is Not Collected?
Target Recommendations
- Where Can I Find the Assessment Failure Cause?
- Why Can't I Manually Select Target Server Specifications and Disk Types?
- What Can I Do If a Server Assessment Fails and the System Displays a Message Indicating No Proper Specifications Are Matched?
- What Can I Do If a Server Assessment Fails Because the Target Server Specifications Do Not Support Windows Images?
- What Types of Databases Can I Assess Using MgC?
- How Does MgC Generate Target Recommendations?
- Why Are 0 or -1 Displayed in the Hive Verification Results?
- Why Does a Field in Hive Fail the Sum Verification?
- Why Do a Large Number of Tables Fail to Be Verified in a DLI Verification Task?
- How Do I Optimize the Verification Task When the Delta Lake Data Volume Is Large?
- How Do I Replace Packages Before I Create a Connection to a Secured HBase Cluster on the Target Cloud?
- How Do I Replace Packages When I Create a Verification Task for an MRS 3.1.0 Cluster Using Yarn?
Show all
TCO Analysis for Cross-Cloud Migration Using Credentials
You can share your source cloud credentials, and MgC will analyze your source bills, identify what and how many source resources you used, match the source resources with Huawei Cloud alternatives, and then compare the costs of your source environment with the costs on Huawei Cloud.
The supported source clouds include AWS and Alibaba Cloud.
A maximum of 9,999 servers can be included in an analysis task.
Creating an Analysis Task
- Sign in to the MgC console. In the navigation pane, under Project, choose a project from the drop-down list.
- In the navigation pane on the left, choose Assess > TCO Analysis.
- Click the TCO Analysis: Cross-Cloud Migration card. Under the Online Analysis tab, click Create Analysis Task. If you are using this function for the first time, you need to delegate MgC certain permissions. After you agree to the authorization, the Create Analysis Task page is displayed on the right.
- Configure the parameters listed in Table 1.
Table 1 Parameters for creating an analysis task
Task Name
User-defined
Vendor
Select the source cloud vendor.
Currently, AWS and Alibaba Cloud can be chosen.
Region
Select the regions where your source resources are located.
Research Method
- If you select AK/SK, specify Credential, Time Range, and Products. If your source cloud credential has not been added to MgC, add it by choosing Create from the credential drop-down list. Configure the parameters for adding a credential and click Verify and Save.
- You need to provide the AK/SK pair of your source cloud account.
- The source account must have read-only permissions.
- Fees for API requests may be incurred.
- If you select Form upload, download the template, fill it out, and upload the file.
NOTICE:
A maximum of 9,999 servers can be contained in the file.
Target Region
Select the region you want to migrate to.
- Click Confirm.
After the task is submitted, it will appear in analysis task list. You can click the task name to view the analysis progress. After the task is finished, you can download bills, view product mappings, and obtain analysis results for further review.
Downloading Bills
MgC analyzes your source bills for the specified period, identifies the billing items, and obtains the specifications, monthly usage, and monthly consumption of each product you used. You can download your bills after the analysis is finished.
- In the analysis task list, click the task name.
- Click Download Bills in the Operation column. The bills will be downloaded to an Excel file.
Viewing Product Mappings
MgC automatically recommends Huawei Cloud alternatives based on the specifications and usage of source resources. The recommendations prioritize cost-effectiveness while maintaining the current specifications.
You can view the product mapping details and adjust the mappings as needed.
- Click Product Mappings in the Operation column.
- Click
on the left of a resource category to view the mapping details.
- Mapping refers to the aligning of source products to target products.
- Standard mapping means a source product is mapped to the equivalent Huawei Cloud product.
- Non-standard mapping means a source product is mapped to a Huawei Cloud product that is closest to the source product. You can change the mapping if needed.
Viewing Analysis Results
You can view how much you would save if you migrate to Huawei Cloud.
You can also compare the average monthly costs of a certain type of resource between the source cloud vendor and Huawei Cloud. In addition, you can get discounts for each type of resource from your sales manager to save more money on Huawei Cloud.
- Click TCO Analysis in the Operation column.
- View Analysis Details and Price Differences, and adjust the estimated costs of Huawei Cloud resources based on the discounts you get.
Click Export Report in the upper right corner. The analysis report will be exported to a PDF file.
