Subtitling
You can subtitle a virtual avatar video.
- Log in to the MetaStudio console and go to the Overview page.
- Click Go to MetaStudio Console to go to the MetaStudio console.
- Click the Video Production card to go to the video production page.
Select an avatar, enter text for text-based avatar control, and customize other information.
Figure 1 Video production - Click
to enable subtitling.
After enabling subtitling, you can adjust the font, color, and position of the subtitles on the left of the page. For details, see Figure 2. - Click Generate Preview and select Current scene or All scenes to generate a preview video. You can play the video to view the subtitles.
For text-based avatar control, the input text is extracted to generate subtitles. For audio-based avatar control, the audio is converted to text before subtitles are generated.
- In the Subtitling area on the left of the page, you can view the generated subtitles. You can click Edit Subtitle to edit the subtitles, as shown in Figure 3.
- After editing the subtitles, click Save.
