Updated on 2025-08-25 GMT+08:00
Account Settings
By default, IAM users under the same Huawei Cloud account share resources. Specifically:
  • Sharing of resources purchased by each IAM user: Each IAM user's total available resource quantity is the sum of available resources purchased by all IAM users. Since these resources are shared, an IAM user's available quantity will decrease if other IAM users consume resources, even if this user has not used any.
  • Sharing of all IAM users' assets: All assets uploaded by each IAM user can be shared, such as image and voice assets (including production tasks), composited videos (including scripts and tasks), live rooms, and intelligent interaction projects.
By default, IAM User Isolation is not displayed in the navigation pane of the MetaStudio console. To obtain the permission for using this function, you need to submit a service ticket and provide the project ID of the region where the current Huawei Cloud account is.
Once enabled, IAM User Isolation is visible only to Huawei Cloud account users, but not IAM users.
Notes
If the Huawei Cloud account has customized the asset isolation capability using the API field X-App-UserId:
  • After IAM user isolation is enabled, asset isolation by IAM accounts overrides the custom asset isolation capability.
  • Enabling IAM user isolation makes custom asset isolation invalid, but disabling it restores custom asset isolation.
  1. Log in to the MetaStudio console and go to the Overview page.
  2. In the navigation pane, choose IAM User Isolation > Account Settings to go to the Account Settings page, as shown in Figure 1.
    Figure 1 Account settings
    See Table 1.
    Table 1 Parameters
    Item
    IAM User Settings
    IAM User Isolation
    IAM user isolation can be enabled.
    Options:
    • Disable: By default, this function is disabled. That is, purchased resources and assets of each IAM user under the current account can be shared by all IAM users.
    • Enable: An IAM user cannot view or use the assets uploaded or created by another IAM user before this function is enabled. An asset uploaded or created after this function is enabled is managed and used by its owner. For details about asset isolation, see Table 2.
    Enabling or disabling IAM user isolation does not change the following:
    • Purchased resources of all IAM users are shared.
    • The Huawei Cloud account can view and use the resources and assets of all IAM users.
    After IAM user isolation is enabled, you can see the isolation details, as shown in Table 2. If an asset or configuration is not in the table, IAM user isolation is not enabled.
    Table 2 Asset isolation
    Asset
    Asset Subcategory
    Isolated
    Image modeling
    Image modeling task
    Yes
    IAM users can only view the image modeling tasks that they will submit.
    Image model
    Yes
    IAM users can only view the virtual avatar image models that they will generate.
    Voice modeling
    Voice modeling task
    Yes
    IAM users can only view the voice modeling tasks that they will submit.
    Voice model
    Yes
    IAM users can only view the virtual avatar voice models that they will generate.
    Video production
    Video draft
    Yes
    IAM users can only view and edit the video drafts that they will create.
    Each time a video is composited, a video production task is generated.
    Video production task
    Yes
    IAM users can only view the video production tasks that they will submit.
    Composited video
    Yes
    IAM users can only view and edit the videos that they will composite.
    Intelligent interaction
    Dialog project
    Yes
    IAM users can only view and edit the dialog projects that they will create.
    Skill
    No
    The skills of all IAM users can be viewed and used.
    Livestreaming
    Live room
    Yes
    IAM users can only view and edit the live rooms that they will create.
    Each time a livestream starts, a livestreaming task is generated.
    Live template
    No
    The live templates of all IAM users can be viewed and used.
    If the current IAM user uses another IAM user's live template that contains isolated assets, the isolated assets are unavailable. Consequently, an error will be reported. IAM users are advised to use their own live templates.
    Interaction rule library
    Yes
    IAM users can only view and edit the interaction rule libraries that they will create.
    No
    The intelligent interaction settings of all IAM users can be viewed and used.
    Product
    Yes
    IAM users can only view and edit the products that they will create.
    Livestreaming task
    Yes
    IAM users can only view and edit the livestreaming tasks that they will create.
    Interconnected live platform
    No
    The information about interconnected live platforms of all IAM users can be viewed and used.
    Livestream settings
    No
    Each IAM user can configure a livestream as needed. The configuration takes effect for all IAM users.
    Asset uploaded locally
    Yes
    IAM users can only view and edit the assets that they will upload.
