- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Getting Started with MAS
- Modules
- Namespace
- Multi-Active Instances
- Application Management
- Monitor Management
- Credential Management
- Event Monitoring
- Audit Logs
- Permissions Management
MAS FAQs
- Is MAS a Product or Solution?
- Does MAS Synchronize Data in Addition to Controlling Access from Applications to Databases?
- Is MAS Like a Management Channel for Which I Need to Configure Automatic Switchover Policies?
- What Is the Automatic Switchover Mechanism? How Does MAS Implement Switchovers in Seconds?
Multi-Active DR Solution FAQs
- In the Single- or Dual-Instance Data Layer Architecture (Same Region, Multi-AZ, Traffic Distribution with API Gateway), Which Components Are Provided by MAS and Which Ones Should I Prepare?
- Can I Implement the Active-Active Solution on Any Other Services in Addition to Self-Built Cloud Services?
- How Do I Implement Database Dual-Write?
- Does the Multi-Active Architecture Have Any Requirements on My Services?
- What Are the RPO and RTO of the Multi-Active DR Solution?
- Does the Multi-Active DR Solution Have Any Network Requirements? Will Incorrect Switchover Occur If the Network is Unstable or Jitters?
- How Do I Configure Monitoring for Multi-AZ Deployment in the Same Region?
- Will MAS and API Gateway Be Deployed on Both Huawei Cloud and Our Cloud?
- MAS Usage FAQs
MAS FAQs
Help Center/
Multi-Site High Availability Service/
User Guide/
Event Monitoring/
Creating an Alarm Rule to Monitor an Event
This section describes how to create an alarm rule to monitor an MAS event.
- Choose Service List > Cloud Eye.
- In the navigation pane on the left, click Event Monitoring.
- On the event list page, click Create Alarm Rule in the upper right corner.
- Configure the alarm rule name, alarm policy, and alarm notification as prompted.
- Alarm Type: Select Metric or Event.
- Event Type: Select System event.
- Event Source: Select Multi-Site High Availability Service.
Figure 1 Creating an alarm rule
For details about other parameters, see Creating an Alarm Rule to Monitor an Event. After the alarm rule is created, when the event monitoring metric triggers the specified alarm policy, Cloud Eye will immediately notify you of cloud resource exceptions through SMN to avoid losses.
Parent topic: Event Monitoring
