Updated on 2025-07-23 GMT+08:00
Configuring a Notification
Creating a Notification
  1. Log in to the MAS console. On the Multi-Active Instances page, click an instance whose namespace type is Intra-city multi-active.
  2. Click the Global tab.
  3. On the Notifications page, click Create Notification.
  4. Enter the notification information, then click OK.
    Figure 1 Notification configurations
    Table 1 Notification parameters
    Subject
    Select a notification subject or click Add to create one.
    Notify
    Specify whether to enable notification.
    For details about how to create an SMN subject, see Publishing a JSON Message.
Creating an SMN Subject
  4. Click Add to create a subject.
Modifying a Notification
  3. On the Notifications page, click Modify in the row that contains the target notification.
  4. Modify the notification information, and click OK.
Deleting a Notification
  3. On the Notifications page, click Delete in the row that contains the target notification.
  4. Click OK to delete the notification.
