On this page
API Monitoring
Updated on 2024-11-26 GMT+08:00
Introduction
API monitors monitor the API gateway of your service, and control the resolution result of the DNS entry based on the availability of API gateway.
Table 1 Monitoring status description
Monitoring Status
Green
The monitoring is normal.
Red
The monitoring is abnormal. Traffic switchover is automatically triggered when the status changes from normal to failed.
Yellow
The monitor initialization failed. The MAS process cannot detect the service API. In this case, confirm the configurations or contact O&M personnel.
Light gray
Monitor creation or configuration failed.
Dark gray
Invocation failed. The ETCD connection status is abnormal.
Creating an API Monitor
  1. Log in to the MAS console. On the Multi-Active Instances page, click an instance whose namespace type is Intra-city multi-active.
  2. Click the Monitor List tab and click Create Monitor.
  3. Configure the basic information, then click Next: Data Centers.
    Figure 1 Basic information configurations
    Table 2 Basic information parameters
    Monitor
    Select API Monitoring.
    Application
    Select the application.
    Monitor Name
    Customize the monitor name.
    Exception Notification
    By default, this option is disabled.
    If it is enabled,
    • Monitor and API exceptions will be sent to you in a timely manner with the Huawei Cloud SMN service. Configure a secret key first.
    • Cloud Eye is enabled by default. Ensure that the alarm rules for MAS have been created on the Cloud Eye console. For details, see Creating an Alarm Rule to Monitor an Event.
    Subject
    If Exception Notification is enabled, select a subject from the drop-down list or click Add to create a new one.
    Monitoring
    The default value is Yes. If you select No, the API gateway status will not be monitored.
  4. Configure the data centers, then click Next: Advanced.
    Figure 2 Data center configurations
    Table 3 Data center parameters
    Cloud
    Select the environment where the monitored API gateway is deployed.
    Region
    Select the regions of the API gateways.
    Connection Address
    Select HTTP or HTTPS, and enter the connection address of the API gateway.
    Request path
    Health check path of the API gateway.
    Request Methods
    Select GET, POST, DELETE, PATCH, or PUT.
    Status Code
    Set this parameter based on the actual requirements of the monitored API gateway, for example, 200.
    Request Header
    Set this parameter based on the actual requirements of the monitored API gateway.
    Encrypt the request header if it contains sensitive information.
  5. Configure the advanced settings, then click Next: Confirm.
    Figure 3 Advanced configurations
    Table 4 Advanced settings
    Retry Interval (ms)
    The interval of reconnection attempts, in milliseconds. Default value (recommended): 5000
    Value range: 1 to 300,000
    Healthy Threshold
    If the number of successful consecutive API connections reaches or exceeds the threshold, the API connection is normal.
    Default value (recommended): 2; Value range: 1 to 5
    Unhealthy Threshold
    If the number of consecutive API connection failures reaches or exceeds the threshold, the API connection is abnormal.
    Default value (recommended): 3; Value range: 3 to 10
  6. Confirm settings and click Create.
    If the created monitor is not normal, that is, its indicator is not green, its configurations or APIs may be abnormal. In this case, rectify the fault.
