- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Getting Started with MAS
- Modules
- Namespace
- Multi-Active Instances
- Application Management
- Monitor Management
- Credential Management
- Event Monitoring
- Audit Logs
- Permissions Management
MAS FAQs
- Is MAS a Product or Solution?
- Does MAS Synchronize Data in Addition to Controlling Access from Applications to Databases?
- Is MAS Like a Management Channel for Which I Need to Configure Automatic Switchover Policies?
- What Is the Automatic Switchover Mechanism? How Does MAS Implement Switchovers in Seconds?
Multi-Active DR Solution FAQs
- In the Single- or Dual-Instance Data Layer Architecture (Same Region, Multi-AZ, Traffic Distribution with API Gateway), Which Components Are Provided by MAS and Which Ones Should I Prepare?
- Can I Implement the Active-Active Solution on Any Other Services in Addition to Self-Built Cloud Services?
- How Do I Implement Database Dual-Write?
- Does the Multi-Active Architecture Have Any Requirements on My Services?
- What Are the RPO and RTO of the Multi-Active DR Solution?
- Does the Multi-Active DR Solution Have Any Network Requirements? Will Incorrect Switchover Occur If the Network is Unstable or Jitters?
- How Do I Configure Monitoring for Multi-AZ Deployment in the Same Region?
- Will MAS and API Gateway Be Deployed on Both Huawei Cloud and Our Cloud?
- MAS Usage FAQs
MAS FAQs
Introduction
MAS uses applications to isolate resources of different users in the same instance. Resources (such as MySQL and Redis monitors) created in an instance must be associated with an application. By default, IAM users can only check and manage their own applications and resources. You can use your account to check and manage all applications and resources created by IAM users under your account.
Creating an Application
- Log in to the MAS console. On the Multi-Active Instances page, click an instance to go to its console.
- Click the Applications tab, and click Create.
- Enter the application information, then click OK.
Figure 1 Creating an application
Table 1 Application parameters Parameter
Application
Customize an application name.
(Optional) Describe the application.
Switching Monitors
Create monitors for the application by referring to Monitor Management. Then, you can switch over and switch back monitors under the application.
- On the Applications tab page, click Switch Over Monitor in the row of a target application.
- On the Monitoring Status tab page in the dialog box, click Switch Over.
- Click OK.
If the target data center is abnormal but you have to switch over the monitor, select the checkbox to confirm the switchover, and click OK.
Figure 2 Switching over monitors - On the Applications tab page, click Switch Over Monitor in the row of the application. On the Monitoring Status tab page in the dialog box, click Switch Back.
Modifying an Application
- Go to the Applications tab page.
- Click Modify in the row of a target application.
Deleting an Application
- Click Delete in the row of a target application.
- Click OK.
Deleting Multiple Applications
- Go to the Applications tab page and select the target applications.
- Click Delete in the upper left corner.
- Click OK.
