SQL SPLIT Functions
SPLIT functions split a character string using a delimiter, and return the substrings.
Syntax
SELECT split_to_map(x, delimiter01, delimiter02)
SPLIT Function Statements
| Statement | Description | Example | Parameter |
| split | Splits a character string using a delimiter and returns the substrings. | split(x, delimiter,[limit]) |
| split_part | Splits a character string using a specified delimiter and returns the indexed content. | split_part(x, delimiter, part) |
| split_to_map | Splits a character string using the first delimiter, and then splits the string again using the other delimiter. | split_to_map(x, delimiter01, delimiter02) |
Examples
- split
Splits a target character string according to a specified string. limit specifies the maximum number of words to split into. If this parameter is not specified, all words are split by default.
- Example field
- Query and analysis statement
SELECT split(Id,'-'), split(Id,'-',2)
- Query and analysis result
Table 1 Query and analysis result of the split function EXPR$0
EXPR$1
["dc1dab7e","b045","4e77","bda4","914d083d1bf7"]
["dc1dab7e","b045-4e77-bda4-914d083d1bf7"]
- split_part
Splits a character string and returns the indexed content. The index starts from 0. If it is negative or greater than the number of substrings, an empty string is returned.
- split_to_map
Splits a character string using the first delimiter, and then splits the string again using the other delimiter. The result is displayed in format {"KEY1":"VALUE1","KEY2":"VALUE2"}. If a value cannot be split again, it is left blank.
- Example field
Request:request_id:"e3ac4b70c7d244f080d434e300d8065a";request_time: "1674965051000"
SELECT split_to_map(Request,';',':')
Table 3 Query and analysis result of the split_to_map function EXPR$0
{"request_id ":"e3ac4b70c7d244f080d434e300d8065a","request_time":"1674965051000"}
- Example field
