- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Granting LTS Permissions to IAM Users
- Purchasing LTS Resource Packages
- Log Management
Log Ingestion
- Overview
Using ICAgent to Collect Logs
- Overview
- Installing ICAgent (Intra-Region Hosts)
- Installing ICAgent (Extra-Region Hosts)
- Managing ICAgent
- Managing Host Groups
- Ingesting BMS Text Logs to LTS
- Ingesting CCE Application Logs to LTS
- Ingesting ECS Text Logs to LTS
- Ingesting ServiceStage Containerized Application Logs to LTS
- Ingesting ServiceStage Cloud Host Logs to LTS
- Ingesting Self-Built Kubernetes Application Logs to LTS
- Setting ICAgent Structuring Parsing Rules
Ingesting Cloud Service Logs to LTS
- Overview
- Ingesting AOM Logs to LTS
- Ingesting APIG Logs to LTS
- Ingesting CBH Logs to LTS
- Ingesting CFW Logs to LTS
- Ingesting CTS Logs to LTS
- Ingesting DDS Logs to LTS
- Ingesting DMS for Kafka Logs to LTS
- Ingesting DRS Logs to LTS
- Ingesting GaussDB(DWS) Logs to LTS
- Ingesting ELB Logs to LTS
- Ingesting Enterprise Router Logs to LTS
- Ingesting FunctionGraph Logs to LTS
- Ingesting GaussDB Logs to LTS
- Ingesting GES Logs to LTS
- Ingesting TaurusDB Logs to LTS
- Ingesting GeminiDB Logs to LTS
- Ingesting GeminiDB Mongo Logs to LTS
- Ingesting GeminiDB Cassandra Logs to LTS
- Ingesting IoTDA Logs to LTS
- Ingesting ModelArts Logs to LTS
- Ingesting MRS Logs to LTS
- Ingesting RDS for MySQL Logs to LTS
- Ingesting RDS for PostgreSQL Logs to LTS
- Ingesting RDS for SQL Server Logs to LTS
- Ingesting ROMA Connect Logs to LTS
- Ingesting SMN Logs to LTS
- Ingesting SecMaster Logs to LTS
- Ingesting OBS Files to LTS (Beta)
- Ingesting VPC Logs to LTS
- Ingesting WAF Logs to LTS
- Using APIs to Ingest Logs to LTS
- Ingesting Logs to LTS Across IAM Accounts
- Using Kafka to Report Logs to LTS
- Using Flume to Report Logs to LTS
- Log Search and Analysis
Log Visualization
- Overview
- Visualizing Logs in Statistical Charts
Visualizing Logs in Dashboards
- Creating a Dashboard
- Adding a Dashboard Filter
Dashboard Templates
- APIG Dashboard Templates
- CCE Dashboard Templates
- CDN Dashboard Templates
- CFW Dashboard Templates
- CSE Dashboard Templates
- DCS Dashboard Template
- DDS Dashboard Template
- DMS Dashboard Template
- DSL Dashboard Template
- ER Dashboard Template
- METRIC Dashboard Template
- Nginx Dashboard Templates
- VPC Dashboard Template
- WAF Dashboard Templates
- Log Alarms
- Log Transfer
- Log Processing
- Configuration Center
- Querying Real-Time LTS Traces
Best Practices
- Overview
Log Ingestion
- Collecting Logs from Third-Party Cloud Vendors, Internet Data Centers, and Other Huawei Cloud Regions to LTS
- Collecting Kubernetes Logs from Third-Party Clouds, IDCs, and Other Huawei Cloud Regions to LTS
- Collecting Syslog Aggregation Server Logs to LTS
- Importing Logs of Self-built ELK to LTS
- Collecting Zabbix Data Through ECS Log Ingestion
- Collecting Logs from Multiple Channels to LTS
- Log Transfer
- Billing
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- API Calling Examples
- Examples
APIs
- Host Group Management
- Log Group Management
- Log Stream Management
- Log Management
- Log Ingestion
- Log Transfer
- Log Collection Beyond Free Quota
- Cloud Log Structuring
- Container Log Ingestion from AOM to LTS
- Alarm Topics
- Message Template Management
- SQL Alarm Rules
- Keyword Alarm Rules
- Alarm List
- Tag Management
- Dashboard Management
- Log Charts
- Quick Search
- Multi-Account Log Aggregation
- Appendix
- SDK Reference
- Overview
- Consultation
- Log Management
Host Management
- What Do I Do If ICAgent Installation Fails in Windows and the Message "SERVICE STOP" Is Displayed?
- What Do I Do If ICAgent Upgrade Fails on the LTS Console?
- What Do I Do If I Could Not Query New Logs on LTS?
- What Do I Do If ICAgent Restarts Repeatedly After Being Installed?
- What Do I Do If ICAgent Is Displayed as Offline on the LTS Console After Installation?
- What Do I Do If I Do Not See a Host with ICAgent Installed on the LTS Console?
- How Do I Create a VPC Endpoint on the VPCEP Console?
- How Do I Obtain an AK/SK Pair?
- How Do I Install ICAgent by Creating an Agency?
Log Ingestion
- What Do I Do If LTS Cannot Collect Logs After I Configure Host Log Ingestion?
- Will LTS Stop Collecting Logs After the Free Quota Is Used Up If I Disable "Continue to Collect Logs When the Free Quota Is Exceeded" in AOM?
- What Do I Do If the CPU Usage Is High When ICAgent Is Collecting Logs?
- What Kinds of Logs and Files Does LTS Collect?
- How Do I Disable the Function of Collecting CCE Standard Output Logs to AOM on the LTS Console?
- What Log Rotation Scheme Should I Use for ICAgent to Collect Logs?
- Does LTS Use the Log4j Plug-in to Report Logs?
- How Long Does It Take to Generate Logs After Configuring Log Ingestion?
- What Do I Do If LTS Cannot Collect Logs After I Configure Log Ingestion with ICAgent?
Log Transfer
- Does LTS Delete Logs That Have Been Transferred to OBS Buckets?
- What Are the Common Causes of LTS Log Transfer Abnormalities?
- How Do I Transfer CTS Logs to an OBS Bucket?
- What Do I Do If I Cannot View Historical Data in an OBS Bucket After Transferring Data from LTS to OBS?
- What Do I Do If I Cannot Find a New Partition in a DLI Table After Logs Are Transferred to DLI?
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
- User Guide(Paris Regions)
- API Reference(Paris Regions)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- Calling APIs
- APIs
- Appendix
- Change History
- Videos
Show all
SQL Query Example
This section describes how to query ELB raw logs in LTS.
- Log in to the LTS console, and click a log stream on the Log Management page to go to the log details page.
- View logs on the Raw Logs tab page. The system obtains ELB raw logs.
- Click
in the upper right corner. On the page that is displayed, select Cloud Structuring Parsing.
- Select Structuring Template, and configure log structuring based on the ELB template. For other logs, you can select other structuring templates.
- On the Visualization tab page, enter an SQL statement in the search box.
Display of Query Results
Table
The following statement queries the host, the number of logs of each request_uri, the request body size in MB, and the ratios of 2xx, 3xx, 4xx, and 5xx responses. Then the results are displayed in a table, and sorted in descending order by the number of logs.
SELECT "router_request_uri" as "request_uri", "host", COUNT(*) as pv, round(sum(body_bytes_sent) / 1024.0 , 5) as "body_bytes_sent(MB)", round(sum(case when status >= 200 and status < 300 then 1 else 0 end ) * 100.0 / COUNT(1), 6) as "2xx ratio(%)", round(sum(case when status >= 300 and status < 400 then 1 else 0 end ) * 100.0 / count(1), 6) as "3xx ratio(%)", round(sum(case when status >= 400 and status < 500 then 1 else 0 end ) * 100.0 / count(1), 6) as "4xx ratio(%)", round(sum(case when status >= 500 and status < 600 then 1 else 0 end ) * 100.0 / count(1), 6) as "5xx ratio(%)" GROUP BY "host", "router_request_uri" ORDER BY pv DESC LIMIT 100
Bar chart
The following statement queries the number of requests for each request URL and displays the results in a bar chart, with request_uri set as the X axis and pv as the Y axis.
Line chart
The following statement displays a line chart based on the query result, with _time_ set as the X axis and QPS as the Y axis. The chart shows the queries per second (QPS) change at an interval of 5s in the query period.
select TIME_FORMAT(TIME_CEIL(TIME_PARSE(SUBSTRING(time_iso8601, 2, 25) ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_ , COUNT(*) as QPS from log group by _time_
Pie chart
The following statement queries the percentage of different values of status in the query period, and displays the results in a bar chart, with Category set to status and Value set to rm.
SELECT status, COUNT(1) AS rm GROUP BY status
Number chart
The following statement queries the total number of normal requests in the last hour and displays the results in a number chart.
SELECT count(*) AS normalRequest WHERE status = 200
