Collection Diagnosis Dashboard Templates
Collection diagnosis dashboard templates support Viewing ICAgent Collection Monitoring, Viewing Overall ICAgent Status, and Viewing ICAgent Exception Monitoring.
You must enable ICAgent diagnosis: Navigate to the Configuration Center of the LTS console, switch to the ICAgent Collection tab page, enable ICAgent Diagnosis. For details, see Setting ICAgent Collection.
- Log in to the LTS console.
- In the navigation pane, choose Dashboards.
- Choose Collection Diagnosis Dashboard Templates under Dashboard Templates and click ICAgent Collection Monitoring to view the detailed charts.
- Filter by log group ID. The associated query and analysis statement is:
select loggroup from log where report_topic = 'icagent_profile' or report_topic = 'icagent_alarm' group by loggroup
- Filter by log stream ID. The associated query and analysis statement is:
select logstream from log where report_topic = 'icagent_profile' or report_topic = 'icagent_alarm' group by logstream
- Raw Data Traffic. The associated query and analysis statement is:
SELECT case when diff [ 1 ] is null then '0' when diff [ 1 ] > 1024 and diff [ 1 ] <= 1024*1024 then concat(round(diff [ 1 ]*1.0/1024,4),' KB') when diff [ 1 ] > 1024*1024 and diff [ 1 ] < 1024*1024*1024 then concat(round(diff [ 1 ]*1.0/1024/1024,4),' MB') when diff [ 1 ] > 1024*1024*1024 and diff [ 1 ] < 1024*1024*1024*1024 then concat(round(diff [ 1 ]*1.0/1024/1024/1024,4),' GB') when diff [ 1 ] > 1024*1024*1024*1024 then concat(round(diff [ 1 ]*1.0/1024,4),' TB') else concat(round(diff [ 1 ]*1.0,2),' B') END AS "Original Traffic", case when diff [ 3 ] is null then 'No data yesterday' else round(diff [ 3 ] - 1,2) END AS "Day-on-Day" FROM ( SELECT report_topic, compare ( traffic, 86400 ) AS diff FROM ( SELECT report_topic, sum( read_bytes ) AS traffic FROM log WHERE report_topic = 'icagent_profile' GROUP BY report_topic ) GROUP BY report_topic)
- Collected Files. The associated query and analysis statement is:
select diff[1] as "Collected Files" , case when diff[3] is not null then round(diff[3] -1 ,2) else 'No data yesterday' end as "Day-on-Day" from (select compare(uv,86400) as diff from (select report_topic,count(distinct concat(file_name,host_ip)) as uv from log where report_topic = 'icagent_profile' group by report_topic) group by report_topic)
- ICAgents (Day-on-Day). The associated query and analysis statement is:
select diff[1] as "ICAgents" , case when diff[3] is not null then round(diff[3] -1 ,2) else 'No data yesterday' end as "Day-on-Day" from (select compare(uv,86400) as diff from (select report_topic,count(distinct host_ip) as uv from log where report_topic = 'icagent_profile' group by report_topic) group by report_topic)
- Data Sending Traffic. The associated query and analysis statement is:
SELECT "time", case when traffic is null then 0 else round(traffic*1.0/1024/1024,2) END AS "Sending traffic (MB)" from (SELECT time_format( time_floor ( __time, 'PT5M' ), 'yyyy-MM-dd HH:mm' ) AS "time", sum( read_bytes ) AS "traffic" FROM log WHERE report_topic = 'icagent_profile' GROUP BY "time")
- ICAgent Writes. The associated query and analysis statement is:
select time_floor(__time,'PT5M') as \"time\",sum(read_count) as \"Writes\" where report_topic = 'icagent_profile' group by \"time\"
- ICAgents. The associated query and analysis statement is:
select time_floor(__time,'PT5M') as "time" , count(distinct host_ip) as "ICAgents" where report_topic = 'icagent_profile' group by "time"
- Collected File Distribution. The associated query and analysis statement is:
SELECT file_name AS "Collection Path", host_ip AS "IP", case when traffic is null then '0' when traffic > 1024 and traffic <= 1024*1024 then concat(round(traffic*1.0/1024,2),' KB') when traffic > 1024*1024 and traffic < 1024*1024*1024 then concat(round(traffic*1.0/1024,2),' MB') when traffic > 1024*1024*1024 and traffic < 1024*1024*1024*1024 then concat(round(traffic*1.0/1024,2),' GB') when traffic > 1024*1024*1024*1024 then concat(round(traffic*1.0/1024,2),' TB') else concat(round(traffic*1.0,2),' B') END AS "Collection Traffic" FROM (SELECT file_name, host_ip, sum( read_bytes ) AS "traffic" WHERE "report_topic" = 'icagent_profile' GROUP BY file_name, host_ip)
- Choose Collection Diagnosis Dashboard Templates under Dashboard Templates and click Overall ICAgent Status to view the detailed charts.
- Active ICAgents. The associated query and analysis statement is:
select diff[1] as "Active ICAgents",case when diff[2] is not null then diff[2] else 'No data yesterday' end as "Active ICAgents Yesterday" from (select report_topic,compare(uv,86400) as diff from (SELECT report_topic,COUNT(DISTINCT ip) as uv FROM log where report_topic = 'icagent_status' group by report_topic) group by report_topic)
- Sending Delay/Times. The associated query and analysis statement is:
select time_floor(__time,'PT5M') as \"time\" , sum(\"metric.lts_cost.below_100_ms\") as \"below_100_ms\" , sum(\"metric.lts_cost.100to500ms\") as \"100to500ms\" , sum(\"metric.lts_cost.500msto1s\") as \"500msto1s\" , sum(\"metric.lts_cost.1sto10s\") as \"1sto10s\", sum(\"metric.lts_cost.10ston\") as \"10ston\" from log where \"report_topic\" = 'icagent_status' group by \"time\"
- Running Status Distribution. The associated query and analysis statement is:
select status,count(DISTINCT ip) as pv from log where report_topic = 'icagent_status' group by status
- CPU Trend. The associated query and analysis statement is:
select ip,time_floor(__time,'PT5M') as \"time\",avg(\"metric.cpu_usage\") as \"CPU usage\" from log where report_topic = 'icagent_status' and \"metric.cpu_usage\" is not null group by \"time\",ip order by \"time\"
- Overall ICAgent Status. The associated query and analysis statement is:
select host_name as "Host",ip as "IP" , version as "Version" , os as "OS" , time_format(MILLIS_TO_TIMESTAMP(ANY_VALUE("metric.start_time")),'yyyy/MM/dd HH:mm:ss ZZZ') as "Local Time When ICAgent Started to Run",avg("metric.cpu_usage") as "CPU",avg("metric.mem_used")*1.0 as "Memory (MB)",status as "Running Status" where report_topic = 'icagent_status' group by host_name,ip,version,os,status
- Choose Collection Diagnosis Dashboard Templates under Dashboard Templates and click ICAgent Exception Monitoring to view the detailed charts.
select loggroup from log where report_topic = 'icagent_profile' or report_topic = 'icagent_alarm' group by loggroup limit 10000
select logstream from log where report_topic = 'icagent_profile' or report_topic = 'icagent_alarm' group by logstream limit 10000
- Critical Errors. The associated query and analysis statement is:
select diff[1] as "Errors", case when diff[3] is not null then round(diff[3] - 1 , 2) else 'No data yesterday' end as "Errors (Day-on-Day)" from (select report_topic,compare(pv , 86400) as diff from (select report_topic,count(1) as pv from log where report_topic = 'icagent_alarm' group by report_topic) group by report_topic)
- Discarded Oversize Lines. The associated query and analysis statement is:
select diff[1] as "Discarded Lines" , case when diff[3] is not null then round(diff[3] - 1 , 2) else 'No data yesterday' end as "Discarded Lines (Day-on-Day)" from (select report_topic,compare(pv , 400) as diff from (select report_topic,count(1) as pv from log where report_topic = 'icagent_alarm' and alarm_type = 'DISCARD_BIG_LINE' group by report_topic) group by report_topic)
- Failed Requests to LTS. The associated query and analysis statement is:
select diff[1] as "Failed Requests" , case when diff[3] is not null then round(diff[3] - 1 , 2) else 'No data yesterday' end as "Failed Requests (Day-on-Day)" from (select report_topic,compare(pv , 86400) as diff from (select report_topic,count(1) as pv from log where report_topic = 'icagent_alarm' and alarm_type = 'HTTP_REQUEST_ALARM' group by report_topic) group by report_topic)
- Files with Excessive Issues. The associated query and analysis statement is:
select diff[1] as "Files with Excessive Issues" ,case when diff[3] is not null then round(diff[3] - 1 , 2) else 'Files with Excessive Issues' end as "Files with Excessive Issues (Day-on-Day)" from (select report_topic,compare(pv , 86400) as diff from (select report_topic,count(1) as pv from log where report_topic = 'icagent_alarm' and alarm_type = 'COLLECT_FILE_EXCEED' group by report_topic) group by report_topic)
- Critical Errors (Must Handle). The associated query and analysis statement is:
select TIME_FORMAT(MILLIS_TO_TIMESTAMP(ANY_VALUE(report_time/1000000)),'yyyy/MM/dd HH:mm:ss ZZ') as "Last Occurred" , loggroup as "Log Group ID" ,logstream as "Log Stream ID" , host_ip as "IP" , alarm_type as "Alarm Type", os as "System Type" , alarm_message as "Alarm Details" where report_topic = 'icagent_alarm' group by loggroup,logstream,host_ip,alarm_type,os,alarm_message limit 10000
- Details of Discarded Oversize Lines. The associated query and analysis statement is:
select TIME_FORMAT(MILLIS_TO_TIMESTAMP(ANY_VALUE(report_time/1000000)),'yyyy/MM/dd HH:mm:ss ZZ') as "Last Occurred" , loggroup as "Log Group ID" ,logstream as "Log Stream ID" , host_ip as "IP" , alarm_type as "Alarm Type", os as "System Type" , alarm_message as "Alarm Details" where report_topic = 'icagent_alarm' and alarm_type = 'DISCARD_BIG_LINE' group by loggroup,logstream,host_ip,alarm_type,os,alarm_message limit 10000
- Details of Failed Requests to LTS. The associated query and analysis statement is:
select TIME_FORMAT(MILLIS_TO_TIMESTAMP(ANY_VALUE(report_time/1000000)),'yyyy/MM/dd HH:mm:ss ZZ') as "Last Occurred" , loggroup as "Log Group ID" ,logstream as "Log Stream ID" , host_ip as "IP" , alarm_type as "Alarm Type", os as "System Type" , alarm_message as "Alarm Details" where report_topic = 'icagent_alarm' and alarm_type = 'HTTP_REQUEST_ALARM' group by loggroup,logstream,host_ip,alarm_type,os,alarm_message limit 10000
- Details of Files with Excessive Issues. The associated query and analysis statement is:
select TIME_FORMAT(MILLIS_TO_TIMESTAMP(ANY_VALUE(report_time/1000000)),'yyyy/MM/dd HH:mm:ss ZZ') as "Last Occurred" , loggroup as "Log Group ID" ,logstream as "Log Stream ID" , host_ip as "IP" , alarm_type as "Alarm Type", os as "System Type" , alarm_message as "Alarm Details" where report_topic = 'icagent_alarm' and alarm_type = 'COLLECT_FILE_EXCEED' group by loggroup,logstream,host_ip,alarm_type,os,alarm_message limit 10000
