Updated on 2025-11-18 GMT+08:00
Nginx Logs
Nginx is an open-source, high-performance HTTP server and reverse proxy, as well as an IMAP/POP3/SMTP proxy server. It features stability, extensive functions, easy-to-use configuration, and low system resource consumption. Nginx is often used to process static files, load balancing, reverse proxy, and cache. It is applicable to websites and applications of various scales.
Nginx logs are classified into two types: access_log (access log) and error_log (error log). They are useful for system monitoring, performance analysis, and troubleshooting.
  • access_log (access log): Records detailed information about client access to an Nginx server. Access logs help you learn about the IP address, accessed URL, access time, request processing time, HTTP response status code, and request header.
  • error_log (error log): records the errors and warnings encountered by the Nginx server during request processing. You can check the error logs to locate the source of a fault and rectify the fault.
Collection Method
Install ICAgent and configure ECS text log ingestion by referring to Installing ICAgent (Intra-Region Hosts) and Ingesting ECS Text Logs to LTS. Then, ICAgent will collect ECS text logs and report them to LTS.
Nginx Log Examples and Fields
This section describes the examples and fields of access logs and error logs.
Table 1 Access log fields
Example
$remote_addr
Client IP address
211.28.65.253
$remote_user
Client username
$time_local
Access time and time zone
18/Jul/2012:17:00:01 +0800
$request
Request URL and HTTP protocol
"GET /article-10000.html HTTP/1.1"
$http_host
Request address, that is, the address (IP address or domain name) entered in the browser
www.wang.com 192.168.100.100
$status
HTTP request status
200
$upstream_status
Upstream status
200
$body_bytes_sent
Size of the file sent to the client
1547
$http_referer
Source page URL
https://www.example.com/
$http_user_agent
Client browser information
"Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; SV1; GTB7.0; .NET4.0C;
$ssl_protocol
SSL version
TLSv1
$ssl_cipher
Algorithm for exchanging data
RC4-SHA
$upstream_addr
Address of the upstream server, that is, the address of the host that actually provides services
10.10.10.100:80
$request_time
Total request time
0.205
$upstream_response_time
Response time of upstream during the request process
0.002
Error log example:
2023/07/10 17:00:00 [error] 12345#12345: *1 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 192.168.1.100, server: example.com, request: "GET /api/data HTTP/1.1", upstream: "http://10.0.0.1:8080", host: "example.com
Table 2 Error log fields
Example
2023/07/10 17:00:00
Time when an error occurred
[error]
Error log
12345#12345
Process ID
*1
Connection ID
Error information, indicating that the response header fails to be received when it is read from the upstream system. The error cause is that the connection is reset by the peer end.
IP address of the client
server: example.com
Server name
Request method and path
upstream: "http://x.x.x.x:8080"
host: "example.com"
Requested host name
Log Location
You can use commands in the Nginx configuration file to set the storage location and format of access logs and error logs. Example:
http {
    log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                      '$status $body_bytes_sent "$http_referer" '
                      '"$http_user_agent" "$http_x_forwarded_for"';
    server {
        access_log  /var/log/nginx/access.log  main;
        error_log  /var/log/nginx/error.log warn;
In this example, the log_format parameter defines a log format named main, the access_log parameter in the server block specifies the location /var/log/nginx/access.log for storing access logs, error_log specifies /var/log/nginx/error.log for storing error logs, and the log level is set to warn. Nginx supports multiple log levels, including debug, info, notice, warn, error, crit, and alert.
