Updated on 2025-12-05 GMT+08:00
Kafka Logs
Kafka system logs (also called application logs or run logs) record various information generated during Kafka cluster running, such as startup and stop information, configuration loading, node connection and disconnection, and request processing.
Collection Method
Install ICAgent and configure ECS text log ingestion by referring to Installing ICAgent (Intra-Region Hosts) and Ingesting ECS Text Logs to LTS. Then, ICAgent will collect ECS text logs and report them to LTS.
Kafka Log Examples and Fields
Kafka does not directly provide the detailed format or field definition of system logs. The format or field definition may vary according to the log framework. This section uses a typical log framework, Log4j, as an example to describe some common fields.
  1. System log example
    2023-10-23 15:33:45,123 INFO [KafkaServer id=0] onBrokerStartup (KafkaServer.scala:220) starting
    2023-10-23 15:33:45,567 WARN [ReplicaManager broker=0] topic=my_topic partition=0 Broker 1 disconnected; no more in-sync replicas
    2023-10-23 15:33:46,987 ERROR [Controller id=0] onControllerFailover (KafkaController.scala:678) Error during controller failover
    java.lang.RuntimeException: Failed to elect new leader for partition [my_topic,0]
        at kafka.controller.KafkaController
    anonfun$onControllerFailover$1
    anonfun$apply$mcV$sp$1.apply$mcV$sp(KafkaController.scala:629)
    anonfun$apply$mcV$sp$1.apply(KafkaController.scala:609)
        ... (stack trace continues)
  2. Field description
    In the preceding example, the first is an informational log entry generated when KafkaServer was started. The second is a warning log entry, indicating that an in-sync replica of a partition was disconnected from the broker. The third is an error log entry, indicating that an error occurred during controller failover and an attempt to select a new leader for a partition failed.
    Table 1 Fields
    Field
    Example
    Timestamp
    Time when the log entry was generated.
    Log level
    Importance or urgency of the log entry, for example, INFO, WARN, or ERROR.
    INFO
    Thread or process information
    Context for generating logs, such as the ID of KafkaServer or the broker ID of ReplicaManager.
    [KafkaServer id=0]
    Log source
    Source function and code location of the log entry.
    Log content
    Log details, such as descriptive text, error messages, and stack traces.
    starting
Log Location
By default, Kafka system log files are stored in the logs subdirectory of the Kafka installation directory. The specific location may vary depending on your configuration. The following are common methods for locating Kafka system log files:
  1. Check the Kafka installation directory.
    Generally, the system log files are stored in a subdirectory named logs in the installation directory. For example, if Kafka is installed in /usr/local/kafka, log files may be stored in /usr/local/kafka/logs.
  2. Check the Kafka configuration file.
    Change the logs directory of Kafka in ${KAFKA_HOME}/bin/kafka-run-class.sh.
    # Log directory to use
    if [ "x$LOG_DIR" = "x" ]; then
        # LOG_DIR="$base_dir/logs"
        LOG_DIR="/data/kafka_logs"
    fi
