Updated on 2025-03-28 GMT+08:00
Elasticsearch Logs
Elasticsearch, an open-source distributed search and analytics engine, is widely for building real-time and scalable search and analytics applications. Its primary functions are to store, search for, and analyze large amount of data. Elasticsearch logs record various information throughout Elasticsearch running. There are primarily two log types:
  1. cluster-name.log (main log, named after the cluster name): records comprehensive information about all events that occurred during the ElasticSearch running, for example, a query failure or a new node being added to the cluster. These logs are important for understanding the overall running status of Elasticsearch clusters.
  2. cluster-name_index_search_slowlog.log (slow query log, named after the cluster name): When a query runs slowly (takes more than half a second), Elasticsearch generates a log to record the query. These logs are useful for analyzing and optimizing query performance.
Elasticsearch also provides other log types, such as deprecated logs (recording deprecated functions or configurations) and access logs (recording details about all query requests).
Collection Method
Install ICAgent and configure ECS text log ingestion by referring to Installing ICAgent (Intra-Region Hosts) and Ingesting ECS Text Logs to LTS. Then, ICAgent will collect ECS text logs and report them to LTS.
Elasticsearch Log Examples and Fields
  • Main log
      "log.level": "INFO",
      "@timestamp": "2023-10-23T15:46:30.123Z",
      "log.origin.file.name": "Elasticsearch.java",
      "log.origin.file.line": 123,
      "message": "version[7.17.2], pid[12345], build[default/tar/1234567/2023-10-01T12:00:00.000Z], OS[Linux/5.10.0-10-amd64/amd64], JVM[Eclipse Adoptium/OpenJDK 64-Bit Server VM/11.0.14.1/11.0.14.1+1-LTS]",
      "type": "server",
      "cluster.name": "my-cluster",
      "node.name": "node-1",
      "node.id": "abcdefg123",
      "ecs.version": "1.8.0"
      "log.level": "WARN",
      "@timestamp": "2023-10-23T15:47:00.456Z",
      "log.origin.file.name": "SlowLog.java",
      "log.origin.file.line": 456,
      "message": "[index][search_slowlog][index_name] took[5.6s], took_millis[5600], total_hits[1000], types[], stats[], search_type[QUERY_THEN_FETCH], source[...]",
      "type": "slowlog",
      "index.name": "index_name"
    Table 1 Main log fields
    Field
    Example
    log.level
    Log level, which can be INFO, WARN, or ERROR.
    INFO
    @timestamp
    Log timestamp.
    Name of the source file that generated the log entry.
    Elasticsearch.java
    Line number of the source file that generated the log entry.
    123
    message
    Actual log message content.
    type
    Log entry type, such as server, slowlog, or transport.
    server
    cluster.name
    Elasticsearch cluster name.
    my-cluster
    node.name
    Name of the Elasticsearch node for which the log was generated.
    node-1
    node.id
    ID of the Elasticsearch node for which the log was generated.
    abcdefg123
    index.name
    Name of the index associated with the log entry (available to some log entries).
    index_name
    ecs.version
    Version of Elastic Common Schema (ECS). ECS is a specification used to standardize Elasticsearch log fields.
    1.8.0
  • Slow query log
      "type": "slowlog",
      "timestamp": "2023-10-23T16:15:30,234Z",
      "level": "WARN",
      "component": "o.e.i.s.q",
      "took": "10.5s",
      "took_millis": 10500,
      "source": "{\"query\":{\"match_all\":{}}}\n",
      "shards": [
          "index": "my_index",
          "shard": "0",
          "search_type": "QUERY_THEN_FETCH",
          "total_hits": 12345,
          "status": 200,
          "forced_refresh": false,
          "request_cache": true,
          "scroll_size": 0
    Table 2 Slow query log fields
    Field
    Example
    type
    Log type.
    "slowlog" indicates a slow query log entry.
    timestamp
    Timestamp of the log entry.
    level
    Log level.
    "WARN" indicates that the log entry level is warning.
    component
    Component for which the log was generated.
    "o.e.i.s.q" indicates a specific component or module in Elasticsearch.
    cluster.name
    my-cluster
    node.name
    Name of the node for which the log was generated.
    node-1
    node.id
    ID of the node for which the log was generated.
    abcdefg123
    took
    Total query execution time, in a human-readable format.
    10.5s
    took_millis
    Total query execution time, in milliseconds.
    10500
    source
    Original query statement (in JSON format) that triggered the slow query.
    {"query":{"match_all":{}}}\n
    shards
    Shard information array involved in the slow query.
    index
    Name of the index where the shard is located.
    my_index
    shard
    Shard ID.
    0
    search_type
    Query type.
    QUERY_THEN_FETCH
    total_hits
    Total number of hits returned by the query.
    12345
    status
    HTTP status code of the query.
    200
    forced_refresh
    Whether to forcibly refresh shards.
    false
    request_cache
    Whether to use the request cache.
    true
    scroll_size
    Size of the scrolling query. If not applicable, set it to 0.
    0
