Creating a Quick Analysis Task
Monitoring keywords in logs helps you track system performance and services. For example, the number of ERROR keywords indicates the system health, and the number of BUY keywords can reflect sales volume. LTS provides quick analysis for you to obtain statistics on your specified keywords.
- The following describes constraints on fields displayed under Quick Analysis. Figure 1 Quick analysis fields
- The first 100,000 logs can be analyzed.
The purpose of quick analysis is to quickly return the distribution and change trend of field values. It does not analyze all data, but only samples.
- Logs can be filtered by query time and criteria for analysis.
Quick analysis is to analyze the logs queried by query statements. When the number of queried logs is 0, no result is displayed for quick analysis.
- Quick analysis can be used to generate query statements.
You can click an analysis result to automatically generate a query statement, query logs, and generate a new quick analysis.
- The maximum length of a field for quick analysis is 2,000 bytes.
- The distribution statistics in quick analysis field area displays the first 100 records.
- In the More Metric Info pane for analyzing a single field:
The field analysis is performed on all logs that meet the specified time range and search criteria, that is, the search results displayed on the Log Search tab page. If the number of logs in the search results is less than 100 million, the analysis is performed on all of them. If the number of logs exceeds 100 million, a sampling analysis is performed, with a maximum of 100 million logs sampled. To avoid sampling, narrow the time range or add search criteria to reduce the number of logs searched.
Figure 2 More metric info
Quick analysis is conducted on fields extracted from structured logs. Ensure that logs have been reported, structuring has been complete, and indexing has been configured before you create a quick analysis task. For details, see Using ICAgent to Collect Host Logs and Configuring Log Indexing.
If you have not configured ICAgent structuring parsing when configuring log ingestion to LTS, you can configure ICAgent or cloud configuring parsing for the target log stream separately. ICAgent structuring parsing is recommended. For details, see Configuring ICAgent Structuring Parsing.
Quick analysis is performed on a per-log-stream basis. You can create a quick analysis task as follows:
- Log in to the LTS console. The Log Management page is displayed by default.
- Click the target log group or stream to access the log details page.
- On the Log Search tab page, click
next to Quick Analysis to go to the Index Settings tab page. Under Index Fields, click Auto Configure to generate index fields automatically. Enable quick analysis for these fields. Figure 3 Creating a quick analysis task
- Click OK. After the quick analysis task is created, you can perform statistical analysis on these fields. For example, you can check the basic distribution of fields, various statistical metrics, and the top 5 value sequence chart. These tools provide in-depth insights and visualizations to help you understand and explore the data.
- Enter a field name in the search box below Quick Analysis. The search results will then be displayed, helping you quickly locate the target field.
- You can drag and drop a field to adjust its position. (This feature will be rolled out gradually to all regions.)
- abc displayed in front of a field indicates that the field is of the string type.
- 1.2 displayed in front of a field indicates that the field is of the float type.
- 123 displayed in front of a field indicates that the field is of the long type.
- {...} displayed in front of a field indicates that the field is of the JSON type.
- Set whether to hide or display fields.
- To hide a field, click
next to the field. Figure 4 Hiding a field
- To hide all fields, click
next to Fields. - To display a hidden field, click
next to the field. Figure 5 Displaying a field
- To display all fields, click
next to Hidden Fields.
- If the number of statistics records for a displayed field under Quick Analysis is 100 or more, click More to check them on the Charts tab page. The visual charts display data intuitively, enhancing analysis and understanding efficiency.
- Click
next to the target field to access the More Metric Info pane. - For a field of the numeric type, the pane displays its basic distribution (such as total number of log lines and total number of lines in the current column), statistics metrics (such as maximum, minimum, and average values), and value distribution histogram. Figure 6 More metric information of a numeric field
Table 1 Description of a numeric field Category
Basic Distribution
Total Log Lines
Total number of log lines that meet the time range and search criteria you specify on the Log Search tab page.
Lines in Current Column
Total number of log lines containing the field in the current search results.
Lines with Missing Values
Total Log Lines minus Lines in Current Column.
Total Distinct Values
Number of distinct field values in the column, calculated using the approx_distinct function.
Statistics Metrics
Max. Value
Maximum value of the field.
Min. Value
Minimum value of the field.
Avg. Value
Average value of the field.
Median
Value in the middle position after the data is sorted in ascending order.
First Quartile (Q1)
Value at the 25% position after the data is sorted in ascending order.
Third Quartile (Q3)
Value at the 75% position after the data is sorted in ascending order.
Sample Standard Deviation
Sample standard deviation of the field.
Population Standard Deviation
Population standard deviation of the field.
Kurtosis
A statistical concept that indicates the concentration degree of data distribution.
Skewness
A statistical concept that indicates the skewness of data.
Value Distribution Histogram
Statistical histogram created by dividing the value distribution into 10 intervals.
- You can click Number distribution in the upper right corner of the More Metric Info pane to access the Charts tab page. The visual charts display data intuitively, enhancing analysis and understanding efficiency.
- For a field of the string type, the pane displays its basic distribution (such as total number of log lines and total number of lines in the current column), statistics metrics (such as maximum, minimum, and average lengths), and a sequence diagram of the top 5 values. Figure 7 More metric information of a string field
Table 2 Description of a string field Category
Basic Distribution
Total Log Lines
Missing Value Ratio
Lines with Missing Values divided by Total Log Lines.
Distinct Value Ratio
Total Distinct Values divided by Total Log Lines.
Statistics Metrics
Max. Characters
Maximum number of characters in the field value.
Min. Characters
Minimum number of characters in the field value.
Avg. Characters
Average number of characters in the field value.
Sequence Diagram of Top 5 Values
Trend chart showing how the top 5 values from the specified time range change over time.
- You can click Field distribution in the upper right corner of the More Metric Info pane to access the Charts tab page. The visual charts display data intuitively, enhancing analysis and understanding efficiency.
- On the More Metric Info pane, click a blue parameter value to access the Charts tab page and generate the corresponding SQL query statement. In this way, you can check the distribution and change trend of field values more intuitively. For details, see SQL Functions and Visualizing Logs in Statistical Charts.
