Updated on 2026-02-11 GMT+08:00
Ingesting CFW Logs to LTS
LTS can collect logs from CFW. It also enables real-time, efficient, and secure analysis and processing of a vast volume of collected logs.
For details, see Configuring CFW Log Ingestion to LTS.
  1. Log in to the LTS console.
  2. In the navigation pane, choose Log Ingestion > Ingestion Center. On the displayed page, select Cloud services under Types. Hover the cursor over the CFW card and click Ingest Log (LTS) to access the configuration page.
  3. Select a log stream.
    1. Select a log group from the Log Group drop-down list. If there are no desired log groups, click Create Log Group to create one.
    2. Select a log stream from the Log Stream drop-down list under Record Attack Log. If there are no desired log streams, click Create Log Stream to create one.
    3. Select a log stream from the Log Stream drop-down list under Record Access Log. If there are no desired log streams, click Create Log Stream to create one.
    4. Select a log stream from the Log Stream drop-down list under Record Traffic Log. If there are no desired log streams, click Create Log Stream to create one.
    5. Click Next: Configure CFW. For details, see Configuring Logs.
  4. Click Configure CFW.
  5. Click Next: Configure Log Stream.
    Table 1 Log stream parameters
    Auto Structure and Index
    If this function is enabled, the structuring for the log stream is based on the CFW system template, and the indexing enables quick analysis for all parsed CFW fields. Enabling structuring and indexing is required for SQL analysis of CFW logs with visual charts.
    Auto Add Tag log_type=cfw_attack, log_type=cfw_access, log_type=cfw_flow
    If this option is enabled, tags log_type=cfw_attack, log_type=cfw_access, and log_type=cfw_flow are automatically added to the log stream, and the CFW dashboard template can then match this log stream.
    Auto Create Dashboard
    If this option is enabled, a CFW dashboard is automatically created for the log stream.
  6. Click Submit. The created ingestion configuration will be displayed on the Ingestion Management page.
