Configuring Log Content Delimiters
You can configure delimiters to split log content into words, so you can search for logs by these words. LTS has preconfigured the following delimiters:
, '";=()[]{}@&<>/:\\?\n\t\r If the default delimiters cannot meet your needs, you can set custom delimiters.
Precautions
- Your custom delimiters are applicable only to the log events generated after the delimiters are configured.
- Delimiters configured on the Delimiters tab page take effect for all log streams in the current region. To configure delimiters for a single log stream, configure them on the Index Settings tab page. For details, see Configuring Log Indexing.
- Log in to the LTS console.
- Choose Configuration Center in the navigation pane and click the Delimiters tab.
- Configure delimiters. You can configure delimiters in either of the following ways. If you use both ways, the delimiters configured in the two ways will all take effect.
- Common Delimiters: Click Edit and enter custom delimiters in the text box.
- ASCII Delimiters: Click Edit > Add ASCII Delimiter, and enter ASCII values by referring to ASCII Table.
- Preview the parsing result.
Enter log content in the text box and click Preview.
- Check whether the parsing result is correct. If it is correct, click Save.
You can click Reset to restore the default delimiters.
ASCII Table
| ASCII Value | Character | ASCII Value | Character | ASCII Value | Character | ASCII Value | Character |
| 0 | NUL (Null) | 32 | (Space) | 64 | @ | 96 | ` |
| 1 | SOH (Start of heading) | 33 | ! | 65 | A | 97 | a |
| 2 | STX (Start of text) | 34 | " | 66 | B | 98 | b |
| 3 | ETX (End of text) | 35 | # | 67 | C | 99 | c |
| 4 | EOT (End of transmission) | 36 | $ | 68 | D | 100 | d |
| 5 | ENQ (Enquiry) | 37 | % | 69 | E | 101 | e |
| 6 | ACK (Acknowledge) | 38 | & | 70 | F | 102 | f |
| 7 | BEL (Bell) | 39 | ' | 71 | G | 103 | g |
| 8 | BS (Backspace) | 40 | ( | 72 | H | 104 | h |
| 9 | HT (Horizontal tab) | 41 | ) | 73 | I | 105 | i |
| 10 | LF (Line feed) | 42 | * | 74 | J | 106 | j |
| 11 | VT (Vertical tab) | 43 | + | 75 | K | 107 | k |
| 12 | FF (Form feed) | 44 | , | 76 | L | 108 | l |
| 13 | CR (Carriage return) | 45 | - | 77 | M | 109 | m |
| 14 | SO (Shift out) | 46 | . | 78 | N | 110 | n |
| 15 | SI (Shift in) | 47 | / | 79 | O | 111 | o |
| 16 | DLE (Data link escape) | 48 | 0 | 80 | P | 112 | p |
| 17 | DC1 (Device control 1) | 49 | 1 | 81 | Q | 113 | q |
| 18 | DC2 (Device control 2) | 50 | 2 | 82 | R | 114 | r |
| 19 | DC3 (Device control 3) | 51 | 3 | 83 | S | 115 | s |
| 20 | DC4 (Device control 4) | 52 | 4 | 84 | T | 116 | t |
| 21 | NAK (Negative acknowledge) | 53 | 5 | 85 | U | 117 | u |
| 22 | SYN (Synchronous idle) | 54 | 6 | 86 | V | 118 | v |
| 23 | ETB (End of transmission block) | 55 | 7 | 87 | W | 119 | w |
| 24 | CAN (Cancel) | 56 | 8 | 88 | X | 120 | x |
| 25 | EM (End of medium) | 57 | 9 | 89 | Y | 121 | y |
| 26 | SUB (Substitute) | 58 | : | 90 | Z | 122 | z |
| 27 | ESC (Escape) | 59 | ; | 91 | [ | 123 | { |
| 28 | FS (File separator) | 60 | < | 92 | \ | 124 | | |
| 29 | GS (Group separator) | 61 | = | 93 | ] | 125 | } |
| 30 | RS (Record separator) | 62 | > | 94 | ^ | 126 | ~ |
| 31 | US (Unit separator) | 63 | ? | 95 | _ | 127 | DEL (Delete) |
