CTS Auditing
With CTS, you can log operations related to LakeFormation, making it easier to search, audit, and trace in the future.
Operations Recorded by CTS
Operation |
Resource Type |
Trace Name |
Creating a catalog |
Catalog |
createCatalog |
Deleting a catalog |
Catalog |
dropCatalog |
Modifying a catalog |
Catalog |
alterCatalog |
Creating a database |
Database |
createDatabase |
Deleting a database |
Database |
dropDatabase |
Modifying a database |
Database |
alterDatabase |
Creating a data table |
Table |
createTable |
Deleting a data table. |
Table |
dropTable |
Modifying a data table. |
Table |
alterTable |
Clearing the data in a table |
Table |
truncateTable |
Creating a function |
Function |
createFunction |
Modifying the attributes of a function |
Function |
alterFunction |
Deleting a function |
Function |
dropFunction |
Creating an instance |
instance |
createInstance |
Modifying an instance |
instance |
updateInstance |
Deleting an instance |
instance |
deleteInstance |
Granting permissions |
Access |
grantAccess |
Revoking authorization |
Access |
revokeAccess |
Updating statistics about a specified column in a table |
TableColumnStatistic |
setTableColumnStatistics |
Deleting statistics about a specified column in a table |
deleteTableColumnStatistics |
Adding column restrictions for creating tables in batches |
TableConstraint |
addConstraints |
Deleting a column restriction |
TableConstraint |
deleteConstraints |
Adding partition information in batches |
Partition |
addPartitions |
Modifying partition information in batches |
Partition |
alterPartitions |
Deleting partition information in batches |
Partition |
dropPartitions |
Clearing list information in batches |
Partition |
truncatePartitions |
Setting partition column statistics in batches |
PartitionColumnStatistic |
setPartitionColumnStatistics |
Deleting partition column statistics |
deletePartitionColumnStatistics |
For details about how to enable CTS and view real-time traces, see Cloud Trace Service Getting Started.
Viewing an Audit Log
You can query the LakeFormation traces on the CTS console.
For details about the restrictions and more operations, see Querying Real-Time Traces.
- Log in to the CTS console.
- In the navigation pane, choose Trace List.
- Above the list, select a time and search for LakeFormation by trace source. You can view all audit traces of LakeFormation in the corresponding time period.
You can also combine one or more filter criteria as required.
- Click the trace name to view its details.
- Click Export above the list to export all traces of the query result.
- For details about key fields in a trace, see Trace Structure and Example Traces.
Figure 1 Viewing LakeFormation audit traces
