- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- Developer Guide
API Reference
- Before You Start
- API Overview
- API Calling
API
Console
- Instance Management
- Job Management
Service Authorization Management
- Granting Permissions for Accessing Other Cloud Services
- Querying Cloud Service Access Permissions
- Registering a Tenant Agreement
- Querying whether a Tenant Has Registered an Agreement
- Deleting a Tenant Agreement
- Querying the Current System Agreement
- OBS Management
- Access Management
- Specification Management
- Quota Management Service
- Tag Management Service
- Agency Management
- Alarm Management
- Metadata Management
- Location
LakeCat
- Function Management
- Catalog Management
- Database Management
- Table Management
- Data Table Statistics
- Zone-based Management
- Partition Statistics
- Authorization Management
- User Group Management
- Metadata Statistics
Role Management
- Creating a Role
- Listing Roles on Different Pages by Condition
- Deleting a Role
- Obtaining a Role
- Modifying a Role
- Listing All Role Names
- Querying the Users or User groups Under a Role
- Adding One or More Users or User Groups to a Role
- Removing One or More Users or User Groups from a Role
- Updating the Entities in a Role
- Credential Management
- Configuration Management
- User
Console
- Application Examples
- Appendix
- FAQs
Show all
Creating a Custom Policy
Custom policies can be created for LakeFormation to supplement system-defined policies.
To create a custom policy, choose either visual editor or JSON.
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Create a policy in the JSON format from scratch or based on an existing policy.
For details, see Creating a Custom Policy.
The following section contains examples of common LakeFormation custom policies.
Example Custom Policies
- Example 1: Grant the read-only permission on LakeFormation in batches to a user.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "lakeformation:instance:describe", "lakeformation:role:describe", "lakeformation:policy:export", "lakeformation:group:describe", "lakeformation:function:describe", "lakeformation:catalog:describe", "lakeformation:policy:describe", "lakeformation:table:describe", "lakeformation:database:describe" ] } ] }
- Example 2: Deny data deletion.
A policy with only "Deny" permissions must be used together with other policies. If the permissions granted to an IAM user contain both "Allow" and "Deny", the "Deny" permissions take precedence over the "Allow" permissions.
The following method can be used if you need to assign permissions of the Admin policy to a user but you want to prevent the user from deleting LakeFormation catalogs, databases, and tables. Create a custom policy for denying deletion, and attach both policies to the group to which the user belongs. Then, the user can perform all operations on catalogs, databases, and tables except deleting them.
Example policy denying MRS cluster deletion:
{ "Version": "1.1", "Statement": [ { "Effect": "Deny", "Action": [ "lakeformation:database:drop", "lakeformation:table:drop", "lakeformation:catalog:drop" ] } ] }
- Example 3: Create a custom policy that contains the actions of multiple services.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "obs:bucket:CreateBucket" ] }, { "Effect": "Allow", "Action": [ "lakeformation:table:create", "lakeformation:database:create", "lakeformation:catalog:create" ] } ] }
