Experiencing KooSearch Document Search
With a knowledge base that contains the necessary knowledge in it, you can try the Document Search service on the KooSearch Experience Platform.
- KooSearch has been enabled.
- A knowledge base has been created, and knowledge has been uploaded to it.
- The knowledge base that you plan to use to experience the Document Q&A service is Enabled.
Accessing the KooSearch Console
- Log in to the CSS management console.
- In the navigation pane on the left, choose KooSearch > KooSearch Document Q&A.
- Select a document Q&A service created earlier, and click Q&A in the Operation column to switch to the KooSearch console.
Selecting a Knowledge Base
- On the KooSearch console, choose Experience Platform from the left navigation pane.
- Click
in the upper right corner. In the displayed Sources dialog box, select a knowledge base and click OK. You can select a single knowledge base or select multiple ones after toggling on
KooSearch will search for answers in response to your questions in the selected knowledge base.
Configuring Search Settings
- On the Experience Platform page, click
in the upper right corner. On the Configure page, configure the search settings. For details, see Configuring Q&A Settings.
- Click OK.
Experiencing Document Search
- In the upper right corner of the Experience Platform, click Search.
- Enter a question in the text box and click
Click a search result to check more details. Click Full text to check the original document.
The system currently cannot properly display content from a DOCX document that has multiple columns.
