Help Center/ Cloud Search Service_KooSearch/ User Guide/ Managing KooSearch Document Q&A Service/ Configuring Cluster Routes for KooSearch Document Q&A Service
Updated on 2025-08-14 GMT+08:00
Configure cluster routes to allow a KooSearch service to proactively connect to the public network or enable cross-network KooSearch API access.
  1. Go to the details page of a KooSearch service.
    1. Log in to the CSS management console.
    2. In the navigation pane on the left, choose KooSearch > KooSearch Document Q&A.
    3. Click the name of the target service to go to the service details page.
  2. Click Add Route next to Cluster Route.
  3. In the displayed dialog box, configure the route information.
    Table 1 Configuring cluster routing
    IP Address
    Enter the first 16 or 24 bits (or first two or three octets) of the remote server's IP address. For example, if the source IP address is 192.168.1.1, enter 192.168.0.0 in the text box.
    Subnet Mask
    Enter the subnet mask of the IP address.
    • If the first 16 bits of the IP address are provided, enter 255.255.0.0 in Subnet Mask.
    • If the first 24 bits of the IP address are provided, enter 255.255.255.0 in Subnet Mask.
    The subnet mask must cover the IP network segment. That is, after the subnet mask and IP address are converted into binary values, the number of 0s at the end of the IP address must be greater than the number of 0s at the end of the subnet mask.
  4. Click OK to complete the cluster routing configuration.
  5. Click View Route next to Cluster Route. In the View Route dialog box, check the updated route information.
