- What's New
- Billing
- Getting Started
- User Guide
- API Reference
- FAQs
- Videos
Anti-screen Capture
The Anti-screen Capture page displays your purchased cloud phone instances. You can enable or disable the anti-screen capture function for them.
- Click the cloud phone name to check information such as the ID, region, flavor, and username. Enter a keyword in the search box or click
next to Status to filter data.
- Click
on the right to search for instances that meet the criteria.
- Click
in the upper right corner to refresh all instances.
- By default, the list displays information such as the cloud phone name/ID, region, flavor, and username. Click
in the upper right corner above the list to customize columns. For details about mandatory and optional parameters, see Table 1.
Table 1 Parameters Parameter
Cloud Phone Name/ID
(Mandatory) Name of a cloud phone defined when you purchased the cloud phone and ID that the system assigns to a cloud phone instance.
Region
(Mandatory) Location of the physical data center of cloud phones. Different regions indicate different physical distances between a physical data center and users, as well as different levels of network latency.
Flavors
(Mandatory) Flavor of the cloud phone, including the vCPU and memory.
Username
(Optional) Member name configured by the administrator.
Status
(Mandatory) Task execution status, which is Enabled or Disabled.
Enabling Anti-screen Capture
You can enable the anti-screen capture function for cloud phones.
- Sign in to the KooPhone console.
- In the navigation pane, choose Security Management > Anti-screen Capture.
- In the instance list, select one or more cloud phone instances and click Enable in the upper left corner above the list.
- On the displayed page, confirm the cloud phone instance information and click OK.
- When the message "Enabled" is displayed, click OK.
Disabling Anti-screen Capture
You can disable the anti-screen capture function for cloud phones.
- In the instance list, select one or more cloud phone instances and click Disable in the upper left corner above the list.
- When the message "Disabled" is displayed, click OK.
