Help Center/ KooPhone/ User Guide/ Signing In to and Using UNI Cloud Terminal/ Accessing a Cloud Phone Desktop and Using the Cloud Phone
Updated on 2025-11-27 GMT+08:00
After installing and logging in to the cloud phone, tap Enter CloudPhone on the app home screen to access the cloud phone desktop and start using the cloud phone.
Checking and Using the Desktop Floating Bubble
The desktop shortcut menu is hidden in the desktop floating bubble. You can drag the floating bubble to adjust its position, tap it to open the shortcut menu to check the network signal of the cloud phone, or perform the following operations:
  • Enable Voice Keep to keep playing audio when audio and video apps run in the background.
  • Enable Silent to mute the cloud phone.
  • Enable PiP to perform background operations with a small window running in the foreground after exiting the KooPhone app.
  • Tap Navigation to set the navigation mode of the cloud phone.
  • Tap Home to return to the cloud phone desktop.
  • Tap Restart to restart the cloud phone.
  • Tap Sign Out to return to the app home screen.
Downloading Game, Office, and Entertainment Apps
The cloud phone is pre-installed with system apps such as clock, album, camera, and calendar. To download game, office, entertainment, and other apps, you are advised to search for the target apps in AppGallery, and download and install them.
