Setting Cloud Phones Permissions
When using the cloud phone, you can grant permissions to facilitate use.
Tap the profile picture in the upper left corner of the app home screen to enter the personal center and tap to set cloud phone permissions.
- Read Clipboard Content
Allows you to paste content copied from a physical device to a cloud phone. You are advised to grant this permission to synchronize clipboard content between a physical device and a cloud phone.
- Obtain Storage
Allows apps on a cloud phone to read or store information.
- Obtain Phone
Allows you to make calls and send SMS messages on a cloud phone.
- Authorize access to
Retains records of calls made on a cloud phone in the cloud phone instead of in a physical device.
- Obtain Location
Obtains accurate location information for apps or functions such as navigation and positioning.
Tap Go to Settings to set more permissions required by the client.
