Help Center/ CloudDevice/ User Guide/ Assigning and Managing General-Purpose Cloud Phones/ Assigning a General-Purpose Cloud Phone to a Member
Updated on 2025-04-03 GMT+08:00
After buying a cloud phone instance, you need to assign it to a user so that the user can use the cloud phone. This section describes how to unbind or bind a user on the console.
  1. Sign in to the KooPhone console.
  2. In the navigation pane on the left of the general-purpose cloud phone, click Cloud Phone Instances.
  3. In the instance list, locate the target cloud phone instance.
    • Unbinding a user: Click Unbind User in the Operation column on the right to unbind the cloud phone instance from the user. The unbinding is successful, and the user's mobile number receives an email.
      Unbinding the user will initialize the cloud phone instance and clear personal data.
    • Binding a user: Click Bind User in the Operation column on the right.
      1. On the displayed page, select an organization and a user, and click OK. You can enter a username or account to search for a user.
      2. Confirm the user information and click OK.
