Updated on 2025-11-27 GMT+08:00
Powering off an Instance
This section describes how to power off an instance on the console.
Only instances in the Running status can be powered off.
  1. Log in to the KooPhone console. The KooPhone overview page is displayed.
  2. In the navigation pane, choose UNI Cloud Terminal > Instance Management.
  3. Choose either of the following power-off modes:
    • In the instance list, select one or more target instances and click Power Off in the upper left corner above the list.
    • In the instance list, locate a target instance and choose More > Power Off in the Operation column on the right.
  4. In the displayed dialog box, click OK.
Result
The instance status is Powered off.
