Help Center/
KooPhone/
User Guide/
Assigning and Managing UNI Cloud Terminal Instances/
Managing Instances/
Powering on an Instance
Updated on 2025-11-27 GMT+08:00
This section describes how to power on an instance on the console.
Only instances in the Stopped or Powered off status can be powered on.
- Log in to the KooPhone console. The KooPhone overview page is displayed.
- In the navigation pane, choose UNI Cloud Terminal > Instance Management.
- Choose either of the following power-on modes:
- In the instance list, select one or more target instances and click Power On in the upper left corner above the list.
- In the instance list, locate a target instance and choose More > Power On in the Operation column on the right.
Result
The instance status is Running.
Parent topic: Managing Instances
