Using IAM Roles or Policies to Grant Access to KooDrive
System-defined permissions in "Role/Policy-based Authorization" provided by Identity and Access Management (IAM) let you control access to KooDrive. With IAM, you can:
- Create IAM users for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing KooDrive resources.
- Grant users only the permissions required to perform a given task based on their job responsibilities.
- Entrust a Huawei Cloud account or a cloud service to perform efficient O&M on your KooDrive resources.
If your Huawei Cloud account meets your permissions requirements, you can skip this section.
Figure 1 shows the process flow of role/policy-based authorization.
Before granting permissions to user groups, learn about system-defined permissions in Role/Policy-based Permissions Management for KooDrive. To grant permissions for other services, learn about all system-defined permissions supported by IAM.
Process Flow
- On the IAM console, create a user group and grant it permissions.
Create a user group on the IAM console and assign the KooDrive FullAccess permission to the group.
- Create an IAM user and add it to the created user group.
On the IAM console, create a user and add it to the user group created in 1.
- Log in as the IAM user and verify permissions.
In the authorized region, perform the following operations:
- Choose KooDrive from the service list. On the KooDrive console, click Enable Now in the upper right corner. If KooDrive cannot be enabled and a message appears indicating that you need to switch from an IAM account to a Huawei account, the KooDrive FullAccess policy is in effect.
After the policy takes effect, the following operations cannot be performed:
- Subscribing to the service
- Unsubscribing from the service
- Logging in to the KooDrive service plane
Example Custom Policies
Custom policies can be created to supplement the system-defined policies of KooDrive. Currently, KooDrive supports only one permission. There is no need to create custom policies. Creating custom policies may result in duplicate policies.
