Space Management
Updated on 2025-03-07 GMT+08:00
A system administrator and department administrator can allocate spaces to departments or individuals, and modify or delete department or individual spaces. A system administrator can also manage group spaces, including modifying the space size, managing group members, and disabling or dismissing group spaces.
Managing Team Space
A system administrator can manage the spaces of all teams. A department administrator can manage the space of only the department.
  1. Sign in to the KooDrive service plane as a system administrator.
    Only a HUAWEI ID can be used to log in to the KooDrive service plane.
  2. Click Console on the top of the page.
  3. In the navigation pane, choose Space Management. On the displayed page, click the Dept Space tab. The department space list is displayed.
  4. Manage department spaces by referring to Table 1.
    Table 1 Managing department spaces
    Operation
    Allocating a department space
    Allocate Space is displayed only for departments without a space.
    1. Enter a department name in the search box of the department space list. Fuzzy search is supported.
    2. In the search result list, click Allocate Space in the Operation column.
    3. In the Allocate Space dialog box, set the department space size.
    4. Click Unable to delete to set initial permissions for members. Unable to delete is the default permissions setting. Different permissions names are displayed for different permissions settings.
    5. Click Permissions Template and select a custom template added on the Permissions Templates page or a preset template. You can also click Custom to configure the permissions types.
    6. After the setting is complete, click OK.
      • The default size of the department space is set during cloud space instance configuration. You can change the size.
      • The department space size cannot be 0 GB.
      • You can also select a department (only one department can be selected) and click Allocate Space above the list.
    Modifying a department space
    2. In the search result list, click Modify Storage in the Operation column.
    3. In the Modify Space Storage dialog box, modify the department space size.
    4. After the setting is complete, click OK.
      • You can set the team space size.
      • The new department space size cannot be smaller than the used department space size.
      • You can also select a department (only one department can be selected) and click Modify Storage above the list.
    Managing permissions
    2. In the search result list, click Manage Permissions in the Operation column.
    3. In the Manage Permissions dialog box, select a permissions type or enter a user name to quickly search for users. Select one or more users and click Change Permissions. For a single user, click next to the user.
    4. Click Permissions Template and select a custom template added on the Permissions Templates page or a preset template. You can also click Custom to configure the permissions types.
    5. After completing the settings, click OK.
    For details about permissions types, click Permission Descriptions in the upper right corner of the page.
    Disabling a department space
    2. In the search result list, click Disable Space in the Operation column.
    3. In the Disable Space dialog box, read the impact of disabling the space and click OK to disable it.
      • After the department space is disabled, resources in it are temporarily frozen and cannot be accessed.
      • You can also select multiple departments and click Disable Space above the list.
    Enabling a department space
    2. In the search result list, click Enable Space in the Operation column.
    You can also select multiple departments and click Enable Space above the list.
    Deleting a department space
    2. In the search result list, click Delete Space in the Operation column.
    3. In the Delete Space dialog box, read the impact of space deletion.
      • If files exist in the selected space, enter DELETE in the displayed dialog box, select I have read and accept the terms above, and click OK.
      • If no space has not been allocated to the department or no file exists in the space, click OK.
    • You can also select multiple departments and click Delete Space above the list.
    • All resources under deleted spaces will be deleted. You are advised to migrate resources before space deletion.
Managing Individual Spaces
A system administrator can manage individual spaces of all users. A department administrator can manage individual spaces of users only under the department.
  3. In the navigation pane, choose Space Management. On the displayed page, click the Individual Space tab. The individual space list is displayed.
  4. Manage individual spaces by referring to Table 2.
    Table 2 Managing individual spaces
    Operation
    Allocating an individual space to a user
    Allocate Space is displayed only for users without a space.
    1. Select the department to which the target user belongs from the drop-down list box above the individual space list, and enter the username in the search box. Fuzzy search is supported.
    3. In the Allocate Space dialog box, set the individual space size and click OK.
      • The default size of the individual space is set during cloud space instance configuration. You can change the size.
      • The individual space size cannot be 0 GB.
      • You can also select a user (only one user can be selected) and click Allocate Space above the list.
    Modifying an individual space
    3. In the Modify Space Storage dialog box, change the individual space size and click OK.
      • You can set the individual space size.
      • The new individual space size cannot be smaller than the used individual space size.
      • You can also select a user (only one user can be selected) and click Modify Storage above the list.
    Disabling an individual space
    You can also select multiple users and click Disable Space above the list.
    Enabling an individual space
    You can also select multiple users and click Enable Space above the list.
    Deleting an individual space
      • If no space has not been allocated to the user or no file exists in the space, click OK.
    • You can also select multiple users and click Delete Space above the list.
Managing Group Spaces
A system administrator can query and manage all groups in their enterprise. Files in the group space cannot be shared. Therefore, permissions templates do not contain the sharing option.
  3. In the navigation pane, choose Space Management. On the displayed page, click the Group Space tab. The group space list is displayed.
  4. Manage group spaces by referring to Table 3.
    Table 3 Managing group spaces
    Operation
    Adding group members
    1. Enter a group name in the search box of the group space list. Fuzzy search is supported.
    2. In the search result list, click Manage Member in the Operation column.
    3. Click Add Member.
    4. Click Unable to delete to set permissions for members. Unable to delete is the default permissions setting. Different permissions names are displayed for different permissions settings.
      Figure 1 Adding members
    6. On the Users, Depts, or User Groups tab, search for and select the target members to be added, and click .
      • Fuzzy search by name is supported for users, departments, and user groups.
      • A group can have up to 200 members.
      • If no user group is available, create one by referring to User Group Management.
      • The default role of the added users is common member.
    7. To modify the permissions of a user that has been added to the list on the right, click next to the user.
      To remove a selected user, search for and select the user in the area of selected members, and click .
    8. Click OK.
    Changing the owner
    3. Select the new owner from the member list.
    4. Click Change Owner.
    By default, the group creator is the group owner. The group owner can change the role of a group member. After the group owner designates a new owner, the original owner becomes a common user with default member permissions. If the default permission is Unable to delete, unless it is changed.
    Changing permissions
    3. Select one or more users and click Change Permissions. For a single user, click next to the user.
    5. After the setting is complete, click OK.
    Deleting members
    3. Select members in the member list and click Delete Member. The Delete Member dialog box is displayed.
    4. Click OK to delete the members.
    Modifying the space storage
    3. In the displayed dialog box, change the group space size and click OK.
      • You can set the group space size.
      • The new group space size cannot be smaller than the used group space size.
    Disabling a group space
    2. In the search result list, choose More > Disable Space in the Operation column.
      • After the group space is disabled, resources in it are temporarily frozen and cannot be accessed.
      • You can also select multiple groups and click Disable Space above the list.
      • To enable the group space again, choose More > Enable Space in the Operation column of the disabled group space.
    Dismissing a group space
    2. In the search result list, choose More > Dismiss Space in the Operation column.
    3. In the Dismiss Group Space dialog box, read the impact of the dismissal, enter DISMISS in the dialog box, select I have read and accept the terms above, and click OK to dismiss the group space.
