Configuring Automatic Topic Creation
Automatic Topic Creation indicates that a topic will be automatically created when a message is produced in or consumed from a topic that does not exist. By default, the topic has parameters listed in Table 1.
The following parameters of cluster instances can be changed on the Instance > Parameters page: log.retention.hours (retention period), default.replication.factor (replica quantity), or num.partitions (partition quantity). The value will be used in later topics that are automatically created.
For example, assume that num.partitions is changed to 5, an automatically created topic has parameters listed in Table 1.
Parameter |
Default Value (Single-node) |
Default Value (Cluster) |
Modified To (Cluster) |
Partitions |
1 |
3 |
5 |
Replicas |
1 |
3 |
3 |
Aging Time (h) |
72 |
72 |
72 |
Synchronous Replication |
Disabled |
Disabled |
Disabled |
Synchronous Flushing |
Disabled |
Disabled |
Disabled |
Message Timestamp |
CreateTime |
CreateTime |
CreateTime |
Max. Message Size (bytes) |
10,485,760 |
10,485,760 |
10,485,760 |
Notes and Constraints
Enabling or disabling automatic topic creation may restart the instance.
- Log in to the Kafka console.
- Click
in the upper left corner to select the region where your instance is located.
- Click the name of the desired Kafka instance to go to the Overview page.
- In the Instance Information area, click
or
next to Automatic Topic Creation. The Confirm dialog box is displayed.
- Click OK. The Background Tasks page is displayed. Automatic topic creation has been configured when the task is in the Successful state.
Related Documents
- To configure automatic topic creation by calling an API, see Configuring Automatic Topic Creation.
- To manually create a topic, see Creating a Kafka Topic.
