Exporting the Kafka Topic List
Export the topic list on the console. Batch export is supported.
A topic has been created.
- Log in to the Kafka console.
- Click
in the upper left corner to select the region where your instance is located.
- Click the desired instance to go to the instance details page.
- In the navigation pane, choose Instance > Topics.
- Export the topic list in either of the following ways:
- Select the desired topics and choose Export > Export selected data to an XLSX file to export specified topics.
- Choose Export > Export all data to an XLSX file to export all topics.
The topic list contains the following information: topic name, number of partitions, number of replicas, aging time, message timestamp, max. message size, description, and whether synchronous replication and flushing are enabled.
