Viewing Sample Code of Kafka Production and Consumption
Distributed Message Service for Kafka allows you to view sample Java, Go, and Python code of producing and consuming messages on the console. You can quickly complete Kafka client integration.
- Log in to the Kafka console.
 - Click
 in the upper left corner to select the region where your instance is located. - Click the desired instance to go to the instance details page.
 - In the navigation pane, choose Instance > Topics.
 - Click View Sample Code. The Sample Code dialog box is displayed.
The sample code is available in Java, Go, and Python, and PlainText, SASL_SSL, and SASL_PLAINTEXT access modes.
- PlainText: Accessing the Kafka instance in plaintext.
 - SASL_SSL: Accessing the Kafka instance in ciphertext with SASL authentication. SASL authentication uses PLAIN or SCRAM-SHA-512.
 - SASL_PLAINTEXT: Accessing the Kafka instance in plaintext with SASL authentication. SASL authentication uses PLAIN or SCRAM-SHA-512.
