Querying the Kafka Consumer Group List
After a consumer group is created, you can view its configuration and status.
Viewing the Consumer Group List (Console)
- Log in to the console.
- Click in the upper left corner to select a region.
Select the region where your Kafka instance is located.
- Click and choose Middleware > Distributed Message Service (for Kafka) to open the console of DMS for Kafka.
- Click the desired Kafka instance to view its details.
- In the navigation pane, choose the Consumer Groups tab.
The consumer group name, status, Coordinator (ID), and description are displayed. Coordinator (ID) indicates the broker where the coordinator component is located. The consumer group status can be:
- DEAD: The consumer group has no member or metadata.
- EMPTY: The consumer group has metadata but has no member.
- PREPARING_REBALANCE: The consumer group is to be rebalanced.
- COMPLETING_REBALANCE: All members have joined the consumer group.
- STABLE: Members in the consumer group can consume messages normally.
Figure 1 Consumer group list
- (Optional) To query a consumer group, enter a consumer group name or status, Coordinator (ID), number of accumulated messages, description, or keyword, then press Enter.
- (Optional) To refresh the consumer group list, click in the upper right corner.
Viewing the Consumer Group List (Kafka CLI)
- For a Kafka instance with ciphertext access disabled, run the following command in the /bin directory of the Kafka client:
./kafka-consumer-groups.sh --bootstrap-server ${connection-address} --list
Parameter description: connection-address indicates the Kafka instance address, which can be obtained in the Connection area on the Basic Information page on the Kafka console.
Example:
[root@ecs-kafka bin]# ./kafka-consumer-groups.sh --bootstrap-server 192.168.xx.xx:9092,192.xx.xx.212:9092,192.xx.xx.147:9092 --list test __consumer-group-dial-test [root@ecs-kafka bin]#
- For a Kafka instance with ciphertext access enabled, do as follows:
- (Optional) Modify the client configuration file.
View Security Protocol in the Connection area on the Basic Information page on the Kafka console. The configuration settings vary depending on the protocol.
- SASL_PLAINTEXT: Skip this step if the username and password are already set. Otherwise, create the ssl-user-config.properties file in the /config directory on the Kafka client and add the following content to the file:
security.protocol=SASL_PLAINTEXT # If the SASL mechanism is SCRAM-SHA-512, configure as follows: sasl.jaas.config=org.apache.kafka.common.security.scram.ScramLoginModule required \ username="**********" \ password="**********"; sasl.mechanism=SCRAM-SHA-512 # If the SASL mechanism is PLAIN, configure as follows: sasl.jaas.config=org.apache.kafka.common.security.plain.PlainLoginModule required \ username="**********" \ password="**********"; sasl.mechanism=PLAIN
Parameter description: username and password are the ones you set when enabling ciphertext access for the first time or when creating a user.
- SASL_SSL: Skip this step if the username, password, and SSL certificate are already set. Otherwise, create the ssl-user-config.properties file in the /config directory on the Kafka client and add the following content to the file:
security.protocol=SASL_SSL ssl.truststore.location={ssl_truststore_path} ssl.truststore.password=dms@kafka ssl.endpoint.identification.algorithm= # If the SASL mechanism is SCRAM-SHA-512, configure as follows: sasl.jaas.config=org.apache.kafka.common.security.scram.ScramLoginModule required \ username="**********" \ password="**********"; sasl.mechanism=SCRAM-SHA-512 # If the SASL mechanism is PLAIN, configure as follows: sasl.jaas.config=org.apache.kafka.common.security.plain.PlainLoginModule required \ username="**********" \ password="**********"; sasl.mechanism=PLAIN
- ssl.truststore.location: path for storing the client.jks certificate. Even in Windows, you need to use slashes (/) for the certificate path. Do not use backslashes (\), which are used by default for paths in Windows. Otherwise, the client will fail to obtain the certificate.
- ssl.truststore.password: server certificate password, which must be set to dms@kafka and cannot be changed.
- ssl.endpoint.identification.algorithm: whether to verify the certificate domain name. This parameter must be left blank, which indicates disabling domain name verification.
- username and password: username and password you set when enabling ciphertext access for the first time or when creating a user.
- Run the following command in the /bin directory of the Kafka client:
./kafka-consumer-groups.sh --bootstrap-server ${connection-address} --list --command-config ../config/ssl-user-config.properties
Example:
[root@ecs-kafka bin]# ./kafka-consumer-groups.sh --bootstrap-server 192.168.xx.xx:9093,192.168.xx.xx:9093,192.168.xx.xx:9093 --list --command-config ../config/ssl-user-config.properties test __consumer-group-dial-test [root@ecs-kafka bin]#
