Viewing Kafka Background Tasks
After you initiate certain instance operations listed in Table 1, a background task will start for each operation. On the console, you can view the background task status and clear task information by deleting task records.
Task Name |
Description |
Creating an instance |
Creates a Kafka instance. |
Restart Instance |
Restarts a Kafka instance. |
Modifying Kafka parameters |
Change capacity threshold policy |
Changes capacity threshold policies for a Kafka instance. |
Enabling or disabling SSL |
Switches between plaintext and ciphertext access. |
Configure public network access |
Enables/Disables public access. |
Enable Smart Connect |
Enables Smart Connect. |
Disable Smart Connect |
Disables Smart Connect. |
Modify Specifications |
Create Quota |
Creates user/client/topic quotas. |
Modify Quota |
Modifies quotas. |
Delete Quota |
Deletes user/client/topic quotas. |
Kafka partition reassignment |
Reassigns partitions of a topic. |
Enable logging |
Enables rebalancing logging. |
Disable logging |
Disables rebalancing logging. |
Configure topic permission |
Grants permissions to users in a topic. |
- Log in to the Kafka console.
- Click
in the upper left corner to select the region where your instance is located.
- Click the name of the desired Kafka instance to go to the Overview page.
- In the navigation pane, choose Instance > Background Tasks.
- On the Current Tasks or Scheduled Tasks tab page, click the time drop-down list and select a time range. Enter a keyword in the search box and press Enter. The tasks started in the specified time range are displayed.
On the Background Tasks page, you can also perform the following operations:
- Click
to refresh the task status.
- Click Delete. In the displayed Delete Task dialog box, click OK to clear the task information.
You can only delete the records of tasks in the Successful, Failed, or Canceled state.
- Click
Related Document
To view a background task list by calling an API, see Listing Background Tasks.
