Updated on 2025-09-18 GMT+08:00
Creating a Kafka Topic
Topics store messages created by producers and subscribed by consumers. If Automatic Topic Creation is not enabled during Kafka instance creation, you need to manually create topics. If Automatic Topic Creation has been enabled for the instance, this operation is optional.
Automatic Topic Creation indicates that a topic will be automatically created when a message is produced in or consumed from a topic that does not exist. The default topic parameters are listed in Table 1.
The following parameters of cluster instances can be changed on the Instance > Parameters page: log.retention.hours (retention period), default.replication.factor (replica quantity), or num.partitions (partition quantity). The value will be used in later topics that are automatically created.
For example, assume that num.partitions is changed to 5, an automatically created topic has parameters listed in Table 1.
Table 1 Topic parameters
Default Value (Single-node)
Default Value (Cluster)
Modified To (Cluster)
Partitions
5
Replicas
3
Aging Time (h)
72
72
72
Synchronous Replication
Disabled
Disabled
Disabled
Synchronous Flushing
Disabled
Disabled
Disabled
Message Timestamp
CreateTime
CreateTime
CreateTime
Max. Message Size (bytes)
10,485,760
10,485,760
10,485,760
Notes and Constraints
  • The partition quantity of topics of a single-node or cluster Kafka instance is limited. When the partition quantity limit is reached, you can no longer create topics. The partition quantity of a topic varies. For details, see Kafka Instance Specifications.
  • Instances created since May 17, 2023 do not have Kafka Manager. You cannot create topics for these instances using Kafka Manager.
  • For an instance with ciphertext access enabled, if allow.everyone.if.no.acl.found is set to false, topics can be created on the client only for the initial user (set when ciphertext access is enabled for the first time).
  • If a topic name starts with a special character, for example, a number sign (#), monitoring data cannot be displayed.
  • Due to the limitation of the Kafka kernel, topics whose names contain only period or underscore difference cannot be created. For example, assume that the Topic_1 topic is created, creating a topic named Topic.1 will fail and throw the Topic 'topic.1' collides with existing topics: topic_1 exception.
You can create a topic on the Kafka console, using Kafka Manager, or on a client.
  1. Log in to the Kafka console.
  2. Click in the upper left corner to select the region where your instance is located.
  3. Click the desired Kafka instance to view the instance details.
  4. In the navigation pane, choose Instance > Topics. Then click Create Topic.
  5. Enter a topic name, specify other parameters, and click OK.
    Figure 1 Creating a topic (cluster instance)
    Table 2 Topic parameters
    Topic Name
    Customize a name that contains 3 to 200 characters, starts with a letter or underscore (_), and contains only letters, digits, periods (.), hyphens (-), and underscores (_).
    The name must be different from preset topics:
    • __consumer_offsets
    • __transaction_state
    • __trace
    • __connect-status
    • __connect-configs
    • __connect-offsets
    • __cloud_event
    • __site_event
    • __dms_dial_test
    • __remote_log_metadata
    • __remote_log_compact_metadata
    • __remote_log_metadata_offset
    Once the topic is created, you cannot modify its name.
    Partitions
    Number of partitions in the topic.
    If the number of partitions is the same as that of consumers, the larger the partitions, the higher the consumption concurrency.
    If this parameter is set to 1, messages will be retrieved in the FIFO order.
    Value range: 1–200
    Replicas
    A higher number of replicas delivers higher reliability. Data is automatically backed up on each replica. When one Kafka broker becomes faulty, data is still available on other brokers. For more information, see Basic Concepts.
    If this parameter is set to 1, only one set of data is available.
    Value range: 1 to number of brokers
    If an instance node is faulty, an internal service error may be reported when you query messages in a topic with only one replica. Therefore, you are not advised using a topic with only one replica.
    Aging Time (h)
    The period that messages are retained for. Consumers must retrieve messages before this period ends. Otherwise, the messages will be deleted and can no longer be consumed.
    Value range: 1–720
    A message is returned to the client only after the message creation request has been received and the message has been acknowledged by all replicas.
    After enabling this, set the parameter acks to all or -1 in the configuration file or production code on the producer client.
    If there is only one replica, synchronous replication cannot be enabled.
    A message is immediately flushed to disk once it is produced, bringing higher reliability. When this option is disabled, a message is stored in the memory instead of being immediately flushed to disk once produced.
    Message Timestamp
    Timestamp type of a message. Options:
    • CreateTime: time when the producer created the message.
    • LogAppendTime: time when the broker appended the message to the log.
    Maximum batch processing size allowed by Kafka. If message compression is enabled in the client configuration file or code of producers, this parameter indicates the size after compression.
    If this is increased and there are consumers older than 0.10.2, the consumers' fetch size must also be increased so that they can fetch record batches this large.
    Value range: 0 to 10,485,760
    0–200 characters.
    After a topic is created, view the new topic on the topic list page.
Log in to Kafka Manager, choose Topic > Create, and set parameters as prompted. To ensure performance, a partition number within 200 is recommended for each topic.
Figure 2 Creating a topic on Kafka Manager
If your client is v2.2 or later, you can use kafka-topics.sh to create topics and manage topic parameters.
  • For a Kafka instance with ciphertext access disabled, run the following command in the /bin directory of the Kafka client:
    ./kafka-topics.sh --create --topic {topic-name} --bootstrap-server {connection-address} --partitions {number-of-partitions} --replication-factor {number-of-replicas}
    Table 3 Topic creation parameters
    topic-name
    topic name, which can be customized.
    connection-address
    Connection address of a Kafka instance. To obtain the address, choose Overview > Connection.
    To ensure performance, 200 or fewer partitions are recommended for each topic.
    number-of-replicas
    Number of replicas of a topic.
    Example:
    [root@ecs-kafka bin]# ./kafka-topics.sh --create --topic topic-01 --bootstrap-server 192.168.xx.xx:9092,192.168.xx.xx:9092,192.168.xx.xx:9092 --partitions 3 --replication-factor 3
    Created topic topic-01.
  • For a Kafka instance with ciphertext access enabled, do as follows:
    1. (Optional) If the username and password, and the SSL certificate has been configured, skip this step and go to 2. Otherwise, do as follows:
      Create the ssl-user-config.properties file in the /config directory of the Kafka client. Add the username and password, and the SSL certificate configuration by referring to 3.
    2. Run the following command in the /bin directory of the Kafka client:
      ./kafka-topics.sh --create --topic {topic-name} --bootstrap-server {connection-address} --partitions {number-of-partitions} --replication-factor {number-of-replicas} --command-config ../config/{ssl-user-config.properties}
      Table 4 Topic creation parameters
      topic-name
      connection-address
      number-of-replicas
      Configuration file name. This file contains username, password, and SSL certificate information.
      Example:
      [root@ecs-kafka bin]# ./kafka-topics.sh --create --topic topic-01 --bootstrap-server 192.168.xx.xx:9093,192.168.xx.xx:9093,192.168.xx.xx:9093 --partitions 3 --replication-factor 3 --command-config ../config/ssl-user-config.properties
Related Documents
