- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is DMS for Kafka?
- Product Advantages
- Application Scenarios
- Kafka Instance Specifications
- Comparing Single-node and Cluster Kafka Instances
- Comparing Kafka, RabbitMQ, and RocketMQ
- Comparing DMS for Kafka and Open-Source Kafka
- Security
- Notes and Constraints
- Related Services
- Basic Concepts
- Permissions
- Billing
- Getting Started
User Guide
- Process of Using Kafka
- Permissions Management
- Buying a Kafka Instance
- Configuring Topics
- Connecting to an Instance
- Managing Messages
- Managing Consumer Groups
- Managing Quotas
Managing Instances
- Viewing and Modifying Basic Information of a Kafka Instance
- Viewing Kafka Disk Usage
- Viewing Kafka Background Tasks
- Viewing Sample Code of Kafka Production and Consumption
- Modifying Kafka Instance Configuration Parameters
- Configuring Kafka Instance Tags
- Configuring Kafka Recycling Policies
- Upgrading the Kafka Instance Kernel
- Exporting the Kafka Instance List
- Restarting a Kafka Instance
- Deleting Kafka Instances
- Using Kafka Manager
- Modifying Instance Specifications
- Migrating Data
- Testing Instance Performance
- Applying for Increasing Kafka Quotas
- Monitoring and Alarms
- Viewing Kafka Audit Logs
Best Practices
- Kafka Best Practices
- Improving Kafka Message Processing Efficiency
- Optimizing Consumer Polling
- Interconnecting Logstash to Kafka to Produce and Consume Messages
- Using MirrorMaker to Synchronize Data Across Clusters
- Handling Message Accumulation
- Handling Service Overload
- Handling Uneven Service Data
- Configuring Message Accumulation Monitoring
- Suggestions on Using DMS for Kafka Securely
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs V2 (Recommended)
- Managing Lifecycle
Instance Management
- Resetting the Password
- Resetting Kafka Manager Password
- Restarting Kafka Manager
- Configuring Automatic Topic Creation
- Modifying the Private IP Address for Cross-VPC Access
- Querying Kafka Cluster Metadata
- Querying Coordinator Details of a Kafka Instance
- Reassigning Replicas of a Topic for a Kafka Instance
- Modifying Kafka Access Modes
- Querying the Disk Usage Status of Topics
- Initiating Partition Reassignment for a Kafka Instance
- Disabling Kafka Manager
- Deleting a User or Client Quota
- Querying User or Client Quotas
- Creating User or Client Quotas
- Modifying User or Client Quotas
Smart Connect
- Enabling Smart Connect (Pay-per-Use Instance)
- Disabling Smart Connect (Pay-per-Use Instance)
- Creating a Smart Connect Task
- Querying Smart Connect Tasks
- Querying Smart Connect Task Details
- Deleting a Smart Connect Task
- Pausing a Smart Connect Task
- Restarting a Smart Connect Task
- Starting a Smart Connect Task or Restarting a Paused or Running Smart Connect Task
- Specification Modification Management
- Topic Management
- Querying Consumer Group Details
- Querying All Consumer Groups
- Deleting Consumer Groups of a Kafka Instance in Batches
- Creating a Consumer Group
- Resetting Consumer Group Offset to the Specified Position
- Querying the Offset of a Consumer Group
- Modifying All Consumer Groups
- Querying a Specified Consumer Group
- Deleting a Specified Consumer Group
- Modifying a Specified Consumer Group
- Querying Topics of a Specified Consumer Group
- Querying Consumers in a Specified Consumer Group
- User Management
- Managing Messages
- Background Task Management
- Tag Management
- Diagnosis Management
- Other APIs
- Out-of-Date APIs
- Appendix
- Change History
- SDK Reference
Instances
- Why Can't I Select Two AZs?
- Why Can't I View the Subnet and Security Group Information When Creating a DMS Instance?
- How Do I Select Storage Space for a Kafka Instance?
- How Do I Choose Between High I/O and Ultra-high I/O?
- Which Capacity Threshold Policy Should I Use?
- Which Kafka Versions Are Supported?
- What Is the ZooKeeper Address of a Kafka Instance?
- Are Kafka Instances in Cluster Mode?
- Can I Modify the Port for Accessing a Kafka Instance?
- How Long Are Kafka SSL Certificates Valid for?
- How Do I Synchronize Data from One Kafka Instance to Another?
- How Do I Change the SASL_SSL Setting of a Kafka Instance?
- How Do I Modify the SASL Mechanism?
- How Do I Change the Security Protocol?
- Will a Kafka Instance Be Restarted After Its Enterprise Project Is Modified?
- Are Kafka Brokers and ZooKeeper Deployed on the Same VM or on Different VMs?
- Can I Delete a Kafka Instance Billed in Yearly/Monthly Mode?
- Which Cipher Suites Are Supported by Kafka?
- Can I Change Single-AZ Deployment to Multi-AZ Deployment for an Instance?
- Does DMS for Kafka Support Cross-AZ Disaster Recovery? Where Can I Check Whether an Existing Instance is Across-AZs?
- Do Kafka Instances Support Disk Encryption?
- Can I Change the VPC and Subnet After a Kafka Instance Is Created?
- Where Can I Find Kafka Streams Use Cases?
- Can I Upgrade Kafka Instances?
- How Do I Bind an EIP Again?
Connections
- How Do I Select and Configure a Security Group?
- Can I Access a Kafka Instance Over a Public Network?
- How Many Connection Addresses Does a Kafka Instance Have by Default?
- Do Kafka Instances Support Cross-Region Access?
- Do Kafka Instances Support Cross-VPC Access?
- Do Kafka Instances Support Cross-Subnet Access?
- Does DMS for Kafka Support Authentication with Kerberos?
- Does DMS for Kafka Support Password-Free Access?
- How Do I Obtain the Public Access Address After Public Access Is Enabled?
- Does DMS for Kafka Support Authentication on Clients by the Server?
- Can I Use PEM SSL Truststore When Connecting to a Kafka Instance with SASL_SSL Enabled?
- What Are the Differences Between JKS and CRT Certificates?
- Which TLS Version Does DMS for Kafka Support?
- Is There a Limit on the Number of Client Connections to a Kafka Instance?
- How Many Connections Are Allowed from Each IP Address?
- Can I Change the Private Network Addresses of a Kafka Instance?
- Is the Same SSL Certificate Used for Different Instances?
- Why Is It Not Recommended to Use a Sarama Client for Messaging?
Topics and Partitions
- Is There a Limit on the Number of Topics in a Kafka Instance?
- Why Is Partition Quantity Limited?
- Can I Reduce the Partition Quantity?
- Why Do I Fail to Create Topics?
- Do Kafka Instances Support Batch Importing Topics or Automatic Topic Creation?
- Why Do Deleted Topics Still Exist?
- Can I View the Disk Space Used by a Topic?
- Can I Add ACL Permissions for Topics?
- What Should I Do If Kafka Storage Space Is Used Up Because Retrieved Messages Are Not Deleted?
- How Do I Increase the Partition Quantity?
- Will a Kafka Instance Be Restarted After Its Automatic Topic Creation Setting Is Modified?
- What Can I Do If a Consumer Fails to Retrieve Messages from a Topic Due to Insufficient Permissions?
Consumer Groups
- Do I Need to Create Consumer Groups, Producers, and Consumers for Kafka Instances?
- Will a Consumer Group Without Active Consumers Be Automatically Deleted in 14 Days?
- Why Does a Deleted Consumer Group Still Exist?
- Why Can't I View Consumers When Instance Consumption Is Normal?
- Can I Delete Unnecessary Topics in a Consumer Group?
Messages
- What Is the Maximum Size of a Message that Can be Created?
- Why Does Message Poll Often Fail During Rebalancing?
- Why Can't I Query Messages on the Console?
- What Can I Do If Kafka Messages Are Accumulated?
- Why Do Messages Still Exist After the Retention Period Elapses?
- Do Kafka Instances Support Delayed Message Delivery?
- How Do I View the Number of Accumulated Messages?
- Why Is the Message Creation Time Displayed as Year 1970?
- How Do I Modify message.max.bytes?
- Why Are Offsets Not Continuous?
Kafka Manager
- Can I Configure a Kafka Manager Account to Be Read-Only?
- Why Can't I See Broker Information After Logging In to Kafka Manager?
- Yikes! Insufficient partition balance when creating topic : projectman_project_enterprise_project Try again.
- Can I Query the Body of a Message by Using Kafka Manager?
- Can I Change the Port of the Kafka Manager Web UI?
- Which Topic Configurations Can Be Modified on Kafka Manager?
- Why Is Information Displayed on Kafka Manager Inconsistent with Cloud Eye Monitoring Data?
- How Do I Change a Partition Leader for a Topic in Kafka Manager?
- Why Is the Version on the Console Different from That in Kafka Manager?
- Why Does an Instance Contain Default Topics __trace and __consumer_offsets?
- Why Do I See a Deleted Consumer Group on Kafka Manager?
Monitoring & Alarm
- Why Can't I View the Monitoring Data?
- Why Is the Monitored Number of Accumulated Messages Inconsistent with the Message Quantity Displayed on the Kafka Console?
- Why Is a Consumer Group Still on the Monitoring Page After Being Deleted?
- Why Do Metrics Fluctuate Significantly (Disk Read/Write Speed, Average Disk Read/Write Time, and CPU Usage)?
- Why Does JVM Heap Memory Usage of JVM Fluctuate Significantly?
- Why Is Production Rate Still 0 When There Are Produced Messages?
Instances
Troubleshooting
- Troubleshooting Kafka Connection Exceptions
- Troubleshooting 6-Min Latency Between Message Creation and Retrieval
- Troubleshooting Message Creation Failures
- Troubleshooting Topic Deletion Failures
- Troubleshooting Failure to Log In to Kafka Manager in Windows
- Troubleshooting Error "Topic {{topic_name}} not present in metadata after 60000 ms" During Message Production or Consumption
- Flink 1.15 Consumption Progress Submission Failure
- Videos
More Documents
- Getting Started
- Preparing Required Resources
- Buying an Instance
- Accessing a Kafka Instance
- Managing Instances
- Managing Topics
- Managing Messages
- Managing Users
- Managing Kafka Quotas
- Modifying Kafka Parameters
- Quotas
- Monitoring
- Auditing
Instances
- Can I Change an Instance from Single-AZ Deployment to Multi-AZ Deployment?
- Does DMS for Kafka Support Cross-AZ Disaster Recovery? Where Can I View the AZs Configured for an Existing Instance?
- Does Specification Modification Affect Services?
Connections
- Can I Change the Partition Quantity?
- How Do I Disable Automatic Topic Creation?
- Consumer Groups
Messages
Kafka Manager
- Monitoring & Alarm
Instances
Troubleshooting
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Getting Started
- Creating an Instance
- Managing Topics
- Managing Messages
- Managing Users
- Quotas
- Monitoring
- Auditing
Instances
Connections
- Consumer Groups
Messages
Kafka Manager
Instances
Troubleshooting
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- Lifecycle Management
Instance Management
- Adding Partitions to a Topic for a Kafka Instance
- Querying a Specific Consumer Group
- Deleting a Consumer Group from a Kafka Instance
- Batch Deleting Consumer Groups of a Kafka Instance
- Initiating Partition Reassigning for a Kafka Instance
- Topic Management
- User Management
- Message Query
- Tag Management
- Other APIs
- Out-of-Date APIs
- Appendix
- Change History
- Developer Guide (Paris Region)
- Getting Started
- Managing Messages
- Managing Quotas
Managing Instances
- Modifying Kafka Instance Specifications
- Migrating Data
Instances
Connections
- Consumer Groups
Messages
Kafka Manager
Instances
Troubleshooting
- Change History
- API Reference (Kuala Lumpur Region)
With Cloud Trace Service (CTS), you can record operations associated with DMS for Kafka for later query, audit, and backtrack operations.
Prerequisite
CTS has been enabled.
DMS for Kafka Operations Supported by CTS
Operation |
Resource Type |
Trace Name |
Successfully creating an order for creating an instance |
kafka |
createDMSInstanceOrderSuccess |
Successfully creating an instance |
kafka |
createDMSInstanceTaskSuccess |
Failing to create an order for creating an instance |
kafka |
createDMSInstanceOrderFailure |
Failing to create an instance |
kafka |
createDMSInstanceTaskFailure |
Successfully deleting an instance that failed to be created |
kafka |
deleteDMSCreateFailureInstancesSuccess |
Failing to delete an instance that failed to be created |
kafka |
deleteDMSCreateFailureInstancesFailure |
Successfully deleting an instance |
kafka |
deleteDMSInstanceTaskSuccess |
Failing to delete an instance |
kafka |
deleteDMSInstanceTaskFailure |
Deleting multiple instance tasks at a time |
kafka |
batchDeleteDMSInstanceTask |
Successfully submitting a request to delete multiple instances at a time |
kafka |
batchDeleteDMSInstanceSuccess |
Successfully deleting multiple instances at a time |
kafka |
batchDeleteDMSInstanceTaskSuccess |
Failing to submit a request to delete multiple instances at a time |
kafka |
batchDeleteDMSInstanceFailure |
Failing to delete multiple instances at a time |
kafka |
batchDeleteDMSInstanceTaskFailure |
Successfully submitting a request to modify an instance order |
kafka |
modifyDMSInstanceOrderSuccess |
Failing to submit a request to modify an instance order |
kafka |
modifyDMSInstanceOrderFailure |
Successfully submitting a request to scale up an instance |
kafka |
extendDMSInstanceSuccess |
Successfully scaling up an instance |
kafka |
extendDMSInstanceTaskSuccess |
Failing to submit a request to scale up an instance |
kafka |
extendDMSInstanceFailure |
Failing to scale up an instance |
kafka |
extendDMSInstanceTaskFailure |
Successfully submitting a request to reset instance password |
kafka |
resetDMSInstancePasswordSuccess |
Failing to submit a request to reset instance password |
kafka |
resetDMSInstancePasswordFailure |
Successfully submitting a request to restart an instance |
kafka |
restartDMSInstanceSuccess |
Successfully restarting an instance |
kafka |
restartDMSInstanceTaskSuccess |
Failing to submit a request to restart an instance |
kafka |
restartDMSInstanceFailure |
Failing to restart an instance |
kafka |
restartDMSInstanceTaskFailure |
Successfully submitting a request to restart multiple instances at a time |
instance |
batchRestartDMSInstanceSuccess |
Successfully restarting multiple instances at a time |
kafka |
batchRestartDMSInstanceTaskSuccess |
Failing to submit a request to restart multiple instances at a time |
instance |
batchRestartDMSInstanceFailure |
Failing to restart multiple instances at a time |
kafka |
batchRestartDMSInstanceTaskFailure |
Successfully submitting a request to modify instance information |
kafka |
modifyDMSInstanceInfoSuccess |
Successfully modifying instance information |
kafka |
modifyDMSInstanceInfoTaskSuccess |
Failing to submit a request to modify instance information |
kafka |
modifyDMSInstanceInfoFailure |
Failing to modify instance information |
kafka |
modifyDMSInstanceInfoTaskFailure |
Successfully deleting a background task |
kafka |
deleteDMSBackendJobSuccess |
Failing to delete a background task |
kafka |
deleteDMSBackendJobFailure |
Successfully enabling Smart Connect |
kafka |
createConnectorTaskSuccess |
Successfully creating a Smart Connect task |
kafka |
createConnectorSinkTaskSuccess |
Failing to enable Smart Connect |
kafka |
createConnectorTaskFailure |
Failing to create a Smart Connect task |
kafka |
createConnectorSinkTaskFailure |
Successfully freezing an instance |
kafka |
freezeDMSInstanceTaskSuccess |
Failing to freeze an instance |
kafka |
freezeDMSInstanceTaskFailure |
Successfully unfreezing an instance |
kafka |
unfreezeDMSInstanceTaskSuccess |
Failing to unfreeze an instance |
kafka |
unfreezeDMSInstanceTaskFailure |
Successfully creating a topic for a Kafka instance |
kafka |
Kafka_create_topicSuccess |
Failing to create a topic for a Kafka instance |
kafka |
Kafka_create_topicFailure |
Successfully deleting a topic from a Kafka instance |
kafka |
Kafka_delete_topicsSuccess |
Failing to delete a topic for a Kafka instance |
kafka |
Kafka_delete_topicsFailure |
Successfully enabling automatic topic creation |
kafka |
enable_auto_topicSuccess |
Failing to enable automatic topic creation |
kafka |
enable_auto_topicFailure |
Successfully modifying a topic |
kafka |
Kafka_alter_topicsSuccess |
Failing to modify a topic |
kafka |
Kafka_alter_topicsFailure |
Successfully reassigning partitions |
kafka |
kafka_reassignmentTaskSuccess |
Failing to reassign partitions |
kafka |
kafka_reassignmentTaskFailure |
Successfully submitting a partition reassignment request |
kafka |
kafka_reassignmentSuccess |
Failing to submit a partition reassignment request |
kafka |
kafka_reassignmentFailure |
Successfully resetting the consumer offset |
kafka |
Kafka_reset_consumer_offsetSuccess |
Failing to reset the consumer offset |
kafka |
Kafka_reset_consumer_offsetFailure |
Successfully deleting consumer groups in batches |
kafka |
Kafka_batch_delete_groupSuccess |
Failing to delete consumer groups in batches |
kafka |
Kafka_batch_delete_groupFailure |
Successfully creating a user |
kafka |
createUserSuccess |
Failing to create a user |
kafka |
createUserFailure |
Successfully deleting a user |
kafka |
deleteUserSuccess |
Failing to delete a user |
kafka |
deleteUserFailure |
Successfully updating user policies |
kafka |
updateUserPoliciesTaskSuccess |
Failing to update user policies |
kafka |
updateUserPoliciesTaskFailure |
Successfully recovering an instance from Recycle Bin |
kafka |
out_recycleTaskSuccess |
Failing to recover an instance from Recycle Bin |
kafka |
out_recycleTaskFailure |
Viewing Audit Logs
