Updated on 2025-11-20 GMT+08:00
Kafka Metrics
Introduction
This section describes metrics reported by DMS for Kafka to Cloud Eye as well as their namespaces and dimensions. You can use the Cloud Eye console or APIs to query the Kafka metrics and alarms, or view Kafka instance metrics on the Monitoring Details page of the DMS for Kafka console.
Cloud Eye supports a maximum of four hierarchical dimensions that are numbered from 0 to 3. For example, if the dimension information of a monitoring metric is "kafka_instance_id,kafka_broker", the dimension of "kafka_instance_id" is numbered 0 and that of "kafka_broker" is numbered 1.
Namespace
SYS.DMS
Instance Metrics
Table 1 Instance metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
Monitoring Period (Raw Data)
current_partitions
Partitions
Number of used partitions in the instance
0–100,000
Count
N/A
kafka_instance_id
1 minute
current_topics
Topics
Number of created topics in the instance
0–100,000
Count
N/A
kafka_instance_id
1 minute
group_msgs
Accumulated Messages
Total number of accumulated messages in all consumer groups of the instance
0–1,000,000,000
Count
N/A
kafka_instance_id
1 minute
instance_bytes_in_rate
Message Production
Number of bytes produced in the instance per second
Some instances do not support this metric. Check whether your instance supports it on the console.
0–1,000,000
Byte/s
1024(IEC)
kafka_instance_id
1 minute
instance_bytes_out_rate
Message Consumption
Number of bytes consumed from the instance per second
0–1,000,000
Byte/s
1024(IEC)
kafka_instance_id
1 minute
current_partitions_usage
Current Partitions Usage
0–100
N/A
kafka_instance_id
1 minute
Broker Metrics
Enabling Smart Connect for a Kafka instance creates two or more brokers. On the By Broker tab page, select "connector" for Node Type for Smart Connect broker metrics, or select "broker" for Node Type for Kafka instance broker metrics.
Metrics of Smart Connect brokers: disk capacity usage, memory usage, JVM heap memory usage, node alive status, and connections.
Table 2 Broker metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
broker_data_size
Message Size
Total size of messages in the broker
0–5,000,000,000,000
Byte
1024(IEC)
1 minute
broker_messages_in_rate
Message Creation Rate
Number of messages created per second
0–500,000
Count/s
N/A
1 minute
broker_bytes_out_rate
Message Retrieval
Number of bytes retrieved per second
0–500,000,000
Byte/s
1024(IEC)
1 minute
broker_bytes_in_rate
Message Creation
Number of bytes created per second
0–500,000,000
Byte/s
1024(IEC)
1 minute
broker_fetch_mean
Average Message Retrieval Processing Duration
Average time that the broker spends processing message retrieval requests
0–10,000
ms
N/A
1 minute
broker_produce_mean
Average Message Creation Processing Duration
Average time that the broker spends processing message creation requests
0–10,000
ms
N/A
1 minute
broker_cpu_core_load
Average Load per CPU Core
Average load of each CPU core of the Kafka VM
0–20
N/A
N/A
1 minute
broker_disk_usage
Disk Capacity Usage
Disk usage of the Kafka VM
0–100
N/A
1 minute
broker_memory_usage
Memory usage of the broker VM
Memory usage of the Kafka VM
0–100
N/A
1 minute
broker_heap_usage
JVM Heap Memory Usage of JVM
Heap memory usage of the Kafka JVM
0–100
N/A
1 minute
broker_alive
Broker Alive
Whether the Kafka broker is alive
This metric is supported by instances purchased in April 2020 or later.
  • 1: alive
  • 0: not alive
N/A
N/A
1 minute
broker_connections
Connections
Total number of TCP connections on the Kafka broker
0–65,535
Count
N/A
1 minute
broker_cpu_usage
CPU Usage
CPU usage of the Kafka VM
0–100
N/A
1 minute
broker_disk_read_await
Average Disk Read Time
Average time for each disk I/O read in the monitoring period
This metric is supported for instances purchased in June 2020 or later.
> 0
ms
N/A
1 minute
broker_disk_write_await
Average Disk Write Time
Average time for each disk I/O write in the monitoring period
> 0
ms
N/A
1 minute
broker_total_bytes_in_rate
Inbound Traffic
Inbound traffic per second
0–1,000,000,000
Byte/s
1024(IEC)
1 minute
broker_total_bytes_out_rate
Outbound Traffic
Outbound traffic per second
0–1,000,000,000
Byte/s
1024(IEC)
1 minute
broker_disk_read_rate
Disk Read Speed
Read traffic on the disk
This metric is supported for instances purchased on or after May 16, 2022.
≥ 0
Byte/s
1024(IEC)
1 minute
broker_disk_write_rate
Disk Write Speed
Write traffic on the disk
≥ 0
Byte/s
1024(IEC)
1 minute
network_bandwidth_usage
Network Bandwidth Usage
Network bandwidth usage
This metric is supported only:
  • For instances purchased since July 9 2023.
  • For instances purchased before July 9 2023, this metric is supported for brokers if they are added since July 9 2023.
0–100
N/A
1 minute
Topic Metrics
Table 3 Topic metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
topic_bytes_in_rate
Message Creation
This metric is available only when Monitoring Type is set to Basic monitoring on the By Topic tab page.
0–500,000,000
Byte/s
1024(IEC)
kafka_instance_id,kafka_topics
1 minute
topic_bytes_out_rate
Message Retrieval
0–500,000,000
Byte/s
1024(IEC)
1 minute
topic_data_size
Message Size
Total size of messages in the queue
0–5,000,000,000,000
Byte
1024(IEC)
1 minute
topic_messages
Total Messages
Total number of messages in the queue
≥ 0
Count
N/A
1 minute
topic_messages_in_rate
0–500,000
Count/s
N/A
1 minute
partition_messages
Partition Messages
Total number of messages in the partition
This metric is available only when Monitoring Type is set to Partition monitoring on the By Topic tab page.
≥ 0
Count
N/A
kafka_instance_id,kafka_topics,kafka_partitions
1 minute
produced_messages
Created Messages
Number of messages that have been created
≥ 0
Count
N/A
1 minute
partition_messages_in_rate
Partition message production rate
Number of messages created per second in a partition.
Some instances do not support this metric. Contact customer service.
≥ 0
Count/s
N/A
1 minute
Consumer Group Metrics
Table 4 Consumer group metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
messages_consumed
Retrieved Messages
Number of messages that have been retrieved in the consumer group
This metric is available only when Topic is set to a specific topic name and Monitoring Type is set to Partition monitoring on the By Consumer Group tab page.
≥ 0
Count
N/A
kafka_instance_id,kafka_groups,kafka_groups_topics,kafka_groups_partitions
1 minute
messages_remained
Number of accumulations Available Messages
Number of messages that can be retrieved in the consumer group
≥ 0
Count
N/A
1 minute
topic_messages_remained
Topic Available Messages
Number of remaining messages that can be retrieved from the specified topic in the consumer group
This metric is available only when Topic is set to a specific topic name and Monitoring Type is set to Basic monitoring on the By Consumer Group tab page.
0 to 263–1
Count
N/A
1 minute
topic_messages_consumed
Topic Retrieved Messages
Number of messages that have been retrieved from the specified topic in the consumer group
0 to 263–1
Count
N/A
1 minute
consumer_messages_remained
Consumer Available Messages
Number of remaining messages that can be retrieved in the consumer group
This metric is available only when Topic is set to All topics on the By Consumer Group tab page.
0 to 263–1
Count
N/A
1 minute
consumer_messages_consumed
Consumer Retrieved Messages
0 to 263–1
Count
N/A
1 minute
messages_consumed_per_min
Partition Consumption Rate
Number of messages consumed from the specified queue partition in the consumer group every minute
0–30,000,000
Count/min
N/A
1 minute
topic_messages_consumed_per_min
Queue Consumption Rate
Number of messages consumed from the specified queue in the consumer group every minute
0–30,000,000
Count/min
N/A
1 minute
consumer_messages_consumed_per_min
Consumer Group Consumption Rate
Number of messages consumed from the consumer group every minute
0–30,000,000
Count/min
N/A
1 minute
Smart Connect Metrics
Smart Connect metrics are only available for cluster instances.
Table 5 Smart Connect metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
kafka_wait_synchronize_data
Kafka Data to Sync
Data to synchronize in the Kafka migration task
≥ 0
Count
N/A
kafka_instance_id,connector_task
1 minute
kafka_synchronize_rate
Kafka Data Synced per Minute
Data synchronized per minute in the Kafka migration task
≥ 0
Count
N/A
1 minute
task_status
Task Status
Status of the current task
  • 0: abnormal
  • 1: normal
N/A
N/A
1 minute
message_delay
Message Delay
Time elapsed between when a message is sent from the source and received by the target
≥ 0
ms
N/A
1 minute
Precautions:
  • A Smart Connect task that bidirectionally copies Kafka data is split into two tasks for monitoring: Smart Connect task name_source_0 and Smart Connect task name_source_1.
  • If all messages in a topic have aged before the next synchronization, there is no Kafka data to be synchronized. However, since the Kafka data synchronization metric uses the offset value that contains aged data, Kafka Data Synced per Minute will display the number of aged messages.
If a monitored object has multiple dimensions, the dimensional level of specific metrics is required when you use APIs to query the metrics.
For example, to query the disk capacity usage (broker_disk_usage) of a Kafka broker, its dimension is "kafka_instance_id,kafka_broker", indicating that kafka_instance_id is numbered 0 and kafka_broker is numbered 1.
  • To query a single metric by calling the API, the kafka_broker dimension is used as follows:
    dim.0=kafka_instance_id,6a0df74a-fxxx-497bfdda6c8e&dim.1=kafka_broker,broker-0
    6a0df74a-fxxx-497bfdda6c8e and broker-0 are the dimension values of kafka_instance_id and kafka_broker. For details about how to obtain them, see the guide in the Dimension table.
  • To batch query metrics by calling the API, the kafka_broker dimension is used as follows:
    "dimensions": [
                         "name": "kafka_instance_id",
                         "value": "6a0df74a-fxxx-497bfdda6c8e"
                         "name": "kafka_broker",
                         "value": "broker-0"
Dimension
Key
Value
kafka_instance_id
Kafka instance ID, for example, 6a0df74a-fxxx-497bfdda6c8e.
To obtain the value, call the Listing All Instances API and extract the value from the response parameters.
kafka_broker
Kafka instance broker. The broker ID starts from 0 and increases in ascending order. For example, if an instance has three brokers, they are broker-0, broker-1, and broker-2.
To obtain the value, call the Querying Kafka Instance Monitoring Dimensions API and extract the value from the response parameters.
kafka_topics
Topic name, for example, topic-01.
kafka_partitions
Partition number in a topic, for example, 0.
Partition number in a topic consumed by a consumer group, for example, 0.
kafka_groups_topics
Topic name consumed by a consumer group, for example, topic-01.
kafka_groups
Consumer group name of a Kafka instance, for example, group-01.
connector_task
Smart Connect task name, for example, smart-connect-01_source_0.
