Configuring Kafka Public Access
Updated on 2025-02-14 GMT+08:00
Clients can use IPv4 or IPv6 addresses to access a Kafka instance over a public network.
  • By IPv4: On the Kafka console, enable public access and configure EIPs for the instance.
  • By IPv6: Enable IPv6 in Kafka instance creation and add IPv6 addresses to the shared bandwidth to support both private and public IPv6 access.
On the Kafka console, the procedures for configuring public IPv4 access vary depending on the content displayed in the Connection area on the Basic Information page.
Notes and Constraints
Kafka instances only support IPv4 EIPs. IPv6 EIPs are not supported.
  • You can change the public access setting only when the Kafka instance is in the Running state.
  • (Optional) To access a Kafka instance using IPv6 addresses, ensure that IPv6 is enabled for the Kafka instance.
Enabling Public IPv4 Access (SASL Cannot Be Changed)
  1. Log in to the console.
  2. Click in the upper left corner to select the region where your instance is located.
  3. Click and choose Middleware > Distributed Message Service (for Kafka) to open the console of DMS for Kafka.
  4. In the navigation pane, choose Kafka Instances.
  5. Click a Kafka instance to go to the Basic Information page.
  6. Click next to Public Access to enable public access. For Elastic IP Address, select an EIP for each broker.
    If the EIPs are insufficient, do as follows to set them.
    1. Click Create Elastic IP to go to the Buy EIP page and purchase EIPs. For details, see Assigning an EIP.
    2. After the purchase is complete, return to the public access enabling page.
    3. Click after Elastic IP Address, select an EIP for each broker and then click .
    4. You can view the operation progress on the Background Tasks page. If the task status is Successful, the modification has succeeded.
    Figure 1 Enabling public access
    After public access is enabled, configure security group rules listed in Table 1 before attempting to access Kafka. For details about accessing Kafka, see Connecting to an Instance.
    Table 1 Kafka instance security group rules (public IPv4 access)
    Direction
    Protocol
    Type
    Port
    Source
    Inbound
    TCP
    IPv4
    9094
    IP address or IP address group of the Kafka client
    Accessing Kafka over a public network (without SSL)
    Inbound
    TCP
    IPv4
    9095
    Accessing Kafka over a public network (with SSL)
Disabling Public IPv4 Access (SASL Cannot Be Changed)
  6. Click next to Public Access.
    After public access is disabled, configure security group rules listed in Table 2 before attempting to access Kafka in a VPC. For details about accessing Kafka, see Connecting to an Instance.
    Table 2 Kafka instance security group rules (private access)
    Direction
    Protocol
    Type
    Port
    Source
    Inbound
    TCP
    IPv4
    9092
    Accessing a Kafka instance over a private network within a VPC (without SSL)
    Inbound
    TCP
    IPv4
    9093
    Accessing a Kafka instance over a private network within a VPC (with SSL)
    After a security group is created, its default inbound rule allows communication among ECSs within the security group and its default outbound rule allows all outbound traffic. In this case, you can access a Kafka instance within a VPC, and do not need to add rules according to Table 2.
Enabling Public IPv4 Access (Plaintext or Ciphertext Access Can Be Changed)
  3. Click and choose Middleware > Distributed Message Service for Kafka to open the console of DMS for Kafka.
    3. Click after Elastic IP Address, select an EIP for each broker and then click . The Background Tasks page is displayed.
    4. If the status of the task turns to Successful, public access is successfully enabled.
    Figure 2 Enabling public access
    After public access is enabled, configure the access mode (plaintext or ciphertext) and security group rules listed in Table 3 before attempting to access Kafka. For details about accessing Kafka, see Connecting to an Instance.
    Table 3 Kafka instance security group rules (public IPv4 access)
    Direction
    Protocol
    Type
    Port
    Source
    Inbound
    TCP
    IPv4
    9094
    Public plaintext access to Kafka
    Inbound
    TCP
    IPv4
    9095
    Public ciphertext access to Kafka
Disabling Public IPv4 Access (Plaintext or Ciphertext Access Can Be Changed)
  6. Before disabling public access, disable Plaintext Access and Ciphertext Access next to Public Network Access. Then click next to Public Access.
  7. Click OK. The Background Tasks page is displayed. If the status of the task turns to Successful, public access is successfully disabled.
    After public access is disabled, configure security group rules listed in Table 4 before attempting to access Kafka in a VPC. For details about accessing Kafka, see Connecting to an Instance.
    After a security group is created, its default inbound rule allows communication among ECSs within the security group and its default outbound rule allows all outbound traffic. In this case, you can access a Kafka instance within a VPC, and do not need to add rules according to Table 4.
    Table 4 Kafka instance security group rules (private access)
    Direction
    Protocol
    Type
    Port
    Source
    Inbound
    TCP
    IPv4
    9092
    Accessing a Kafka instance over a private network within a VPC (in plaintext)
    Inbound
    TCP
    IPv4
    9093
    Accessing a Kafka instance over a private network within a VPC (in ciphertext)
Enabling IPv6 Public Network Access
  6. In the Connection area, obtain IPv6 Instance Address (Private Network). In the Network area, view and record the VPC and subnet.
    Figure 3 Instance details page
  7. Click in the upper left corner of the management console and choose Network > Elastic IP. The EIPs page is displayed.
  8. Choose Shared Bandwidths in the navigation pane.
  9. Apply for a shared bandwidth. For details, see Assigning a Shared Bandwidth.
    If a shared bandwidth already exists, you do not need to apply for one again.
  10. In the row containing the shared bandwidth, click Add Public IP Address.
  11. Set the parameters as described in Table 5 and click OK.
    Table 5 Adding public IP parameters
    Public IP Address
    Select IPv6 Address.
    VPC
    Select the VPC in 6 from the drop-down list.
    Subnet
    Select the subnet in 6 from the drop-down list. Select all IPv6 addresses in 6.
    Figure 4 Adding public IPs
  12. After the shared bandwidth is configured, set a Kafka instance security group with the rules described in Table 6.
    Table 6 Kafka instance security group rules (IPv6 access)
    Direction
    Protocol
    Type
    Port
    Source
    Inbound
    TCP
    IPv6
    9192
    ::/0
    Accessing a Kafka instance using IPv6 addresses (without SSL encryption)
    Inbound
    TCP
    IPv6
    9193
    ::/0
    Accessing a Kafka instance using IPv6 addresses (with SSL encryption)
    When a client is connected to a Kafka instance over an IPv6 public network:
    • The Kafka connection addresses are the IPv6 addresses in Instance Address (Private Network).
    • The client NIC must be added to shard bandwidth. Shared bandwidth is using a connected network. The shared bandwidth of the client NIC and that of the Kafka instance can be different.
Disabling IPv6 Public Access
Remove the IPv6 addresses of a Kafka instance from the shared bandwidth. For details, see Removing EIPs from a Shared Bandwidth.
