Updated on 2025-08-21 GMT+08:00
Configuring Kafka Recycling Policies
If recycling is enabled, deleted instances and their data are retained in Recycle Bin, and can be recovered during the retention period. Once the retention period expires, instances in Recycle Bin will be deleted permanently.
Recycling is disabled by default.
Notes and Constraints
  • Pay-per-use instance in Recycle Bin will not generate fees, but their storage will.
  • Yearly/Monthly instances will be moved to Recycle Bin upon unsubscription. After that, they will not generate fees, but their storage will.
  • Yearly/Monthly instances will be changed to pay-per-use ones upon successful recovery.
  • Removing or unsubscribing instances in the grace or retention period deletes them permanently.
Enabling Recycle Bin
  1. Log in to the Kafka console.
  2. Click in the upper left corner to select the region where your instance is located.
  3. In the navigation pane, choose Recycle Bin.
  4. Click Modify Recycling Policy and the Modify Recycling Policy dialog box is displayed.
  5. Enable Recycle Bin, specify Retention Days (1–7), and click OK.
Recovering Kafka Instances
  4. Recover Kafka instances using either of the following methods:
    • Select one or more Kafka instances and click Recover in the upper left corner.
    • In the row containing the desired Kafka instance, click Recover.
  5. In the displayed Recover Instance dialog box, click OK.
    It takes 3 to 10 minutes to recover an instance. You can view recovered instances on the Kafka Instances page.
Modifying Retention Days
  5. Modify the retention days (1–7) and click OK.
    Changes to the retention period apply only to instances deleted after the changes.
Exporting Instances in the Recycle Bin
  4. Export the instance list using either of the following methods:
    • Select the desired instances and choose Export > Export selected data to an XLSX file to export specified instances.
    • Choose Export > Export all data to an XLSX file to export all instances.
Deleting Instances Permanently
  4. Delete instances using either of the following methods:
    • Select one or more Kafka instances and click Delete in the upper left corner.
    • In the row containing the Kafka instance to be deleted, click Delete.
  5. In the displayed Delete Instance dialog box, enter DELETE and click OK.
    Deleting a Kafka instance in the recycle bin will clear the instance data without any backup. Exercise caution.
Disabling Recycling
  5. Disable Recycle Bin and click OK.
