Help Center/
Distributed Message Service for Kafka/
User Guide/
Managing Consumer Groups/
Exporting Kafka Consumer Groups
Updated on 2025-08-21 GMT+08:00
You can export a list of consumer groups in a Kafka instance.
- Log in to the Kafka console.
- Click
in the upper left corner to select the region where your instance is located. - Click the desired instance to go to the instance details page.
- In the navigation pane, choose Instance > Consumer Groups.
- Export consumer groups in either of the following ways:
- Select the desired consumer groups and choose Export > Export selected data to an XLSX file to export specified consumer groups.
- Choose Export > Export all data to an XLSX file to export all consumer groups.
