Creating a Kafka Consumer Group
A consumer subscribes to a topic. A consumer group consists of one or more consumers. Within a consumer group, each consumer can consume multiple partitions at the same time. Each partition can be consumed by one consumer at a time.
auto.create.groups.enable: a consumer group is automatically created when a consumer attempts to enter a group that does not exist.
- A consumer group is required before consuming messages when auto.create.groups.enable is false in Configuring Parameters. Otherwise, consumption will fail.
- A consumer group is created automatically before consuming messages when auto.create.groups.enable is true in Configuring Parameters.
This section describes how to create a consumer group on the console. This operation does not restart the Kafka instance.
Notes and Constraints
- For instances created on and after April 25, 2023, consumer groups can be created on the console.
- If auto.create.groups.enable is set to true, the consumer group status is EMPTY, and no offset has been submitted, the system automatically deletes the consumer group 10 minutes later.
- If auto.create.groups.enable is set to false, the system does not automatically delete consumer groups. You can manually delete them.
- If a consumer group has never committed an offset, the group will be deleted after the Kafka instance restarts.
- Log in to the Kafka console.
- Click
in the upper left corner to select the region where your instance is located. - Click the desired instance to go to the instance details page.
- In the navigation pane, choose Instance > Consumer Groups.
- Click Create Consumer Group.
- Set consumer group parameters by referring to Table 1 and click OK.
Table 1 Consumer group parameters Parameter
Consumer Group Name
Enter 3 to 64 characters, starting with a letter or underscore (_). Use only letters, digits, periods (.), hyphens (-), and underscores (_).
If a consumer group name starts with a special character, for example, a number sign (#), monitoring data cannot be displayed.
Enter 0 to 200 characters.
View the new consumer group in the consumer group list.
Related Documents
- To create a consumer group by calling an API, see Creating a Consumer Group.
- Why Can't I View Consumers When Instance Consumption Is Normal?
