Help Center/ Distributed Message Service for Kafka/ User Guide/ Managing Consumer Groups/ Viewing and Resetting Kafka Consumption Offsets
Updated on 2025-08-21 GMT+08:00
A consumption offset indicates the consumption progress of a consumer. This section describes how to view and reset consumption offsets.
Video Tutorial
This video shows how to reset the Kafka consumer offset.
Notes and Constraints
Messages may be consumed more than once after the offset is reset. Exercise caution when performing this operation.
The consumer offset cannot be reset on the fly. You must first stop consumption of the desired consumer group. After a client is stopped, the server considers the client offline only after the time period specified in ConsumerConfig.SESSION_TIMEOUT_MS_CONFIG (1000 ms by default).
Viewing Consumer Offset
Consumer offset can be viewed on the Kafka console or on a client.
  1. Log in to the Kafka console.
  2. Click in the upper left corner to select the region where your instance is located.
  3. Click the desired instance to go to the instance details page.
  4. In the navigation pane, choose Instance > Consumer Groups.
  5. Click the name of the desired consumer group.
  6. On the Consumer Offset tab page, view the list of topics that the consumer group has subscribed to, topic quantity, total number of messages accumulated in the topic, and offset of each partition.
    Figure 1 Consumer offsets
    Table 1 Consumer offset parameters
    Topic Name
    Name of a topic that the consumer group has subscribed to
    Partitions
    Number of partitions in a topic
    Cumulative Messages
    Number of messages that are not consumed by the consumer group in a topic
    This parameter indicates the instantaneous value at the sampling. The value of its corresponding metric in monitoring is sampled every minute. These values may vary. For more information, see Why Is the Number of Stacked Messages Monitored as 0 when Messages Are Stacked?.
    Partition
    Partition number in a topic
    Accumulated Messages
    Number of messages that are not consumed by the consumer group in a partition
    Offset
    Offset of this partition
    Latest Offset
    Maximum message position of a partition
    ID
    ID of the consumer who consumes messages in this partition
    Address
    Address of the consumer who consumes messages in this partition
    Client ID
    Client identifier. This client is used to connect to a Kafka instance and consume messages in this partition.
  7. (Optional) To query the consumer offsets of a specific topic, enter the topic name in the search box and press Enter.
  8. (Optional) To export the consumption progress to the local, refer to either of the following ways.
    • Select the desired topics and choose Export > Export selected data to an XLSX file to export the consumption progress of specific topics.
    • Choose Export > Export all data to an XLSX file to export the consumption progress of all topics.
  • For a Kafka instance with ciphertext access disabled, run the following command in the /bin directory of the Kafka client:
    ./kafka-consumer-groups.sh --bootstrap-server ${connection-address} --offsets --describe --all-groups
    Parameter description: connection-address indicates the Kafka instance address, which can be obtained in the Connection area on the Overview page on the Kafka console.
    Example:
    [root@ecs-kafka bin]# ./kafka-consumer-groups.sh --bootstrap-server 192.168.xx.xx:9092,192.168.xx.xx:9092,192.168.xx.xx:9092 --offsets --describe --all-groups
    Consumer group '__consumer-group-dial-test' has no active members.
    GROUP                      TOPIC           PARTITION  CURRENT-OFFSET  LOG-END-OFFSET  LAG             CONSUMER-ID     HOST            CLIENT-ID
    __consumer-group-dial-test __dms_dial_test 0          350             350             0               -               -               -
    __consumer-group-dial-test __dms_dial_test 1          350             350             0               -               -               -
    __consumer-group-dial-test __dms_dial_test 2          350             350             0               -               -               -
    Consumer group 'test' has no active members.
    test            topic-01        0          5               5               0               -               -               -
    test            topic-01        1          3               3               0               -               -               -
    test            topic-01        2          10              10              0               -               -               -
  • For a Kafka instance with ciphertext access enabled, do as follows:
    1. (Optional) If the username and password, and the SSL certificate has been configured, skip this step and go to 2. Otherwise, do as follows:
      Create the ssl-user-config.properties file in the /config directory of the Kafka client. Add the username and password, and the SSL certificate configuration by referring to 3.
    2. Run the following command in the /bin directory of the Kafka client:
      ./kafka-consumer-groups.sh --bootstrap-server {connection-address} --offsets --describe --all-groups --command-config ../config/{ssl-user-config.properties}
      Table 2 Consumer offset query parameters
      connection-address
      Connection address of a Kafka instance. To obtain the address, choose Overview > Connection.
      Configuration file name. This file contains username, password, and SSL certificate information.
      Example:
      [root@ecs-kafka bin]# ./kafka-consumer-groups.sh --bootstrap-server 192.168.xx.xx:9093,192.168.xx.xx:9093,192.168.xx.xx:9093 --offsets --describe --all-groups --command-config ../config/ssl-user-config.properties
      __consumer-group-dial-test __dms_dial_test 0          347             347             0               -               -               -
      __consumer-group-dial-test __dms_dial_test 1          347             347             0               -               -               -
      __consumer-group-dial-test __dms_dial_test 2          347             347             0               -               -               -
Resetting Consumer Offsets
  6. On the Consumer Offset tab page, you can perform the following operations:
    • To reset the consumer offset of all partitions of a single topic, click Reset Consumer Offset in the row containing the desired topic.
    • To reset the consumer offset of a single partition of a single topic, click Reset Consumer Offset in the row containing the desired partition.
    • To reset the consumer offset in all partitions of all topics, click Reset Offset.
  7. In the displayed Reset Consumer Offset dialog box, set the parameters by referring to Table 3.
    Table 3 Parameters for resetting the consumer offset
    Reset By
    You can reset an offset by:
    • Time: Reset the offset to the specified time.
    • Offset: Reset the offset to the specified position.
    Reset Offset works with a specific time.
    Time
    Set this parameter if Reset By is set to Time.
    Select a time point. After the reset is complete, retrieval starts from this time point.
    • Earliest: earliest offset
    • Custom: a custom time point
    • Latest: latest offset
    Offset
    Set this parameter if Reset By is set to Offset.
    Enter an offset, which is greater than or equal to 0. After the reset is complete, retrieval starts from this offset.
  8. Click OK.
  9. Click Yes in the confirmation dialog box. The consumer offset is reset.
    On the Consumer Offset tab page, click before the topic whose consumer offset has been reset, and view the new value in the Offset column.
Related Document
To reset consumer offset by calling an API, see Resetting Consumer Group Offset to the Specified Position.
